Highcliffe Posted September 26 Report Posted September 26 Would someone please let me know a good method for screwing the milled securing nut on the instrument gauge support in a TR4a please. I just can’t get the fiddly little thing on the threaded post and turn it. I feel as though I need 3 hands with fingers that are a foot long to be able to manoeuvre it properly since I keep losing it into the floor well or behind the H support. Any guidance would be gratefully received David Quote
MichaelH Posted September 26 Report Posted September 26 The way I do it: Put a little thick grease in the centre of the knurled nut. It will then stay on my first finger so I can locate it on the end of the threaded rod Next try to turn the nut anti clockwise (as you see it from the front) using my thumb and second finger. needless to say it doesn't always work first time Good luck MichaelH Quote
Highcliffe Posted September 27 Author Report Posted September 27 Thank you Michael, I shall try your method when the replacement nuts arrive from Rimmers. I have ordered a few spares for the inevitable losses! Regards David Quote
stuart Posted September 28 Report Posted September 28 On 9/27/2026 at 6:03 AM, Highcliffe said: Thank you Michael, I shall try your method when the replacement nuts arrive from Rimmers. I have ordered a few spares for the inevitable losses! Regards David Check that they are the correct thread first too. Stuart. Quote
Charlie D Posted September 29 Report Posted September 29 On 9/28/2026 at 11:06 AM, stuart said: Check that they are the correct thread first too. +1 I have got a dozen or so instruments in my spares box and 20+ knurled nuts. I don't think any of the nuts fit any of the instruments. Quote
MichaelH Posted September 29 Report Posted September 29 Everyday is a school day I thought all the nuts and threads were common! I bought some knurled nuts and they fit all my instruments so far obviously good fortune MichaelH Quote
harrytr5 Posted September 30 Report Posted September 30 You could try removing the speedo and rev counter.Undo the five securing screws. Undo the glove box sliding hinge and pull the dash backwards to you. At this point you may find the oil gauge pipe stopping you pulling it further backwards. Unscrew it and do not loose the leather washer. Now easy to get your hand in. Yes a convoluted way but give access with out crawling around under the dash. For some reason the Gauge manufacturers used different threads and not a common one which would make life at bit more easy. Good luck you will get there. Regards Harry Quote
Highcliffe Posted October 1 Author Report Posted October 1 Thank you all for your advice and comments, all of which are noted After contorting myself into a strange S shape to reach under the dash, I found removing the passenger seat made it far easier and then I realised that, after impaling myself through a belt loop and getting stuck, that removing the rear set of seat securing bar/bolts too was much the safer and a less painful route. I also discovered that using a pair of chopsticks, after smearing the threaded instrument securing stub with grease, worked after a number of attempts, in getting the nut onto the stub and then using one chopstick as pressure and some very long, thin nosed pliers to turn it, I got it on! I hope the LED bulb lasts a lifetime because I don’t fancy going through all that again All the best David Quote
RogerH Posted October 1 Report Posted October 1 (edited) Hi David, the method that Harry has posted immediately before yours really is the way to go. But, well done for surviving such a task. Roger Edited October 1 by RogerH Quote
