R1ceman Posted October 7 Report Posted October 7 Hi, My window frame is in serious need of attention. As you can see in the photos the paint is cracking all over the place and the screen rubber is totally shot. I am thinking of tackling this job myself but I'm unsure of the best way to go about it. Is it a simple job to remove the frame from the car to strip it down and paint or would it be easier to remove the windscreen on the car and then paint the frame in situ? All advice gratefully received. Cheers, Andy Quote
stuart Posted October 7 Report Posted October 7 I suspect you may find there will be a fair bit of rot in the bottom corners that would need sorting out as thats the usual problem. In which case you would need to remove it to sort it out properly, You`ll soon tell if you remove the screen first while the frame is still on the car and look at the bottom corners where the glass sits and then make your mind up. Stuart. Quote
RogerH Posted October 7 Report Posted October 7 (edited) Hi Andy If it was me, I would remove the glass with the frame still attached to the body. It will help to hold thigs still while you struggle to gett he glass out. It may be worth soucing the rubber before you start from MOSS ( as this one fits) and its infill silver beading. I have cut the rubber off as it will be scrap anyway. This will save the glass from cracking as you attack it. AS mentioned above the two bottom corners are the masin areas of concern. Paint strip/grit blast remove the paint to see what is actually going on. If you need to replace any metal due to corrosion you will have to make these parts yourself as nothing is available that fits of the shelf. The outside is easy enough to cut and replace. The underside is very awkward - but do-able. If you can dunk the whole of the bottom rail into a trough of rust remover (BiltHamber DeOxC work well) then give it 48Hrs in thr soup. Coat the inside with Bond-A-Rust primer and a decent top coat. Perhaps introduce a drain path (1/4" hole) in the bottom corners. Metal can be welded into position or possibly use braze or silver solder Or if the rust is serious then you could look for a decent replacement - £400 - £500 Good luck Roger Edited October 7 by RogerH Quote
R1ceman Posted October 7 Author Report Posted October 7 Thanks Stuart and Roger for your advice. I will do as you say and remove the windscreen first and investigate the state of it. One question, you advise me to source a new rubber from Moss, how can I tell if it is a Moss rubber now that they have joined with Rimmers? Quote
stuart Posted October 7 Report Posted October 7 1 hour ago, R1ceman said: Thanks Stuart and Roger for your advice. I will do as you say and remove the windscreen first and investigate the state of it. One question, you advise me to source a new rubber from Moss, how can I tell if it is a Moss rubber now that they have joined with Rimmers? Sadly its a bit pot luck now as to what your going to get. Moss one fits and the Rimmer one is too tight and will pull away from the frame when fitted, Im not sure if you could tell by the packaging when it lands if its still got Moss style labelling or not. Stuart. Quote
R1ceman Posted October 7 Author Report Posted October 7 (edited) Ok, following on from the advice given, I have ordered the following parts to ensure I have all the bits in place before I start. I thought I would replace the windscreen seeing that it was on offer and my current one has 2 chips conveniently covered by 2 stickers. Is there anything else I need to consider? Cheers, Andy Edited October 7 by R1ceman Quote
stuart Posted October 7 Report Posted October 7 That should do it, I would say you`ll probably find the packing pieces still there from original, theyre only bits of grey cardboard anyway. Do you still have the original inner finishers (Black plastic) that go round the inside? Stuart. Quote
R1ceman Posted October 7 Author Report Posted October 7 10 minutes ago, stuart said: That should do it, I would say you`ll probably find the packing pieces still there from original, theyre only bits of grey cardboard anyway. Do you still have the original inner finishers (Black plastic) that go round the inside? Stuart. No I don't have the inner finishers, what I have is pretty tatty and could do with replacing as well. I'm not sure what to do about that really. Andy Quote
had17462 Posted October 7 Report Posted October 7 Hi, if your screen is beyond repair I have a nice one available Quote
PodOne Posted October 8 Report Posted October 8 Windscreen seems also to be a bit variable. I bought a Triple X thinking it would be a good fit from Moss and it was the wrong shape in the corners so I returned it. In the end I got a cheap Chinese one for £80 and guess what it went straight in no problems! Quote
Andy Moltu Posted October 8 Report Posted October 8 Screen out before removing the frame. Painting it in situ will always be a compromise and may well miss rust that is hidden on the underside. Then you can make sure all surfaces are repaired if required clean and painted properly so no overspray on the seals. Quote
stuart Posted October 8 Report Posted October 8 17 hours ago, R1ceman said: No I don't have the inner finishers, what I have is pretty tatty and could do with replacing as well. I'm not sure what to do about that really. Andy The finisher kit is good as its all moulded to suit, you do need good glue to hold it in as the edges go over the lip where the screen goes so you dont want it pulling off as you pull the screen in. Or you could do it on the cheap with a thin black vinyl, it does finish it off etter inside if you have something, I know its hardly visible but Ive seen a few without and its glarinly obvious then. Glue' https://www.woolies-trim.co.uk/p-1263-heat-resistant-adhesive Trim; https://www.moss-europe.co.uk/finisher-set-windscreen-frame-black-gac6029x Stuart. Quote
R1ceman Posted October 8 Author Report Posted October 8 7 hours ago, stuart said: The finisher kit is good as its all moulded to suit, you do need good glue to hold it in as the edges go over the lip where the screen goes so you dont want it pulling off as you pull the screen in. Or you could do it on the cheap with a thin black vinyl, it does finish it off etter inside if you have something, I know its hardly visible but Ive seen a few without and its glarinly obvious then. Glue' https://www.woolies-trim.co.uk/p-1263-heat-resistant-adhesive Trim; https://www.moss-europe.co.uk/finisher-set-windscreen-frame-black-gac6029x Stuart. Thanks Stuart, More things to consider. I may hold off on the finisher for a while since the Mrs has just confronted me about a £540 radiator repair bill from the local rad specialist today plus the £280 from Moss yesterday. It looks as though I currently have a vinyl finisher which may or may not be redeemable. I'll cross that bridge later. First thing is to fit my radiator and then remove the windscreen and see what I discover. Andy Quote
R1ceman Posted October 9 Author Report Posted October 9 Windscreen plus ancillaries arrived today from Moss. I must say it was very well packaged., it could have fallen off the back of a truck and survived. Although the labeling makes me wonder if it came from Moss or Rimmer. Quote
stuart Posted October 9 Report Posted October 9 17 minutes ago, R1ceman said: Windscreen plus ancillaries arrived today from Moss. I must say it was very well packaged., it could have fallen off the back of a truck and survived. Although the labeling makes me wonder if it came from Moss or Rimmer. Yes I had a screen turn up yesterday in a box that would double as a small flat and was also Rimmer labelled though I suspect as its all coming from their place now theyre the only labels they have, the tag on the screen rubbers changed a while ago before the amalgamation so that may well be a Moss one, you`ll soon tell with the fit. Stuart. Quote
R1ceman Posted October 9 Author Report Posted October 9 Thanks Stuart. Fingers crossed it will be OK. Maybe I can try it for size once I get the windscreen out. Andy Quote
stuart Posted October 9 Report Posted October 9 8 minutes ago, R1ceman said: Thanks Stuart. Fingers crossed it will be OK. Maybe I can try it for size once I get the windscreen out. Andy IIRC the Rimmer one is a bit thinner where it sits on the outside of the frame. Stuart. Quote
Jeff Cotter Posted October 9 Report Posted October 9 Hi All im reading all the comments with great interest. I am in the throws of replacing the rear surrey frame glass on my TR4a, The rubber seal has gone on but has ripples in it on the inside top corners and it sits away from the glass on two lower corners. in one location front ns corner edge if I push the seal down to the bodywork it reveals the glass edge at the top, if I go the other way to cover the glass I can get a screwdriver between the seal and the body work. With an unsatisfied feeling I progressed to the (Chrome), trim which is actually just silver coloured tape. It will just not sit in. It will on the straights but on the corners it just wants to jump out. Very frustrating . I purchased from Moss/Rimmer several months ago. If there are any advisories out there then I would be very appreciative , and if there is a recognised best product out there I would be also v interested. PS. the tape on the chrome trim lifts away where it navigates a bend on the frame. cheers Jeff... Quote
Jeff Cotter Posted October 9 Report Posted October 9 (edited) Ive just purchased rear screen seal and trim from these guys I will let you know on the quality...... 🙂 https://coh-baines.co.uk/pages/rubber-seals-for-triumph Edited October 9 by Jeff Cotter Quote
stuart Posted October 9 Report Posted October 9 2 hours ago, Jeff Cotter said: Hi All im reading all the comments with great interest. I am in the throws of replacing the rear surrey frame glass on my TR4a, The rubber seal has gone on but has ripples in it on the inside top corners and it sits away from the glass on two lower corners. in one location front ns corner edge if I push the seal down to the bodywork it reveals the glass edge at the top, if I go the other way to cover the glass I can get a screwdriver between the seal and the body work. With an unsatisfied feeling I progressed to the (Chrome), trim which is actually just silver coloured tape. It will just not sit in. It will on the straights but on the corners it just wants to jump out. Very frustrating . I purchased from Moss/Rimmer several months ago. If there are any advisories out there then I would be very appreciative , and if there is a recognised best product out there I would be also v interested. PS. the tape on the chrome trim lifts away where it navigates a bend on the frame. cheers Jeff... By the sound of it they didnt supply you with a proper Moss rear rubber as they are a good fit, they are longer than you would think necessary for a reason so the rubber fits right down into the lower corners and doesnt leave a gap as you have. The finisher strip is actually a "T" shaped plastic chrome effect and certainly not a tape as you have described and will sit into the groove in the rubber. I dont know how the Baines one will fit but I can tell you for certain if it only just fits around the window with no spare then you`ll end up with the same problem Stuart. Quote
sonsoldcar Posted October 10 Report Posted October 10 Might sound stupid but have you fitted it inside out.I did this with a classic mini screen with much the same results.Steve.. Quote
R1ceman Posted October 14 Author Report Posted October 14 Update. Windscreen removed and it looks pretty good, no evidence of rot. Should I go ahead and remove the frame or leave it as it is to paint? Andy Quote
RogerH Posted October 14 Report Posted October 14 Hi Andy, looking good so far. You now need to remove the frame from the car and see the underside of those two corners Roger Quote
R1ceman Posted October 14 Author Report Posted October 14 3 minutes ago, RogerH said: Hi Andy, looking good so far. You now need to remove the frame from the car and see the underside of those two corners Roger Cheers Roger, I will give it a go 👍 Andy Quote
R1ceman Posted October 15 Author Report Posted October 15 (edited) Do these bolts need to come out? I've undone all the others and it feels pretty solid still. Update, I have removed them and it has given me some movement. Drivers side will raise but nearside isn't playing. Any suggestions other than a mallet? Andy Edited October 15 by R1ceman Quote
