I had a test drive with the pump fitted back on the engine,
which started the problens on our tour to Belgium, and the problems are back!
The manometer shows only sometimes 0.1 bar, most time 0.08 bar,
uphill and with powerfull driving quickly falling to 0.05 bar.
With the engine not willing to rev up and not willing to pull.
This pump worked well for years, so I will fit new valves in there.
And from my collection of pumps I compared 5 springs, all different.
So yesterday night I fitted a stronger one.
Test drive this evening.
my thought yesterday evening:
- if the valves are a problem, a stronger spring does not solve it
- do I have new valves? no
- do I have different springs? yes
Could a weaked spring be the problem?
Perhaps, and today with the stronger spring the pressure jumped up to about 0,15 - 0.16 bar.
The car run well, but reving the engine uphill and strong it could still be better with 0.2 bar?
AP1GczNYtrS3QaYJ6vHEFPRAltdfGV-cWEkGaBJN
Springs I have are 1.6 and 1.9 mm diameter and have different length.
AP1GczMKXbBuZPSxxxBSvkRMF0i2WBD11z0I8XIx
Pressed with the housing against a letter scale (max 2 kg display) until the flange nearly touches the scale the loat is:
one has 1.7 kg, two have 1.8 kg, the one I fitted now has some more than 2.0 kg (scale tilt), anotherone I guess 2.2 kg (on the photo).
AP1GczOr-vSR7YeFnrGobIDqKsrVT_hMPvo3YjHf
I will now drive the TR with the 2 kg spring and order parts to rebuilt an original AC pump with the 2.2 kg spring.
Marco
From what you say, it certainly points to a fuel issue. I would have thought the fuel pressure was not that critical unless you are working at the max limit of the pumps capability and the capacity of that pump is much higher than required by the TR 4 pot. Max pressure is important in preventing it from overcoming the carburetors needle and seat. Thought....could the car be running rich rather than lean? Unlikely but just a thought.
To me, it sounds like you have a flow rate which of course can be caused by a low pressure issue. Pity you do not have a O2 sensor.
Have you been able to check the plugs for any indication as to if it is isolated to one or both carburetors. Just thinking out loud here.
The spring governs the pressure and would not cause the issue you have. The springs specs  would not change over the rev band they work in. The valves are important, both sets of valves. The two in the pump and the two in the carburetors. If the pressure drops as the speed/load increases it tends to indicate it is not the carby needle and seats so the fuel pump valves sound suspect.
Do you not have a spare pump you can try? Even a jury rigged electric pump would certainly isolate or confirm the fuel pumps part in the issue.
Brian
Edited by Trumpy3
spelling correction
Hi Brian,
thank you for your thoughts, I will check the ignition (points at the moment).
A spare pump I checked, it produces 0.1 bar.
The fuel pump pressure not only causes the fuel rate, also the fuel level in the float chamber.
—> low pressure —> low level —> below the jet
—> higher pressure —> higher level
The pressure should (and is) about constant on a diaphragm pump due to its construction.
A club mate told me at least 0.2 bar is essential needed for SU HS6.
He swapped to an electric pump, because several mechanic pumps he tested did not at all deliver 0.2 bar.
AI tells HS6 are best at 0.20 - 0.35 bar.
What pressure do other 4 pot drivers have with their electrical fuel pump, please?
Good Morning Marco
Just a thought, have you checked th the cam lobe for wear? It may be that your pump is not getting full action therefore not giving sufficient fuel delivery.
George
Hi George,
I touched on the cam yesterday with my finger to check the top center, the surface is smooth.
Also with the engine on idle, I can feel on the primer lever: the pump lever is lifted off the cam and only touches the very top of it.
All OK there, thats how a diaphragm pump works.
Marco
Never measured the pressure from electric fuel pump but their specs say from 1.7- 2.1 Bar (2.5 -3.0 PSI).
Brian
4 hours ago, Trumpy3 said:
Marco
Brian
pretty sure 0.17 - 0.21 bar 😀
yesterday we had the 200 km autumn-Ausfahrt of our local calssic car club.
The "problem pump" started with 0.14 bar, sometimes 0.12 - 0.15 bar, driving was lovely and better than ever.
But at the end of the tour the pressure dropped down to 0.08 - 0.10 bar with poor running on the acceleration lane and Bundesstraße,
--> the problems are mainly the valves, but also the weak spring
New parts from Flexolite I get tomorrow and hope I can built a reliable pump for 0.16 - 0.20 bar.
If not, I sorry that, I will buy a German built Hardi electric fuel pump.
this are the springs I got from a number of pertol pumps,
all with different wire diameter, length, turns and force to compress.
AP1GczPAjVti6Xjv1OiPZizzgi8mChY1D-hJTBvv
I restored an original AC pump with new valves and the 2,850 g spring, now with the fuel pressure constant at 0.22 bar.
The TR runs lovely this way, but the problems are not gone. I guess the problem is not only the fuel pressure....
edit: it was the problem every moment  the fuel pressure dropped below 0.1 bar
Marco
Another case of chasing the wrong cause. Could it be electrical???
Brian
Some more fuel pressure than 0.1 bar is never wrong 😀
And interesting how many springs exist, without being mentioned anywhere….
My next target: the condencer
With the coil it is a RC circut, the condenser is needed not only to delete the spark but also to reload the coil
Marco
Are you saying the problem was a faulty condenser?
Brian
Hello,
The test would probably have taken 5 minutes.
Then an engine tester would have analyzed the fault.
Stay well, Ralf
Sadly I had 3 different faults this year:
May: my Blue Bosch ignition coil had ignition breaks (anotherone fitted)
September: my mechanic fuel pump had pressure breaks (I now restored and fitted an original AC with the strongest spring I got)
October: the condenser failed (points fitted in May to exclute a fault from my Ignitor 1)
                --> the problem is clearly different from the fuel problem
The condenser is pretty easy to test for everybody with a multimeter in a few minutes, no tester / workshop is needed:
Go on the resistance mode to max resistance (20 MOhm), this works with a small voltage (and current).
At the beginning the condenser is empty (short cut it, 0 Ohm), after a very few seconds on the multimeter (2-3 sec) it is full loaded (>20MOhm).
So the display starts at „zero“, the numbers quickly rises to „1“, or tilt or what ever your multimeter shows on infinite.
Short cut the loaded condenser again and repeat.
If it does something different, for example constant zero, a low or alternating resistance, it is faulty.
info added: the condenser must be out of the distributor for a reliable result.
Testing for a condenser failure is even simpler - just take it out!
The condenser was added to his invention by Kettering only a few months after it's introduction on a Cadillac on 1912,  when he realised that arcing at the points limited thier life.    Condensers fail in two ways - they fail to condense, and your points last a shorter time, but that's all.  Or they fail to insulate and short circuit the points, leading to no spark, no ignition.   Either way, taking the condenser out restores the spark and will get you home from almost any journey.
I learned the issue is different.
Without a condenser, or with a condenser with reduced capacity, you can not really „drive“ a car.
This is not only an problem for the points.
The condenser and the coil is a needed oscillating circut,
the moment the points open the condenser loads up energy and helps to re-load the coil the next moment.
Without the condenser the coil is not propper loaded and the spark is poor.
In my case, from one day to another, the engine was poor to start, poor on idle, poor running on start driving, poor pulling on every rev and every situation.
The symthoms have been clearly what I‘ve been told
True up to a point Marco but oscillation has little to do with it.
 Without the condenser, when the points open there is an arc struck.   That causes the coil primary current to reduce slowly rather than cut off quickly.   The coil output voltage is proportional to the speed of switching - the faster the change of current the faster the rate of change of the magnetic flux in the coil, and the higher is the output from the coil, so that if the change is slowed the HT is lower too*.   Without the condenser there can be insufficient HT voltage to 'fire' the plug properly so the engine mis-fires particularly at higher revs.
[*  e=Blv where e is the voltage generated, B is the magnetic field strength,  l is the length of the conductor in the  field ,  and v is the rate of change of flux. ]
Hmmmm…
No doubt, the condensator is loaded by the current each switch of the points.
What happens with the load / energy, when the condensator must be empty for the next switch, please?
Any residual charge in the condenser will just get shorted out when the points close again.  There is very little energy in that.
All the useful energy from the coil is discharged  through the spark plug until the voltage is too low to sustain the spark.  There is some minor ringing after that which is just an artifact of the LC circuit but it doesn't really play any part.
Does not the charge in the capacitor discharge when the points close?
Brian
Rob, thank you for your explanation!
It seems I've been told something wrong and told that in good believe?
This is not a problem, it is the common issue 😂
Yes, thank you Rob, for explaining the need for a condenser in far more detail than I could have.     But my point remains.   One way they can fail is to short circuit the points, when there will be no ignition spark at all.   Taking out the condenser will allow an ignition spark and the car to run.
Yes, there will be arcing at the points and less efficient generation of a high volts ignition spark, but it will get you home!
Did you try, please?
IMO this is dangerous for the public traffic and yourself.
