58TR3-Doug Posted October 5 Report Posted October 5 So I bought the 'improved five vane water pump to replace my original unit and according to Moss it is compatible with the original pully but when I mount the pully to the pump the back side of the pully hits the bearing block where the machining widens out (where my highlighter is pointing and the nut isn't fully seated on the shaft yet. Anybody else run into this? I can replace the pully if I have to but I'm trying to figure out if this is an issue with the new pump because if it is, a new pully isn't going to help. Original pump has the smaller shaft and nut but the pully clears just fine. Quote
Don H. Posted October 6 Report Posted October 6 (edited) I threw away one of those “uprated” 5-vane water pumps. I couldn’t tell it was doing anything better, or likely even as well as a properly set up original pump. And the cast iron impeller was corroding in my car. Grr… I’m now running my TR3B’s original pump (with 4-vane bronze impeller) rebuilt by E.P. Services in Wolverhampton, brought over and back to the USA from my trips to Goodwood and the help of my TR friend Julian. Seems to be working perfectly. I’m happy with what they did. Edited October 6 by Don H. Quote
iain Posted October 6 Report Posted October 6 Agree with Don another of those “upgrade downgrades” a refurbished original by E P Services is by far the best option. Iain Quote
Z320 Posted October 6 Report Posted October 6 (edited) Hi Doug, please show us the 5 vanes impeller and measure its hight from the flange and diameter for us? Ciao, Marco Edited October 6 by Z320 Quote
rcreweread Posted October 6 Report Posted October 6 Doug (?) - If it turns out you have got one of the “upgrade downgrades” pumps and want to replace it, I do have a small stock of proper EP Services reconditioned pumps which I am happy to sell on an outright basis - PM if interested. Cheers Rich C-R Quote
58TR3-Doug Posted October 7 Author Report Posted October 7 19 hours ago, Z320 said: Hi Doug, please show us the 5 vanes impeller and measure its hight from the flange and diameter for us? Ciao, Marco so measuring each flute to the same location on the flange I get an average of 21.52mm w/ a stnd dev of 0.119 and the diameter is a consistent 68.91mm. Does that ring right Marco? The pully is on the original 4 vane, small nutted pump at the moment but I'll pull photos if I can later. Moss staff were great and pulled a few of their 5 vane pumps off the shelf and mated with their new pulleys and found no issue so I'm leaning toward just buying the pulley to move onward and then I'll rebuild the original pump myself if I can track down the bearings and seals at some point. Quote
58TR3-Doug Posted October 7 Author Report Posted October 7 On 10/5/2026 at 10:08 PM, Don H. said: I threw away one of those “uprated” 5-vane water pumps. I couldn’t tell it was doing anything better, or likely even as well as a properly set up original pump. And the cast iron impeller was corroding in my car. Grr… I’m now running my TR3B’s original pump (with 4-vane bronze impeller) rebuilt by E.P. Services in Wolverhampton, brought over and back to the USA from my trips to Goodwood and the help of my TR friend Julian. Seems to be working perfectly. I’m happy with what they did. No currier friends in my circle and if I can find the parts I'm not to afraid of tackling doing the rebuild myself although I'll have to brush up my solder skills 😅 Quote
Z320 Posted October 7 Report Posted October 7 Hi Doug, this impeller look OK, as usual the vanes shorter than original (less power?). The diameter is correct, the height could be half a millimeter more for a smaller gap to the housing. But it is not basicly wrong, like the impeller from a friends TR, which had a fanthasy shape. Not knowing this he was convinced about the improved pump for years, until the head gasket failed in a heat collapse. IMO these pumps are more „“I want for my good feeling“ and not „the engine needs it“. The original pumps are „pretty easy“, if you DON‘T work like shown at the workshop manual. There is a post anywhere how I did it several times. Don‘t try to pull the bronze impeller off the shaft! Quote
Z320 Posted October 7 Report Posted October 7 I started with a stupid question, knowing nothing Quote
Ian Vincent Posted October 7 Report Posted October 7 I Rebuilt my pump using a stainless steel shaft. I had difficulty finding bearings the same size as the original ones so I increased diameter of the shaft where the bearings sit. I got the idea from a long time Canadian contributor to this forum called Don who died a few years ago. If you would like a copy of the sketch of the shaft that Don provided me with, pls send me a pm. Rgds Ian Quote
Z320 Posted October 7 Report Posted October 7 (edited) The correct bearing is called 6203-16, knowing this it is no problem to buy two of them at ebay at the moment another offer Edited October 7 by Z320 Quote
Nigel C Posted October 7 Report Posted October 7 On 10/6/2026 at 10:25 AM, rcreweread said: Doug (?) - If it turns out you have got one of the “upgrade downgrades” pumps and want to replace it, I do have a small stock of proper EP Services reconditioned pumps which I am happy to sell on an outright basis - PM if interested. Cheers Rich C-R Hi Richard, how much are these reconditioned water pumps with the original impeller? Quote
rcreweread Posted October 7 Report Posted October 7 1 minute ago, Nigel C said: Hi Richard, how much are these reconditioned water pumps with the original impeller? Nigel - they are £95 outright plus postage if required - I also have fully refurbished pulleys at £10, plus a few studs instead of the mounting bolts - can take to the Stoneleigh Restoration show on the 25th of this month if necessary Cheers Rich Quote
iain Posted October 7 Report Posted October 7 26 minutes ago, rcreweread said: Nigel - they are £95 outright plus postage if required - I also have fully refurbished pulleys at £10, plus a few studs instead of the mounting bolts - can take to the Stoneleigh Restoration show on the 25th of this month if necessary Cheers Rich I’ve one of Richards, E P rebuilt pumps, perfect so far. Quote
BlueTR3A-5EKT Posted October 7 Report Posted October 7 I have one ‘just in case’. My car has a Racetorations item fitted. Quote
Nigel C Posted October 7 Report Posted October 7 2 hours ago, rcreweread said: Nigel - they are £95 outright plus postage if required - I also have fully refurbished pulleys at £10, plus a few studs instead of the mounting bolts - can take to the Stoneleigh Restoration show on the 25th of this month if necessary Cheers Rich add it to my tab! Quote
rcreweread Posted October 7 Report Posted October 7 12 minutes ago, Nigel C said: add it to my tab! will do cheers Rich Quote
