Ralph Whitaker Posted September 25 Report Posted September 25 On 9/23/2026 at 2:37 PM, OllieK said: Hi. Another thing I was going to ask is regarding the stone guards. I bought new ones from Rimmer which fit much better now after some modifications! Do you recommend using any kind of sealer under or around the guards? Maybe there should be some kind of rubber seal? Thanks I think Ollie may be referencing the alloy stone guards for the rear wing. I always wondered whether there should have been a rubber seal along the top edge at least. Ralph Quote
OllieK Posted September 25 Author Report Posted September 25 Yes you’re correct Ralph though those front wing seals will be an issue soon. It does feel like there should be a rubber seal along the top of the stone guards. I might try and fabricate one. I also like the idea of riveting the beads to the wings prior to assembly. It will definitely make the assembly job easier. Has anyone used butyl sealer strips for the join? Quote
Ralph Whitaker Posted September 27 Report Posted September 27 On 9/25/2026 at 4:32 PM, OllieK said: Yes you’re correct Ralph though those front wing seals will be an issue soon. It does feel like there should be a rubber seal along the top of the stone guards. I might try and fabricate one. I also like the idea of riveting the beads to the wings prior to assembly. It will definitely make the assembly job easier. Has anyone used butyl sealer strips for the join? Have a look at VW Beetle accessories, I am sure they did an alloy stone guard for the rear wings, and I am fairly certain they used a rubber seal around the top. Ralph Quote
iain Posted September 27 Report Posted September 27 (edited) On 9/25/2026 at 4:32 PM, OllieK said: Yes you’re correct Ralph though those front wing seals will be an issue soon. It does feel like there should be a rubber seal along the top of the stone guards. I might try and fabricate one. I also like the idea of riveting the beads to the wings prior to assembly. It will definitely make the assembly job easier. Has anyone used butyl sealer strips for the join? It makes assembly easier, but, it makes removal of the front apron a total PITA in the future. If you use stainless steel self tappers in the engine bay, these can be removed, the front wing bolts to apron loosened and the paint protected with tape and then the beading removed for safe keeping. Refitting being the reverse. A liberal coat of Lanoguard or Lanoguard grease behind the wing beading plates ( or your favourite body wax) stops rust forming behind. Iain Edited September 27 by iain Quote
OllieK Posted September 28 Author Report Posted September 28 Sorted the dash… gentle heat from my trusty blowtorch worked a treat . Thanks for that tip! Quote
OllieK Posted September 29 Author Report Posted September 29 Ordered the interior from skinners via the TR shop. Everyone is a winner , J.Skinner get a sale, TR shop gets a sale and I get a discount. Thanks for all your advice. Quote
