Ecosse Posted October 10 Report Posted October 10 Does anyone have any experience of 123 Distributors on their TR in general, or on a TR7 specifically. Is there any noticeable difference in performance and how easy, or difficult, is it to set-up and find the optimum configuration. Thanks for any information. Cliff Quote
harlequin Posted October 11 Report Posted October 11 I have the old type with pre programed advance curves on my TR6. It works really well giving a smooth running engine, instant starting and low maintenance. My 123 is really for a Jaguar so I had to do a bit of experimenting with the curve selection to find the best, and ofcourse I nolonger have a mechanical tachometer. Replacement rotor arms and caps are Boru (I think that's how it's spelt?) which are easy to get as Mercedes and others use them. I do have the old Lucas distributor in the boot for just incase but should my 123 which is now about 20 years old go wrong I'd definitely replace it with one of the newer type of 123. Hope this helps George Quote
pinky Posted October 11 Report Posted October 11 I have used one one for over 10 years no problem, did have the wrong coil fitted to start with, kept burning the caps out, new coil no problem Quote
BlueTR3A-5EKT Posted October 11 Report Posted October 11 21 hours ago, Ecosse said: Does anyone have any experience of 123 Distributors on their TR in general, or on a TR7 specifically. Is there any noticeable difference in performance and how easy, or difficult, is it to set-up and find the optimum configuration. Thanks for any information. Cliff Is there enough ‘vertical real estate’ for the proposed distributor with cap and leads to fit? Sprint engines need a distributor cap with side entry leads. Is that the case with TR7? Quote
Black Forest TR3A Posted October 11 Report Posted October 11 2 hours ago, harlequin said: Replacement rotor arms and caps are Boru (I think that's how it's spelt?). It's BERU 😉 Good quality stuff, like Bosch (whose parts also fit for the 123). Quote
Waldi Posted October 11 Report Posted October 11 What solution have you used for the rev counter? I want to convert to a 123 dizzy too but like to modify my own rev counter if possible. Waldi Quote
harlequin Posted October 11 Report Posted October 11 7 hours ago, BlueTR3A-5EKT said: Is there enough ‘vertical real estate’ for the proposed distributor with cap and leads to fit? Sprint engines need a distributor cap with side entry leads. Is that the case with TR7? Side entry caps are available but at a price G Quote
Drewmotty Posted October 11 Report Posted October 11 Red 123 caps are Bosch. Black ones are Ducellier. Both are available as top or side entry. Quote
harlequin Posted October 11 Report Posted October 11 2 minutes ago, Waldi said: What solution have you used for the rev counter? I want to convert to a 123 dizzy too but like to modify my own rev counter if possible. Waldi I found a couple of tachometers from an XJ6 at a local scrap yard for £5 each, they are plug and go but the warning lights are elsewhere on the Jag and the needle is different. I have fitted one in the car and intend to use the other to convert a TR tachometer although a few years have slipped by, but it's on the list. My car is a CF so there are a couple of extra warning lights for random things like seatbelt warning lights so I've used one for the indicator repeater. George Quote
harlequin Posted October 11 Report Posted October 11 2 minutes ago, Drewmotty said: Red 123 caps are Bosch. Black ones are Ducellier. Both are available as top or side entry. Beru are a fetching shade of brown Quote
Drewmotty Posted October 11 Report Posted October 11 38 minutes ago, Waldi said: What solution have you used for the rev counter? I want to convert to a 123 dizzy too but like to modify my own rev counter if possible. Waldi Issue 13 here Waldi: https://www.dropbox.com/sh/gfmi37kp2i2m7hi/AAASxwvmDIEsBE20f9BgebfSa?dl=0 Quote
AndyR100 Posted October 11 Report Posted October 11 I have a 123 Tune+ on my 4, not had any issues in the 6 years since fitted. I started with the std. curve and have simply tweaked it over time. Set up was straightforward, you just need to remember that all values are in addition to any static timing that you may (or may not) choose to set and have a quick read up to ensure you calculate the vacuum advance correctly. …….. Andy Quote
harlequin Posted October 11 Report Posted October 11 (edited) 1 hour ago, Waldi said: What solution have you used for the rev counter? I want to convert to a 123 dizzy too but like to modify my own rev counter if possible. Waldi Waldi This is the Jag rev counter in my car, as you can see it's a bit different from the original (and upside down) G Edited October 11 by harlequin Quote
Waldi Posted October 11 Report Posted October 11 Thank you George and Andrew, next week is a spares day in Holland, so I hope to find one there. I think there are 2 types: RVC and RVI, do you know if both types could be used? To narrow down my search, are Jaguar S1,2 and 3 items suitable? Apologies if i’m “overasking”. Thanks, Waldi Quote
stuart Posted October 11 Report Posted October 11 Series 3 XJ face is closer to a CR car type or you could use the internals with the TR face Stuart. Quote
harlequin Posted October 11 Report Posted October 11 (edited) 59 minutes ago, Waldi said: Thank you George and Andrew, next week is a spares day in Holland, so I hope to find one there. I think there are 2 types: RVC and RVI, do you know if both types could be used? To narrow down my search, are Jaguar S1,2 and 3 items suitable? Apologies if i’m “overasking”. Thanks, Waldi I've just done an AI search on my photo and it tells me that it's a RVI unit from a Series 1 XJ6. It also goes on to state that RVI (current sensing) are unsuitable for modern systems such as Pertronix or 123 as the pulse is to rapid/clean. This is is weird as mine has worked fine for years, and I've tested the spare one and that works fine as well. Maybe my 20 year old 123 is not as sophisticated as the later models? George Edited October 11 by harlequin Quote
RobH Posted October 11 Report Posted October 11 (edited) You can use either type Waldi. The RVI type tacho has a small loop on the back and the power feed to the ignition coil loops through that so there are two signal input wires. These are polarity-sensitive. The RVC type has a single voltage-sensing wire. This document may help with identification and connections etc. https://triumphclub.co.nz/wp-content/uploads/2025/01/A-gentlemans-guide-to-Smiths-tachometers.pdf Edited October 11 by RobH Quote
pinky Posted October 12 Report Posted October 12 I used speedy cables to covert my mechanical rev counter to electrical, they were really good pink x Quote
Waldi Posted October 12 Report Posted October 12 Thank you George and Rob, I will ask 123 what they recommend as well, a company that can convert my tacho (like JDO/Speedy) in Holland warned me for compatibility-issues. We are now in York (last day) and heading to Hull for the ferry. Once I’m home I will call 123 (they are located near my home town) and ask. I will feed back on here. Best regards, Waldi Quote
Waldi Posted October 14 Report Posted October 14 Today I called 123Ignition, they are based 50 kms from where I live, and had a good conversation with them about electronic tacho's. RVI or RVC? If you want to use an (old) Smiths electronic rev counter (such as from a Jaguar XJ), both RVI and RVC type rev counter can be used, but 123Ignition recommends the RVC type. 123Ignition do not sell a ready-to-fit conversion kit for mechanical tacho's, unfortunately. RVI: In case an RVI type is rev counter is used (which is possible as George indicates), their website provides a guide to re-route the wiring to solve potential issues, see attached document. Note this document is a copy of "Enjoying MG", Okt. 20212. FRee programmable versions: BT or USB-connection? For the programmable versions, both BT and USB are available, but BT is preferred, because of the vulnerable USB connection (oil, dirty hands, USB plug pushed in the wrong way around etc.). Regards, Waldi. Smiths RVI Rev Counter wiring adaption for electronic ignition systems (like 123).pdf Quote
harlequin Posted October 18 Report Posted October 18 On 10/14/2026 at 9:34 AM, Waldi said: Today I called 123Ignition, they are based 50 kms from where I live, and had a good conversation with them about electronic tacho's. RVI or RVC? If you want to use an (old) Smiths electronic rev counter (such as from a Jaguar XJ), both RVI and RVC type rev counter can be used, but 123Ignition recommends the RVC type. 123Ignition do not sell a ready-to-fit conversion kit for mechanical tacho's, unfortunately. RVI: In case an RVI type is rev counter is used (which is possible as George indicates), their website provides a guide to re-route the wiring to solve potential issues, see attached document. Note this document is a copy of "Enjoying MG", Okt. 20212. FRee programmable versions: BT or USB-connection? For the programmable versions, both BT and USB are available, but BT is preferred, because of the vulnerable USB connection (oil, dirty hands, USB plug pushed in the wrong way around etc.). Regards, Waldi. Smiths RVI Rev Counter wiring adaption for electronic ignition systems (like 123).pdf 2.58 MB · 5 downloads Thanks for posting Waldi I shall alter my wiring to suit 123s recommendation George Quote
tim hunt Posted October 18 Report Posted October 18 On 10/11/2026 at 7:51 AM, harlequin said: I have the old type with pre programed advance curves on my TR6. It works really well giving a smooth running engine, instant starting and low maintenance. My 123 is really for a Jaguar so I had to do a bit of experimenting with the curve selection to find the best, and ofcourse I nolonger have a mechanical tachometer. Replacement rotor arms and caps are Boru (I think that's how it's spelt?) which are easy to get as Mercedes and others use them. I do have the old Lucas distributor in the boot for just incase but should my 123 which is now about 20 years old go wrong I'd definitely replace it with one of the newer type of 123. Hope this helps George I also have an early non-tuneable 123, albeit on a TR4A. It was a direct drop in replacement for the Lucas original and the mechanical tachometer works with it. The old Lucas distributor has now been in the boot for over 19 years just in case, but the 123 has proved completely reliable over ~ 75,000 miles. I selected curve number 7, which proved ideal. The car picks up smoothly with no flat spots, will not pink under load when accelerating in top from ~20mph and low speed running is noticeably smoother. Tim Quote
harlequin Posted October 18 Report Posted October 18 1 hour ago, tim hunt said: I also have an early non-tuneable 123, albeit on a TR4A. It was a direct drop in replacement for the Lucas original and the mechanical tachometer works with it. The old Lucas distributor has now been in the boot for over 19 years just in case, but the 123 has proved completely reliable over ~ 75,000 miles. I selected curve number 7, which proved ideal. The car picks up smoothly with no flat spots, will not pink under load when accelerating in top from ~20mph and low speed running is noticeably smoother. Tim Tim The TR6 tachometer drive is slightly different from a 4 cylinder car as the drive is a part of the distributor its self, hence the Jag rev counter. I started using the 123 completely by chance when my Lucas one fell to bits while we were driving down to Andora, this happened right outside a French classic Jaguar dealers shop so I went in to see if he could help and came out with the 123, the only slight issue is it's ment for an E Type so the curves are different from the standard 123. I picked a curve near to the Lucas curve and then started experimenting with acceleration runs between 2 points and checking the final speed. I've been using it for about the same time as you and a similar milage and have to agree about the performance which is first rate George Quote
tim hunt Posted October 18 Report Posted October 18 Yes George I was aware that fitting a 123 to a 6 was not so straightforward, requiring alternative provision for a tacho. Tim Quote
