Pyttspete Posted September 29 Report Posted September 29 Any suggestions please, on how to stop an oil leak from the mechanical fuel pump? Now on my third gasket and still the leak returns under the base of the pump. I have even tried changing the pump itself for NOS but no improvement. It’s clear that where it leaks from is the narrowest part of the block face where the pump fits. The first time I used the gasket with Permatex Form a Gasket sealant liquid, but not sure that is oil resistant. The second one I tried Permatex 2 which does resist oil and petrol, but no luck. Wrong sealants possibly??? Cheers. Quote
ewan2 Posted October 1 Report Posted October 1 Pyttspete I was supplied with gaskets for a rebuild and the cut out was too high if fitted it would have leaked. I found one the correct shape and fitted it. The pump still drips oil but not from the joint. Ewan Quote
John McCormack Posted October 2 Report Posted October 2 The pump leaks from the shaft that the lever pivots on. I believe you can overhaul it, and it might last a few thousand miles. Make sure the gasket has the cut out/hole at the bottom so oil can drain back into the sump. Some gaskets don't have it. Quote
Z320 Posted October 2 Report Posted October 2 Hi Pete, these aluminium (or zinc) housings are soft like butter. Put the lever out and check the flange. I had to face a pump some weeks ago and did it on another one yesterday, Ciao, Marco Quote
Z320 Posted October 2 Report Posted October 2 This is a rubber based gasket I ordered from Flexite on recommendation of Peter W (?) I have seen something like this in red before, and fitted it tody with my restored AC pump (with faced flange). Ciao, Marco Quote
Hamish Posted October 2 Report Posted October 2 That should do you Marco it’s the same pattern as I found on my pump. The red one was quite thin and flexible. But it was old. Quote
rcreweread Posted October 2 Report Posted October 2 1 hour ago, Z320 said: This is a rubber based gasket I ordered from Flexite on recommendation of Peter W (?) I have seen something like this in red before, and fitted it tody with my restored AC pump (with faced flange). Ciao, Marco That or a very similar rubber gasket was always supplied to me, together with a paper gasket, by Dave Davies when he rebuilt the OE pumps for me, and which I passed on with any purchases. Unfortunately, he has very little, if any, OE spares left and hence is largely unable to supply further TR pumps - he did however manage to put together 2 pumps for me recently as I didn't have a spare for myself so I do have one left, if anybody is interested. Also, I'm not sure that all the rebuild kits include the oil seal in the very bottom of the pump, which might have an impact on oil leaks?? Cheers Rich Quote
