John Morrison Posted October 7 Report Posted October 7 Hi all, I have an overheating problem on my TR4. Briefly, and thi ssatrted in a 20 mile tailback haeding from Malvern after Car Fest 2026. For over 20 years I have had an electric fan, on an automatic swith with manual over ride, and no mechanical fan. The system has worked admirably, never an issue, if I was in traffic the fan cut in and pulled the temp guage back to normal. Since Malvern, the fan cuts in where it always did on the guage, but struggles to keep the temp from rising, the guage keeps slowly climbing. Get rolling again and the temp falls back to normal very quickly, leaving me thinking that the rad is fine. So, I sem to have a circulation issue when standing, and I'm looking for suggestions as to what might be at fault, Thermostat? Pump? John. Quote
stuart Posted October 7 Report Posted October 7 4 minutes ago, John Morrison said: Hi all, I have an overheating problem on my TR4. Briefly, and thi ssatrted in a 20 mile tailback haeding from Malvern after Car Fest 2026. For over 20 years I have had an electric fan, on an automatic swith with manual over ride, and no mechanical fan. The system has worked admirably, never an issue, if I was in traffic the fan cut in and pulled the temp guage back to normal. Since Malvern, the fan cuts in where it always did on the guage, but struggles to keep the temp from rising, the guage keeps slowly climbing. Get rolling again and the temp falls back to normal very quickly, leaving me thinking that the rad is fine. So, I sem to have a circulation issue when standing, and I'm looking for suggestions as to what might be at fault, Thermostat? Pump? John. Start with the easy bit first, try the thermostat. When was the last time the water system was flushed through? Stuart. Quote
Andy Moltu Posted October 7 Report Posted October 7 The airflow through the rad is significantly greater when moving than the electric fan can provide so this doesn’t exclude a clogged rad. (any more than it excludes a stat that isn’t fully opening) Quote
MichaelH Posted October 7 Report Posted October 7 This happened to me: run up behind a traffic line and sat - after a while the temp went up and I switched on the electric fan temp continued up. My engine ticks over at about 600 (a bit low I know) I revved slightly as we moved off and the temp came down despite moving only yards Keeping the revs at about 900 the temp came down and stayed down My assessment was that at 600 the water was not getting round through the radiator to get cool but at 900 the water circulated and the fan could cool it MichaelH Quote
Trumpy3 Posted October 7 Report Posted October 7 One problem I have found was 'air re-circulation'. I have a Davies Craig puller fan and electric water pump with no engine driven pump. The water pump controller also controls the fan. After shut down, the fan and pump continues to operate for about two minutes or until the engine temp drops below the temp set point. This prevents after-boil. One day, after driving into my garage on a warm day, I walked around the front of the car, the fan was still running, and noticed that warm air was coming from under the front of the car and recirculating back through the radiator. I did work where we fitted engines to stationary installations and recirculation was always a consideration. One area was the ability of the air to escape the engine bay and baffling to direct the hot air away. In my engine bay, there is a fair bit more than on a standard TR engine bay which can tend to restrict air flow through it. I found that as the air exited the radiator, some traveled back in front of the front cross member and re-entered the radiator. This of course effectively raises the ambient air temp as far as the radiator is concerned. Fitting a simple baffle fixed this. When the car is moving forward, this is not a problem but can be when stationary.The ability of the cooling air to exit the engine bay should always be considered, especially when more items have been fitted above what is standard and can restrict the air flow through the engine bay. Brian Quote
Schnippel Posted October 8 Report Posted October 8 19 hours ago, John Morrison said: Hallo zusammen, ich habe ein Überhitzungsproblem mit meinem TR4. Kurz gesagt, und das begann mit einem 20 Meilen langen Stau von Malvern nach dem Car Fest 2026. Seit über 20 Jahren besitze ich einen elektrischen Ventilator mit automatischer Steuerung und manueller Übersteuerung, keinen mechanischen Ventilator. Das System hat hervorragend funktioniert, es gab nie Probleme; wenn ich im Stau stand, schaltete sich der Lüfter ein und brachte die Temperaturanzeige wieder auf Normalwerte. Seit Malvern schaltet sich der Lüfter an der Stelle ein, an der er es immer auf dem Messgerät getan hat, aber er hat Mühe, den Temperaturanstieg zu verhindern, das Messgerät steigt langsam weiter an. Sobald ich wieder losfahre, sinkt die Temperatur sehr schnell wieder auf Normalwerte, was mich zu der Annahme veranlasst, dass der Kühler in Ordnung ist. Ich habe anscheinend Durchblutungsstörungen beim Stehen und suche nach Hinweisen, woran das liegen könnte. Thermostat? Pumpe? John. Hi, Start with the easy stuff. Make sure there's no air in the cooling system where it shouldn't be. Best regards, Ralf Quote
