Smugalug Posted October 10 Report Posted October 10 Hi All Thanks for the replies for the 5 + 6 low compression, watch that space and I will update once the head is off. Anyways, whilst getting the 6 into the garage for the head removal I somehow managed to get the reverse selection of the gearstick stuck (This is the second time this has happened in the last 12 months) Basically the gearstick would not move the selector out of reverse but the gearbox was not actually in reverse. On taking the tunnel off etc and removing the selector mechanism form the gearbox the only thing I could find that is of worry is that the selector gate has play in it compared to the 3rd and 4th gate against the 1st and 2nd gate (if that make sense) i.e. there is not to little gap between the 3rd and 4th and the 1st and 2nd gate but there is a visible gap between the reverse gate and the 1st and 2nd gate . Is this normal ? My concern is that this gate is allowing the selector to jam against the reverse selector fork that moves the lever to move the reverse idler spindle. Is this possible ? Has anyone seen this happen and is there an adjustment for the nut that holds that lever in position ? I may be barking up the wrong tree but maybe someone can enlighten me. I've attached some pictures with the gap open and close in relation to the gate and the selector against the housing. Your advice is gladly received Steve Quote
BlueTR3A-5EKT Posted October 11 Report Posted October 11 The nos top cover assy I have does not have that gap between the gear-lever segments. There is almost zero rotation of the selectors in the housing. Could this be another example of a bent reverse gear selector shaft? Quote
Smugalug Posted October 11 Author Report Posted October 11 Hi Peter That's what I'm suspecting but wanted to see if anyone else has seen this. Are you saying there is little to no gap between the gates? Thankis Steve Quote
BlueTR3A-5EKT Posted October 11 Report Posted October 11 (edited) Maybe 0.010”-gap max. A running clearance. The gaps are parallel too. Edited October 11 by BlueTR3A-5EKT Quote
Smugalug Posted October 13 Author Report Posted October 13 Ok Thank you Peter. Have you seen any threads on how to straighten the rod before I attempt it ? Or should I just replace it. The gap I have is at least a 1 - 1.5mm which cannot be right and the reason the fork is able to move so much. Regards Steve Quote
RogerH Posted October 13 Report Posted October 13 Hi Steve there are no new rods. Any used one may also be ebent. Be careful. You could simply roll it on a flat surface to see where the bow is and then give it a gentle whack with a lump hammer in the right direction. Roger Quote
Smugalug Posted October 19 Author Report Posted October 19 Hi Roger Whack carried out, will monitor but it does seem tighter now and hopefully it will work but as I not sure why it has occurred I can only monitor. Regards Steve Quote
RogerH Posted October 19 Report Posted October 19 Hi Steve it is probably caused by heavy handed gear change into reverse. Lift gear stick and bang it over to the right Roger Quote
stuart Posted October 20 Report Posted October 20 15 hours ago, RogerH said: Hi Steve it is probably caused by heavy handed gear change into reverse. Lift gear stick and bang it over to the right Roger Thats something Im forever telling my customers off for, they just bang the stick over to get reverse instead of lifting, no wonder we come across selector cradles with a big dig where the step is supposed to be. Stuart. Quote
FBM Posted October 22 Report Posted October 22 On 10/20/2026 at 10:59 AM, stuart said: Thats something Im forever telling my customers off for, they just bang the stick over to get reverse instead of lifting, no wonder we come across selector cradles with a big dig where the step is supposed to be. Stuart. On 10/19/2026 at 7:23 PM, RogerH said: Hi Steve it is probably caused by heavy handed gear change into reverse. Lift gear stick and bang it over to the right Roger Hi Stuart and Roger, Thanks for pointing this out! As a fairly new TR6 owner, this is the first time I've heard about lifting the gear lever to engage reverse, but it certainly makes a lot of sense, especially to avoid having to use that extra force when the car is cold. I don't have the car with me at the moment, but I'll definitely give it a try this weekend. I've always engaged reverse in two steps, without any lifting: first moving the lever to the right, then pulling it back. Just to make sure I've got it right, should I lift the lever as I move it to the right from neutral, so it's already above the step when I pull it back, or should I also keep lifting it as I pull it back? Thanks again for the tip! Francis Quote
TR NIALL Posted October 23 Report Posted October 23 6 hours ago, FBM said: Hi Stuart and Roger, Thanks for pointing this out! As a fairly new TR6 owner, this is the first time I've heard about lifting the gear lever to engage reverse, but it certainly makes a lot of sense, especially to avoid having to use that extra force when the car is cold. I don't have the car with me at the moment, but I'll definitely give it a try this weekend. I've always engaged reverse in two steps, without any lifting: first moving the lever to the right, then pulling it back. Just to make sure I've got it right, should I lift the lever as I move it to the right from neutral, so it's already above the step when I pull it back, or should I also keep lifting it as I pull it back? Thanks again for the tip! Francis Lift initially to get it over the step. Quote
RogerH Posted October 23 Report Posted October 23 Hi Francis as mentioned above by Niall - move the gear stick to the right whilst lifting against the spring. Once fully right pull it rearwards, let go and enjoy. There is a baulk to stop you engaging reverse when meaning to go into 4th. The racing boys are very naughty, some of them actually remove this baulk so as to engage reverse quicker. If you try to whack it past the baulk then you may bend the rod. Roger Quote
FBM Posted October 24 Report Posted October 24 (edited) 17 hours ago, TR NIALL said: Lift initially to get it over the step. 15 hours ago, RogerH said: Hi Francis as mentioned above by Niall - move the gear stick to the right whilst lifting against the spring. Once fully right pull it rearwards, let go and enjoy. There is a baulk to stop you engaging reverse when meaning to go into 4th. The racing boys are very naughty, some of them actually remove this baulk so as to engage reverse quicker. If you try to whack it past the baulk then you may bend the rod. Roger Hi Niall and Roger, Thanks for the clarification. I've just been in the garage to try the lifting technique, and compared with my old way of doing it, it went into reverse as smooth as butter. I really appreciate this tip, as the old technique of pushing the selector to the right with some vigour, certainly wasn't very mechanically sympathetic. Thanks again to all our resident experts for sharing their knowledge. Francis Edited October 24 by FBM Quote
PodOne Posted October 26 Report Posted October 26 I’ll second that as well as I was unaware to lift the gear nob to better select reverse with mechanical kindness👍 Quote
RogerH Posted October 26 Report Posted October 26 Hi Folks I have become aware of a different style of reverse selector rod. Where the step/baulk that makes you lift the gearstick to engage, there is a ramp. This ramp allows the bottom of the gear stick to glide into position with very little effort. I can see the benefit (easier to use and no bent rods). But I can also see a disaster. Imagine moving forwards and you intend to engage 3/4th gear and you over run into reverse (if possible) - aaarrrggghhh Could the TR6 gearbox have had this ramp as an upgrade. But sometime after the first few were fitted the stepped selector rod was fitted instead - Hmmmm a mystery. Roger Quote
stuart Posted October 27 Report Posted October 27 16 hours ago, RogerH said: Hi Folks I have become aware of a different style of reverse selector rod. Where the step/baulk that makes you lift the gearstick to engage, there is a ramp. This ramp allows the bottom of the gear stick to glide into position with very little effort. I can see the benefit (easier to use and no bent rods). But I can also see a disaster. Imagine moving forwards and you intend to engage 3/4th gear and you over run into reverse (if possible) - aaarrrggghhh Could the TR6 gearbox have had this ramp as an upgrade. But sometime after the first few were fitted the stepped selector rod was fitted instead - Hmmmm a mystery. Roger There was a similar interesting problem with accidental selection of reverse on the Moss box as fitted to Jaguars of the fifties and very early sixties with non syncro first gear. Reverse on them was over and forward right next to first and it was so easy on cars with slightly worn selectors to get it wrong. You always knew when sitting behind one in traffic when the reversing light suddenly came on so needing a blast on the horn to alert the driver! Stuart. Quote
