John Mellor Posted Saturday at 03:32 PM Report Posted Saturday at 03:32 PM Hi all. Giving a biannual coolant flush and last time I was aware the tap was seized as was the radiator tap which I replaced with a bolt and ptfe tape. I'd like to remove the block tap to clear any crude. I'm wary of breaking the tap thread ending up screaming wtf. The car never overheats even crossing Spain and has the bog standard metal fan. Should I leave well alone and drain only at the rad plug John M Quote
BlueTR3A-5EKT Posted Saturday at 06:24 PM Report Posted Saturday at 06:24 PM (edited) What type of tap is screwed in the block? Winged type or original brass tap thing? For my money……..Drain the block. The drain hole in the block is at the lowest point of the water jacket where all the crud and debris might collect. Once the plug is out poke about with a screwdriver in tge hole to loosen anything Thats loose in there. COVER THE STARTER WITH A PLASTIC BAG. I too have replaced the drain plug in the block with a 1/2” unf stainless hex head screw. If you’ve an inclination for one PM me as I think I still have a spare from the batch of 5 I had to order. Note The radiator is thread BSP not UNF So the taps/plugs are not interchangeable. Edited Saturday at 06:27 PM by BlueTR3A-5EKT Quote
John Mellor Posted Sunday at 09:20 PM Author Report Posted Sunday at 09:20 PM Hi, its the original brass tap/lever. I still fear snapping the threaded part if I rotate the whole tap. Does the perfect temp control suggest there's no crud around 3/4 cylinder Quote
John Mellor Posted Monday at 12:21 PM Author Report Posted Monday at 12:21 PM The original tap in the radiator is identical to the block tap but thay are a different thread then? Quote
BlueTR3A-5EKT Posted Monday at 01:15 PM Report Posted Monday at 01:15 PM (edited) 54 minutes ago, John Mellor said: The original tap in the radiator is identical to the block tap but thay are a different thread then? As original that is correct Unified in the block. BSP in the radiator. They differ by one thread per inch and are very close in major diameter. Edited Monday at 01:17 PM by BlueTR3A-5EKT Quote
Z320 Posted Monday at 03:44 PM Report Posted Monday at 03:44 PM (edited) On our TRs a lot of threads that should be BSP (for liquids) are UNF. Does this simplify the issue? To fit a BSP ball valve I made an adapter UNFxBSP Edited Monday at 03:45 PM by Z320 Quote
