On the inside of the car just below the screw that you show above there are two more screws that need loosening.
There is also a nut on the end of the frame spigot.
Thanks Roger,
I'll try and find those screws although the drivers side is completely free.
Andy
Well that wasn't easy, 2 sockets dropped behind the trim panel in the process of removing the screw holding the tunnel in place but I got it off in the end. The frame still won't move so I am assuming that it is rusted in place. Sprayed some penetrating fluid in there hoping that it will work its magic.
It's dark now,20261015_190124.thumb.jpg.4478c5a422f72d60839a13f6abb577aa.jpg so I have put it in the garage and will go again tomorrow.
They are usually stuck pretty solid, especially if theyve never been off, you need to leave the one bolt that holds the bracket to the side of the bulkhead in tight and remove the one that clamps the tube then with a big screwdriver prise the clamp apart a little . The frame needs to come up straight or it will continually jam. Its a stand in the car and pull up job. Presumably youve removed the three across the dash top?
Thanks Stuart.
Yes I have removed the bolts on the dash top. I just need to prise the clamp apart. I think I may need to remove the glove box in order to get access to it. Hopefully the penetrating oil I put on last night will help.
Andy
On 10/9/2026 at 3:27 PM, stuart said:
By the sound of it they didnt supply you with a proper Moss rear rubber as they are a good fit, they are longer than you would think necessary for a reason so the rubber fits right down into the lower corners and doesnt leave a gap as you have. The finisher strip is actually a "T" shaped plastic chrome effect and certainly not a tape as you have described and will sit into the groove in the rubber. I dont know how the Baines one will fit but I can tell you for certain if it only just fits around the window with no spare then you`ll end up with the same problem
Hi Stuart thanks for your response.... The tape I suggested sits on the plastic T strip. I ll try the Baines and see if it is better....thnks again..
Finally got it out. A lot of wd40 a block of wood and a rubber mallet did the trick. It didn't take much to free it, just a couple of wacks 😉20261016_144446.thumb.jpg.3deaae5e8e4ba2a6d9b61664cc756c23.jpg
57 minutes ago, R1ceman said:
Cleaning  up has revealed quite a few holes and areas filled with body filler. Mmm20261016_153106.thumb.jpg.5359776ea5049f242f1b58d6e4376783.jpg20261016_153054.thumb.jpg.8475e841919c209a77d095f422c4b934.jpg
Thats actually pretty good compared to a lot Ive seen.
1 hour ago, RogerH said:
Hi Andy
if you can get it gently grit blasted it will look a little better.
Hi Roger,
Yes I am looking for someone local who can blast it for me. There is quite a lot of body filler present which is a worry.
Andy
Mine may not look so good once it's been blasted.
Andy
I've been following this thread with interest, because I'm also considering replacing my old Triplex windscreen, as it's quite badly pitted and scratched, making driving difficult when the sun is low in the sky.
Can anyone comment on the quality of this Moss clear laminated windscreen, ref. 906707?
I'd be particularly interested in its optical quality and fit compared with the Pilkington/Triplex alternative, ref. 906707OE, which costs around 4 times as much.
Many thanks,
Francis
I've used the clear and the TT version a number of times. The last replacement was about three years ago.
They all fitted very well.  That was with the MOSS rubber seal.
Hi Roger,
Thanks for the feedback.
I've ordered one of these Moss windscreens, along with the rubber seal and trim, and hope to get it fitted during the winter lay-up. Let's see how it goes!
Francis
Hi Francis,
In the screen rubber seal there is a 'chrome' effect infill.
The usual method of fitting the seal is to fit the seal to the glass, then install the 'chrome' infill, then fit all this to the frame.
However the infill does make the process a little more difficult.
I have fitted the glass/seal to the frame without the infill and found it much easier.
However, the infill becomes a serious hurdle. It could take another 1 Hour+ to install the infill.
Try the usual way first. it will work.
Hi Andy
once the bolts that you can see have been removed you need to look under the dash corners and see how hard the small ‘triangular’ brackets are clamping the screen surround posts - that’s what’s holding it down hard. Prise those apart and they will come free, allowing the posts to rise out of the holes on the bulkhead.
It’s also worth making sure that you have undone all three of the small retainer plates and bolts just behind the screen - one middle, one either end. Those hold the bottom rail onto the front bulkhead.
The surround will still be gripped by the rubber seal, but if you wiggle it all gently when everything is undone it should come away. If you can leave the seal in place as they are difficult to seat and help to locate the screen surround when you put it back on.
Regards
Tony
Wow that took a few days to appear !!!
Update
After a few days taking the paint off it has revealed a lot of filler which you should be able to see in the photos.
What are your thoughts?  Should I remove the filler ang have it all welded up or leave it and just have the minor bits welded?
I'm thinking that if I remove the filler the frame may collapse 😕
Andy
20261029_134950.thumb.jpg.70803c2a9697ab08032367549316b020.jpg20261029_134943.thumb.jpg.c79a47aa89568219babdcc57db58fefe.jpg20261029_134950.thumb.jpg.70803c2a9697ab08032367549316b020.jpg20261029_134925.thumb.jpg.3cd9a85c8b56123808da0bb28ca0d179.jpg20261029_134901.thumb.jpg.aca69d3a0e00ce3acc61453597196e3c.jpg20261029_134853.thumb.jpg.bda9cab520fd728aee9d7044bbcb241d.jpg
Strip it out and repair it properly else its only going to come back to bite you, interesting repair on the seal channel!
Stuart
Stuart
Thanks Stuart. Yes indeed, if only the had managed to line them up 😫
I'm  thinking of using a dremel to strip the filler, what do you recon?
Andy
By the looks of it, chip it out with a sharp screwdriver and then get in with a pointy rotary wire brush to get it as clean as possible then rust treat with Jenolite or similar and then repair.
Thanks Stuart, lucky for me I just received a pack of rotary wire brushes the other day off Temu. I hope they are up to the task.
Andy
Hi Andy
the big round bar (x2) should not fall out as it is brazed up its length to the frame.
If you remove the filler ( I woud remove it)  you will just see a deep hole.
Replace metal where ever you can. If you replace the metral around the big bar  then try and get thyat brazed. Weld is so difficult to clean u afterwards.
16 minutes ago, RogerH said:
Hi Andy
Thanks Roger, that's good to know.
I will be taking it to an old boy who has a workshop just out of town. He is very good and hopefully he will be able to sort it for me. In the meantime I'll do as much prep as I can to make the job easier for him.
Andy
