dblenk Posted September 28 Report Posted September 28 (edited) i have no problems with the ride its soft (one of the lads said like a bed hahah) but with two big lads in a photo taken while driving shows a lot of negative camber i am running1970s springs so i have some new Revington 450lb springs in the garage never fitted anyone running them and will it loosen my fillings ??? was going to run std lever arms ?? its LHD i am driving hahah David Edited September 28 by dblenk Quote
john.r.davies Posted September 28 Report Posted September 28 I've driven a GT6 with 1000lbs fronts, and it was surprisingly not tooth rattling! John Quote
Malbaby Posted September 28 Report Posted September 28 I would leave as is, especially as you like a comfortable ride....Nothing wrong with some negative camber, unless you are travelling high mileages. 450 springs would be good for spirited driving. Easy to swap out the rear springs for a trial. Quote
dblenk Posted September 29 Author Report Posted September 29 yeah i can give them a go see what its like David Quote
dblenk Posted September 29 Author Report Posted September 29 looking again at the photo and looking at the car i checked the toe-in at the manual and it 1/16" mine by eye is way more so another job to check/set as i get my camber to measure ok unladen if it is tracking its the view of the wheel on the cock not camber a good winter job to check everything thks David Quote
harrytr5 Posted September 30 Report Posted September 30 I fitted Revingtons springs in 2000 as he told me at the time he has them made to his spec and the poundage is correct unlike others than can be a bit iffy. They have served me well despite changing the dampers to ones I preferred  years later. Konis front and rear uprated original lever Armstrong dampers. The ride is good, so good, that around five of my mates have converted to the same set up  and all remarked how good it feels. So fronts  RTR3192 springs red/blue 400lbs and RTR3101 rear springs red/yellow 450lbs. So you are in good stead David. Fillings still in. Regards Harry P.S. you are welcome to have a drive in mine before you make up your mind. Quote
michaeldavis39 Posted September 30 Report Posted September 30 Harry are the Revington Springs original factory ride height or lowered? Quote
harrytr5 Posted October 1 Report Posted October 1 I will find out David but if you look at mine they look standard to me. Quote
harrytr5 Posted October 1 Report Posted October 1 12 hours ago, michaeldavis39 said: Harry are the Revington Springs original factory ride height or lowered? Slightly lower but you would not know. I now run with Blockley's  185 x 70 x 15. The rear higher because of the rear disc handbrake how I have fitted it can foul underneath. Since rectified by using thicker insulating poly rings and altering the way I mounted the handbrake. The road clearance is not an issue with the Revington road springs. I made that mistake on my then TR6 with lowered road springs, soon learnt my lesson, track yes, road a no,no! Regards Harry Quote
stuart Posted October 1 Report Posted October 1 7 minutes ago, harrytr5 said: I made that mistake on my then TR6 with lowered road springs, soon learnt my lesson, track yes, road a no,no! Regards Harry With the roads these days you`d be better off with a setup like this 😉 Stuart. Quote
harrytr5 Posted October 1 Report Posted October 1 3 hours ago, stuart said: With the roads these days you`d be better off with a setup like this 😉 Stuart. or this Quote
stuart Posted October 1 Report Posted October 1 16 minutes ago, harrytr5 said: or this Yep same principle, it`ll not be long before we will need it. Stuart. Quote
dblenk Posted October 2 Author Report Posted October 2 I know i have 205/65 tyres but they are a bit different haha yeah ordered uprated lever arms to go with the springs hopefully all looks std cheers PS would love an off road 6 i had a deranged ford ranger until i sold the company so normal stuff now Quote
Steve-B Posted October 4 Report Posted October 4 On 10/1/2026 at 12:31 PM, stuart said: With the roads these days you`d be better off with a setup like this 😉 Stuart. Definitely the recommended setup for Buckinghamshire and Oxfordshire! Quote
dblenk Posted October 4 Author Report Posted October 4 2 hours ago, Steve-B said: Definitely the recommended setup for Buckinghamshire and Oxfordshire! love that the purists would have a heart attack would need a bit at the back with a 1T pay load ideal company car hahahahah Quote
michaeldavis39 Posted October 4 Report Posted October 4 Harry have you got the thicker poly spacers on your front springs too or just the rear? Quote
harrytr5 Posted October 5 Report Posted October 5 Just the rear. With my Blockley's I can make my TR5 dance! Now I have fixed my overdrive (burnt out solenoid) the drive is back to pleasure 130 miles yesterday. Regards Harry Quote
