Desperately WANTED in Australia....Old factory ID plate for LHD TR4A.
Unfortunately misplaced the original ID plate for my project car.
Put it in a safe place, but now cannot find it.😒
I did not record the details either.
None of one’s vehicle ownership documents in Australia have the car’s commission number or VIN?
I would not have guessed that!
That happens to me a lot, more frequently as I get older.
Ralph
Possibly worth enquiring to British Motor Heritage for the Heritage Certificate using any information you may have such as the engine number.
Blank reproduction plates are available from numerous spare parts suppliers.
Ralph
Yes Ralph....This "getting older" has many disadvantages 🤣
Thanks guys,
I have now found the CT number in my paper records...I would like to obtain an original ID plate in reasonable condition so that I can restamp the CT number on it, rather than fit a shiny new plate.
Edited by Malbaby
4 hours ago, Malbaby said:
Thanks guys,
I'd guess re-stamping a number on a commission plate really won't work that well, @Malbaby..  If it were my project, I'd get a new plate, stamp it with the correct (and only commision number), and use that until the original showed up -- which it almost certainly will some day.
I might try to patinate the new plate a bit, but I wouldn't do much to it, and I'd probably use it as is.  There are thousands of TRs out there with replacement commission number plates and they generally look OK.
The hardest thing will be to make the stamping look original.  Almost none are aligned as well as the originals, some are stamped against a block of wood giving a completly wrong look to the imprint, and I have yet to see a set of stamps that were exactly like the typface used by Standard Triumph back in the day.
This method/tool gets things a bit less 'that'll do'
23 hours ago, Malbaby said:
Thanks guys,
I should have said CTC number.
