John Dyson Posted October 10 Report Posted October 10 Have just fitted a spin off oil filter kit to my TR4A 1967 and did fit the o ring , which fits in the centre of the aluminium adapter (it did not seem to fit properly ), fitted the sealing ring ok started the engine and oil pressure reached 70 psi cold and 50ish when hot. Does anyone know what the o ring does and is it a problem leaving it out . Up to now no leaks detected , but only ran the car till warm then switched off. Any advice greatfuly received . Quote
John Morrison Posted October 10 Report Posted October 10 John I have re-titled your post to better target replies John Quote
Lebro Posted October 10 Report Posted October 10 This may help explain things: Final draft Article on Improving spin-on oil filter adaptors 240618.pdf Bob Quote
John Dyson Posted October 11 Author Report Posted October 11 Thanks for the article , do you think it will hurt leaving the o ring out until i next change the oil and filter when i can look at it again , its not leaking at the moment. Quote
BlueTR3A-5EKT Posted October 11 Report Posted October 11 Does that inner seal not stop oil returning to the inlet side of the filter rather than sending it all into the main oil gallery? Quote
