Richardtr3a Posted October 11 Report Posted October 11 My TR has been having problems for some time. It overheated on a trip to the local post office and the temp gauge was showing very high level of heat. The ammeter would not move to positive charge. I think that I have made some questions here on this Forum. Yesterday I received an email from Halfords. They supplied a very strong battery a while ago which does not need charging while in my garage. The email suggested that I should check my tyres. This is something that I do monthly. So I was checking the tyres and also looking at the overheating and the dynamo. The radiator took two large kettles of cold water. The fan belt could be adjusted by using a small length of fence timber behind the dynamo which I have only done by hand before. After these home service jobs I went for a 13 mile drive to get some petrol. The temp. gauge did not move past 185 and the the ammeter showed a positive charge even with the headlamps on. It is tempting to try again this morning and I am feeling much more confident and I will wait for the sun to come out. Richard Quote
Hamish Posted October 11 Report Posted October 11 It could be the belt was loose and not driving either the water pump or the alternator. just make sure the belt is now not too tight as the bearings on the pump etc won’t like it. Quote
Richardtr3a Posted October 11 Author Report Posted October 11 Thanks for the advice I am trying to get some movement in the fan belt on the longest length about 3/4 " Richard Quote
Richardtr3a Posted October 11 Author Report Posted October 11 (edited) 8 hours ago, Hamish said: It could be the belt was loose and not driving either the water pump or the alternator. just make sure the belt is now not too tight as the bearings on the pump etc won’t like it. I went for a 29 mile drive today, down to Newhaven, Sussex and back. The roads were quiet and everything was looking very good in the sun. The TR ran very well. I checked the tension on the fan belt when I got home and there was approx 1" on the longest length I think the water pump is benefitting from the new tension Edited October 11 by Richardtr3a spelling Quote
Richardtr3a Posted October 12 Author Report Posted October 12 This morning it is a quiet day at home. I was thinking about the overheating and I measured the kettle . It turns out that I was 6 pints short of water in the radiator in the first place. My TR needs more maintenance in the autumn. I am also looking to clear up the garage and throw away 1/2 empty oil cans. But it is cold today so not now. Richard Quote
RobH Posted October 12 Report Posted October 12 Considering the system only holds around 13 to 14 pints Richard, the thing must have been half empty. Perhaps it threw a lot out when it overheated but it's not good if it has been running like that - is it still losing water ? Quote
harrytr5 Posted October 12 Report Posted October 12 If the rad has a long neck you do not want to fill it up to the top, only just cover the bottom a smidgeon. Regards Harry P.S. are you an ex member of NLG? Quote
Richardtr3a Posted October 24 Author Report Posted October 24 Thanks for the advice. My radiator does not have a pressure cap and the overflow goes to a small expansion container on the inner wing with a 4 lb pressure cap.There is a sign on the side Coolant Level. I can not remember where it came from. Many years ago I used to visit a breakers yard near Worthing , Sussex. So the longneck is always full. I was planning a drive out to get petrol but there is rain again and it is cold here is Sussex. P.S. I am a member of the South Downs Group Quote
BlueTR3A-5EKT Posted October 24 Report Posted October 24 3 hours ago, Richardtr3a said: Thanks for the advice. My radiator does not have a pressure cap and the overflow goes to a small expansion container on the inner wing with a 4 lb pressure cap.There is a sign on the side Coolant Level. I can not remember where it came from. Many years ago I used to visit a breakers yard near Worthing , Sussex. So the longneck is always full. I was planning a drive out to get petrol but there is rain again and it is cold here is Sussex. P.S. I am a member of the South Downs Group That plain rad cap then a remote pressure tank with 4 lb cap is what I have on my car. When the radiator is recored I will go back to standard and not have the separate pressure tank. My logic for that is my brother’s TR works fine that way so I shall go back to standard and not overfill the header. Quote
