FBM Posted October 29 Report Posted October 29 On 10/28/2026 at 9:25 AM, RogerH said: Hi Francis, In the screen rubber seal there is a 'chrome' effect infill. The usual method of fitting the seal is to fit the seal to the glass, then install the 'chrome' infill, then fit all this to the frame. However the infill does make the process a little more difficult. I have fitted the glass/seal to the frame without the infill and found it much easier. However, the infill becomes a serious hurdle. It could take another 1 Hour+ to install the infill. Try the usual way first. it will work. Roger Hi Roger, Thanks for the useful tips. At the moment, I'm still at ground level, trying to work out the best way to remove the old windscreen. Any tips? Thanks again, Francis Quote
stuart Posted October 30 Report Posted October 30 16 hours ago, FBM said: Hi Roger, Thanks for the useful tips. At the moment, I'm still at ground level, trying to work out the best way to remove the old windscreen. Any tips? Thanks again, Francis Sharp Stanley knife to cut round the rubber to the side of the trim insert and the carefully push the screen out from the inside is the usual way as you should always renew the rubber. Stuart. Quote
R1ceman Posted October 30 Author Report Posted October 30 Update. All filler removed, wire brushed and treated with Bilt Hamber Hydrate-80. I think its ready to go to the welder on Monday. Hopefully he will be able to patch it up. Thanks to everyone for your help with this. Andy Quote
stuart Posted October 30 Report Posted October 30 32 minutes ago, R1ceman said: Update. All filler removed, wire brushed and treated with Bilt Hamber Hydrate-80. I think its ready to go to the welder on Monday. Hopefully he will be able to patch it up. Thanks to everyone for your help with this. Andy Thats not too bad, Ive had to repair far worse to the extent of a loose tube even. Stuart. Quote
R1ceman Posted October 30 Author Report Posted October 30 Thanks Stuart, that's comforting to know. I'll find out on Monday if the welder will take it on 🤞 Andy Quote
FBM Posted November 2 Report Posted November 2 On 10/30/2026 at 10:45 AM, stuart said: Sharp Stanley knife to cut round the rubber to the side of the trim insert and the carefully push the screen out from the inside is the usual way as you should always renew the rubber. Stuart. Hi Stuart, Should I try to remove the original chrome trim with a view to reusing it, or would that just be a waste of time? I had a quick look, and everything seems pretty firmly in place. I haven't tried cutting anything yet, as the weather is still quite warm and sunny over here, so I've decided to put this project off until the rainier days arrive! From what I understand, I should cut along the upper outer lip of the seal, all the way down to the glass, removing as much rubber as possible to free the edge of the windscreen from the channel before pushing it out. Is that correct? Thanks, Francis Quote
FBM Posted November 2 Report Posted November 2 On 10/30/2026 at 2:52 PM, R1ceman said: Thanks Stuart, that's comforting to know. I'll find out on Monday if the welder will take it on 🤞 Andy Hi Andy, Just wanted to thank you for starting this thread, and for putting up with me hijacking it with all my windscreen questions. I wasn't planning on replacing mine just yet, but seeing the one you'd ordered got me thinking, and I ended up ordering the same one and bringing the job forward. Hope everything goes well with yours! Cheers, Francis Quote
stuart Posted November 4 Report Posted November 4 On 11/2/2026 at 11:33 PM, FBM said: Hi Stuart, Should I try to remove the original chrome trim with a view to reusing it, or would that just be a waste of time? I had a quick look, and everything seems pretty firmly in place. I haven't tried cutting anything yet, as the weather is still quite warm and sunny over here, so I've decided to put this project off until the rainier days arrive! From what I understand, I should cut along the upper outer lip of the seal, all the way down to the glass, removing as much rubber as possible to free the edge of the windscreen from the channel before pushing it out. Is that correct? Thanks, Francis TBH I would fit a new one as theyve usually shrunk slightly over the years and in all probability wont go back in the same so best to fit new. I usually cut round just outside of the finishing strip and then push the screen out from the inside with someone outside to help. Stuart. Quote
RogerH Posted November 4 Report Posted November 4 The Chrome in-fill tends to go quite brittle over the years. So you may well end up breaking it when trying to remove it. Roger Quote
R1ceman Posted Tuesday at 02:03 PM Author Report Posted Tuesday at 02:03 PM On 11/2/2026 at 11:44 PM, FBM said: Hi Andy, Just wanted to thank you for starting this thread, and for putting up with me hijacking it with all my windscreen questions. I wasn't planning on replacing mine just yet, but seeing the one you'd ordered got me thinking, and I ended up ordering the same one and bringing the job forward. Hope everything goes well with yours! Cheers, Francis Hi Francis, No worries mate, every little helps 👍 Andy Quote
R1ceman Posted Tuesday at 02:09 PM Author Report Posted Tuesday at 02:09 PM Update: Just picked my window frame from the welder. It doesn't look pretty but it feels solid. Next step is painting. I know of a chap who may take it on. I'll take my hard top with me for a paint match. Andy Quote
RogerH Posted Tuesday at 02:50 PM Report Posted Tuesday at 02:50 PM Hi Andy, that looks OK. If you can get paint inside the frame that would be good - but it is A VERY messy process. Roger Quote
R1ceman Posted Tuesday at 02:59 PM Author Report Posted Tuesday at 02:59 PM (edited) Hi Roger, I was thinking of spraying the inside with some Bilt Hamber Dynax-UB anti corrosion wax. On further investigation. BH do a cavity wax called Dynax s50 which looks more appropriate for the task. It comes with a 600mm tube/ lance which will be useful when spraying it into those hard to reach areas. Andy Edited Tuesday at 03:24 PM by R1ceman Quote
stuart Posted Tuesday at 03:52 PM Report Posted Tuesday at 03:52 PM 52 minutes ago, R1ceman said: Hi Roger, I was thinking of spraying the inside with some Bilt Hamber Dynax-UB anti corrosion wax. On further investigation. BH do a cavity wax called Dynax s50 which looks more appropriate for the task. It comes with a 600mm tube/ lance which will be useful when spraying it into those hard to reach areas. Andy As long as you dont do it till after its painted 😉 Stuart. Quote
R1ceman Posted Tuesday at 04:20 PM Author Report Posted Tuesday at 04:20 PM 27 minutes ago, stuart said: As long as you dont do it till after its painted 😉 Stuart. 👍 Quote
R1ceman Posted Wednesday at 12:57 PM Author Report Posted Wednesday at 12:57 PM Painter has quoted me £320 to do the frame, plus I supply the red paint (250ml). Is that about right? Andy Quote
TR NIALL Posted Wednesday at 01:36 PM Report Posted Wednesday at 01:36 PM 38 minutes ago, R1ceman said: Painter has quoted me £320 to do the frame, plus I supply the red paint (250ml). Is that about right? Andy For that money I’d be spraying it myself with Rattle Cans. Quote
stuart Posted Wednesday at 02:32 PM Report Posted Wednesday at 02:32 PM 1 hour ago, R1ceman said: Painter has quoted me £320 to do the frame, plus I supply the red paint (250ml). Is that about right? Andy That does seem a lot as your supplying the paint. Stuart. Quote
John Morrison Posted Wednesday at 02:39 PM Report Posted Wednesday at 02:39 PM I think that’s a B lot to b pay for that, it’s b pretty straightforward and really very b little surface. John Quote
R1ceman Posted Wednesday at 02:51 PM Author Report Posted Wednesday at 02:51 PM Thanks everyone for your thoughts. I think I will shop around for a better deal. Meanwhile I will fit it to the car to see how it fits. Andy Quote
R1ceman Posted 16 hours ago Author Report Posted 16 hours ago Frame seems to go in a lot easier than when it came out. A couple of questions though. Should there be holes in the bottom of the frame where the holes are on the rubber gasket? Photo 1 In photo 2 is thus acceptable or should that be ground back? Cheers, Andy Quote
RogerH Posted 15 hours ago Report Posted 15 hours ago (edited) Hi Andy you would think that a drain hole woiuld be handy but there isn't one in the top skin of the plenum. Make sure that the screen seal fits OK before trying to fit the glass. Roger Edited 10 hours ago by RogerH Quote
sonsoldcar Posted 11 hours ago Report Posted 11 hours ago If photo two is the windscreen rubber flange then it would probably be best to have it repaired.Just my thoughts as it will only get worse and you are fairly deep into it. Quote
R1ceman Posted 10 hours ago Author Report Posted 10 hours ago 5 hours ago, RogerH said: Hi Andy you would think that a drain hole woiuld be handy but there isn't one it the top skin of the plenum. Make sure that the screen seal fits OK befpre trying to fit the glass. Roger Thanks Roger, noted. Andy Quote
R1ceman Posted 10 hours ago Author Report Posted 10 hours ago 34 minutes ago, sonsoldcar said: If photo two is the windscreen rubber flange then it would probably be best to have it repaired.Just my thoughts as it will only get worse and you are fairly deep into it. Fair point, it is as you say. I will sort it. Andy Quote
