Robc Posted September 28 Report Posted September 28 Hi, I am trying to identify if the cylinder head (as per the photo’s attached) has come from a TR4A engine or if in fact it is a TR4 or even a TR3 head. I inherited this head several years ago when buying my TR4A which had gone through restoration including fitting a new cylinder head. So effectively this is a spare head. Can anybody identify which TR model this will fit ? Quote
Hamish Posted September 28 Report Posted September 28 (edited) This site may help you www.tr3a.info/FAQ_heads.htm Edited September 28 by Hamish Quote
BlueTR3A-5EKT Posted September 28 Report Posted September 28 Looks like high port for TR3-4 not originally a TR4A. With early large diameter springs but I can’t see the inner aux spring on the exhaust valves. No angle chamfer in the combustion chamber so probably originally for 83 mm. Push rod tubes look like aluminium which would place tge head as later 3A-4 models Exhaust valve look pocketed so seat inserts may be required. Good basis for a rework. Get the chambers worked on to achieve your desired compression ratio with the piston set up and choice of gasket you have in mind. Confirm clearance of the thermostat water outlet casting at the front over the water pump housing if you get much milled off the head gasket face. Quote
rcreweread Posted September 28 Report Posted September 28 (edited) 11 minutes ago, BlueTR3A-5EKT said: Looks like high port for TR3-4 not originally a TR4A. With early large diameter springs but I can’t see the inner aux spring on the exhaust valves. No angle chamfer in the combustion chamber so probably originally for 83 mm. Push rod tubes look like aluminium which would place tge head as later 3A-4 models Exhaust valve look pocketed so seat inserts may be required. Good basis for a rework. Get the chambers worked on to achieve your desired compression ratio with the piston set up and choice of gasket you have in mind. Confirm clearance of the thermostat water outlet casting at the front over the water pump housing if you get much milled off the head gasket face. Peter - I would concur with your ID and comments - here is a photo of a 4A head ID on a plinth just above no 1 inlet port Cheers Rich C-R Edited September 28 by rcreweread Quote
Z320 Posted September 28 Report Posted September 28 Does it look like stronger inner and outer springs on valve #7? And #6 has 2 marks with a punch, #8 has one? Is there a reason to mark them? Not a problem at all, just to notice…. Quote
james christie Posted September 29 Report Posted September 29 12 hours ago, BlueTR3A-5EKT said: Good basis for a rework But do have it crack-tested before you start! I have a very original head from my 3A which has never been molested. Fortunately the machine shop examined it thoroughly before starting work on it. Two irreparable cracks in the n°3 exhaust valve area 😩 james Quote
