Ransomes256 Posted October 9 Report Posted October 9 How do you determin how much grease to pump into the hub bearings on a solid axle? Quote
stuart Posted October 9 Report Posted October 9 11 minutes ago, Ransomes256 said: How do you determin how much grease to pump into the hub bearings on a solid axle? You dont, a single stroke every couple of years would be plenty, Ive seen too many where the grease has squeezed through the seal and gone all over the shoes. Stuart. Quote
Ransomes256 Posted October 9 Author Report Posted October 9 Thank you that is what I thought but just wanted some confirmation. Neil Quote
John Mellor Posted October 21 Report Posted October 21 Will the old grease harden and affect lubrication. With ball joints and running one can see the old grease being extruded Quote
John Mellor Posted October 21 Report Posted October 21 Running = trunnions dammed predictive text!!! Quote
stuart Posted October 21 Report Posted October 21 1 hour ago, John Mellor said: Will the old grease harden and affect lubrication. With ball joints and running one can see the old grease being extruded No, modern grease doesnt tend to do that anyway. Stuart. Quote
RogerH Posted October 22 Report Posted October 22 39 minutes ago, MichaelH said: And Trunnions need oil not grease MichaelH But the trunnions leak unless you seal them after purchase. Not an easy job for many folk. Roger Quote
jerrytr5 Posted October 22 Report Posted October 22 Come on Roger, even I can use araldite🙂 Jerry Quote
RogerH Posted October 22 Report Posted October 22 Hi Jerry that is the easy way. I was thinking at the very least plumbers solder. Possibly some fancy TiG brazing technique. Anyway I really do prefer lithium grease. Roger Quote
Lebro Posted October 22 Report Posted October 22 I soft soldered mine, was ok to start but one now squirts grease out when trying to pump more in. Wish I had silver soldered it. Will be taking apart this winter to re-do. Bob Quote
stuart Posted October 23 Report Posted October 23 18 hours ago, Lebro said: I soft soldered mine, was ok to start but one now squirts grease out when trying to pump more in. Wish I had silver soldered it. Will be taking apart this winter to re-do. Bob You`ll probably need to boil them up to get all the grease out to successfully re-solder. Stuart. Quote
John Mellor Posted October 24 Report Posted October 24 Well I've been using grease for 5 years without problems. Am I headed for trouble? Quote
Chris Hubball Posted October 24 Report Posted October 24 I have been using grease for over 50 years with no problems, just grease them every year as part of my annual service routine. Cheers Chris Quote
