We have a two door Samsung  'fridge freezer which has always worked very well. It is over 6 ft high and the two doors are full length . It is a RSG5DURS
There has been a small puddle of water at the lower right hand edge of the door for a long time. I am cleaning up the  floor at least three times a day. There is a supply of water to the freezer and that can be used by filling a glass at the water tap on the freezer side. We could turn off the supply but that would have negative effect on the ice / freezer
In the summer I emptied the 'fridge and took off a long inside panel at the back This did expose two flexible  tubes which looked like water supplies, but they were dry as a bone. The small leak is inside the back of the 'fridge. The kitchen cupboards are built around the Samsung and moving it out into the kitchen is a major disruption especially if we have no plan.
I need some advice from the Forum on what to do next. I have contacted Samsung but they are not helpful..
Any advice would be very helpful
Richard
Richard
Most fridges/ freezers I'm aware of have a sloping channel at the back of the fridge with a drain hole in the middle to take away water from condensation within the fridge  - from the drain hole there is usually a pipe which empties the water into an open reservoir on the top of the compressor which effectively evaporates it .
The drain hole often get blocked with mould and other food detritus so the channel overflows and runs down to the bottom of the fridge and onto the floor - I have to clean ours like this every so often  and use a wooden kebab stick to poke down and clear it - no need to take the fridge out -  may be this is your problem
Cheers Rich
14 hours ago, rcreweread said:
Richard
Cheers Rich
+1
if you google the issue and fridge model number there is lots of info and videos
like this which goes into a lot of detail for inside fridge fixes and rear compressor checks
Edited by Hamish
Thanks for the help. I am walking the dog this afternoon and will start on the Samsung tomorrow ??
Richard
Hi Richard
There will be two potential sources for the water. Condensation build up which would normally drain to the compressor where heat generated will evaporate it away or the water plumbing for the water/ice dispenser. Turning the water off for a while will tell you if it is the water system is leaking without impacting chilling performance (possibly internal filter seals if it has one or failed push fit pipe joint).
If you still have excessive water, my next stop will be any blocked drain holes at the back of the food compartment (stray garden peas are a good drain plug), which may be stopping normal flow.
Excessive ice build up and hence water from a modern frost free unit can be due to a split door seal or twisted door. This allows moisture in the air to get into the unit.
Finally, note if the compressor is cutting in and out normally. If running continuously, there may be a problem with the thermostat controller.
Regards
Steve
Hi Richard,
I had the same water leakage on my double door Samsung refrigerator.
I found a small layer of ice in the bottom of the freezing compartment, and water came out on the left side where the freezer is, so this is where my problem was.
I disconnected the electric first.
Then I emptied all goods and glass plates from the freezer, then removed the rear panel (screws and sticky tape, so start pulling in one corner).
The drainhole was now visible and was frozen and plugged. I melted the ice with a hot air gun from a distance (careful with the plastic!).
At the same time, I blew out melted water from the drain hole to speed the process with a compressor (yes😀!).
Once the drain channel was cleared, I inserted a single strand of copper wire (1 mm2); the copper reduces risk of algea formation I was told by an old plummer.
On the back of the refrigerator, I removed the lower panel and blew clear the compressor and condensor (radiator), you would be surprised how much dust collects in there! This improves efficiency (a lot, I think). I used the air compressor and a vacuum cleaner, to simultaneously clear the dust).
The freezer has worked fine since.
This is not a difficult job, it took me 2 hrs in total.
Waldi
Thanks for the detailed advice and I will try the drain hole cleaner soon. I change the sponge which I have put there to soak up the water and yesterday it was not wet ??
I have left it with no sponge  all  day and it is  still dry.  How did this happen ?? If only the TR would self repair
Richard
I think the defrost is intermittent Richard, not continuously. We had a puddle of water every now and then too.
Waldi
