Hi . I’ve finally reached the fun bit of my TR3A full restoration. I hope . I would appreciate some advice on the following.
1. I’m wondering how to remove the old fabric which is currently bonded onto the dashboard. It is so thin I originally thought it was painted. Any special tips out there or should I even consider leaving it on?
2. when bolting the wings onto the car should I use some kind of mastic? Or rubber between the surfaces? I have new stainless steel beading.
3. I am not really in a position to take my car to a trimmers, so am going to tackle the job myself. Just wondering if anyone has recommendations for suppliers ? John Skinner seems to have a good reputation but I have no knowledge of anyone else. I assume you get what you pay for .
thanks Ollie
The TR Shop can provide you with a complete trimming kit, including new vinyl for the dashboard.
 did mine that way, & am pleased with the results
post-12009-0-28281600-1475058880_thumb.jpg post-12009-0-20318200-1475058925_thumb.jpg post-12009-0-02741800-1532513479_thumb.jpg 816997806_RHside2.thumb.JPG.8419a3e9190cc15d08e8cbe47d62e133.JPG  click on to enlarge
Tr shop are good for trim, although door pockets were awkward a year so so ago, mine collapsed after 40 odd years. Skinners make them but they are not cheap but are a nice product.
Re wings, some none setting sealant is a good idea, Sikoflex or Windscreen sealant. Alternatively a liberal coat of Lanoguard grease on both faces.
TR Shop door pockets work well, I'm 13 years in now, & good as new.
They do all the panels as well - door's, tank, & behind the B posts
Edited by Lebro
TR Shop would be my first choice too. The original dash covering does really need to come off for a good job, hot air gun and a scraper would help. Those seat springs will disappoint you, they are far too stiff in comparison with originals that had lots of thinner springs, if your originals are too far gone to re-use then you`d be better off replacing them with a good quality foam like a memory foam and carve a lump of it to suit the original shape (electric carving knife works well to get the shape right)
+1
Don't do what I thought was a "Good idea" and make a hot wire cutting tool  out of nichrome wire and a battery charger.
I almost passed out within 10 seconds from the smoke and fumes. Seriously dangerous.:(
I Found the new springs very bouncy so have used tie wraps to stiffen them up. Will see how that works
I have use this stuff for sealing the bolt together mating surfaces on the body panels to keep the water etc out easy to wipe off the excess
https://ebay.io/m/4lpVWt
Edited by Hamish
Try your wing beading for length against the wings before attempting to fit.  The front bead metal bit is notorious for being the wrong curvature.  Be sure the bonnet gap is big enough to accommodate the beading both sides.
If I may offer my six pennyworth :
I'm not convinced that it is a good idea to put anything between the wings and the rest. I like to think that if I put nothing,  the rain water will drain away rather than be caught and held by mastic to promote corrosion.
For the dashboard, I had the same problem to strip it. I used a paint stripping gun with a spatula and finished with a rotary wire brush and some solvent. It came off with no problem.
I too have used these bed springs for the seat base as they were all that was available at the time. I don't have any comfort problem with them.
james
Whilst I understand James reluctance to use a sealer, I used windscreen sealant 45 years ago, when I took the front wings off last winter it was still unset. I was utterly amazed.. No corrosion present on the inner or top wing flange…..the lower returns however had to be replaced.
I don’t seal the wing joints but make sure that there is plenty of underbody protection wax on both faces before bolting up.
That was my alternative, hence mentioning Lanoguard Grease, you can brush it on to give excellent coverage.
I brushed on loads of Waxoyl  on both faces which oozed out under the stainless trim as I tightened the bolts. Tooke a bit of cleaning off but I know they are as sealed as I can get them with the added advantage that if you need to take the front apron off at some point in the future as I did it comes apart easily.
Ralph
Some great comments there, thanks. Had a chat with TR shop, apparently they source most of their interior trim from John Skinner. Also it seems there are two types of springs available, the Moss ones come from Korea or somewhere out east. John Skinner makes his own and used to supply Moss before they took the budget route. TR shop offer both.
Looks like some kind of non setting wax  or sealer is the way to go with the wings, some interesting options there . Thanks for your input as always
Surprised to hear TR Shop trim is supplied by John Skinner, always found John Skinner expensive and TR Shop reasonably priced. Also surprised that they divulged their supplier.
Sealer used when fitting wings??????? I'm glad we don't have salt on our roads.
I have found riveting the SS bead to the wings has been great. A painter done this to my TR3A some 10 years ago using a small rivet. It has been first class and greatly reduces the time to R & R the front apron. Also reduces the chances of scratching the paint work. When the beads are riveted, it ensures they fit correctly.
Brian
Many years ago they used to supply trim from John Skinner senior (it’s what I have in my 4a) and the quality was very good but It went downhill when he retired and Johnathan took it over and I wouldn’t use it for a long time after a very public row over quality. Be good if he’s pulled his socks up and improved the quality now. TR Shop were supplying Martrim in the meantime.
Stuart
Hi. Another thing I was going to ask is regarding the stone guards. I bought new ones from Rimmer which fit much better now after some modifications! Do you recommend using any kind of sealer under or around the guards? Maybe there should be some kind of rubber seal? Thanks
Again I just slathered mine with Bilt Hamber Dynex U-C inside and on the mating part of the wing and cleaned off the excess with white spirit afterwards.
There should be two seals, one that goes up the side of the splash panel and goes up against the upright section of the wing and then a top seal that is riveted to the panel using a small steel strip, this covers the top section up against the top curve of the wing and up against the return section that bolts the wing to the inner wing. I waxoyl behind and then fit the panel using a non setting sealer down the side and around the edge of the top seal to form a fully waterproof seal.
+ again
I had my steel filler plates powder coated some 25 years ago and that saw them rust free when removed for  the body repaint 5 years ago.
As an aside…..I have a NOS original that I used as a pattern to cut my steel ones from.  Originals are two piece items with the top side flange spot welded to the main filler plate.   Ideally I should have remade them from stainless steel sheet I think.    At C&B we sold ones that we cut on a bandsaw out of aluminium sheet.  Also we had a flypress punch to pierce the bolt slots.   No idea where that went.
