RogerH Posted October 11 Report Posted October 11 Hi Folks, I have a query regarding MIG welding. I have an R-Tech MIG181 welder I am using disposable gas bottles (for convenience) with Argon on mild steel (car body panel) 0.8mm steel wire Usually the spark has that frying bacon sound (crackle crackle) and metal is laid down. I would not say perfectly or even close to perfect. But all too often the frying bacon is replaced with a hissing sound, the spark is replaced with what looks like a plasma discharge and the weld surface is coated in a thin sheen blue/silver metal. As if metal spraying. Has anybody got an idea what I am doing wrong. Should I be using CO2 gas or Argon with 5% CO2. Help Roger Quote
Chilliman Posted October 11 Report Posted October 11 Hi Roger, I've got the exact same unit as you & run it with a big bottle co2 & 5% argon mix, I've never experience what you are describing, it tends to produce very nice clean welds. Quote
RogerH Posted October 11 Author Report Posted October 11 Hi John Thanks for the reply. I do have a large bottle 5%CO2/Argon - perhaps I need to hook it up and see what happens. Roger Quote
stuart Posted October 11 Report Posted October 11 I prefer the pure Argon as I think it gives a cleaner weld, one thing you’ve got to watch is the modern high carbon steel as its more difficult to weld and is very easy to blow holes in with a MIG Stuart Quote
AlanG Posted October 11 Report Posted October 11 I've found that if it's been a while since I've used the welder I have to strip some wire off the reel to get to clean wire. Alan. Quote
RogerH Posted October 11 Author Report Posted October 11 Clean weld wire. It is the older original body steel that can blow the odd hole. But that is almost certainly my fault. The replacement mild steel I'm using is capable of a decent weld bead until I have my way about things. My main concern is this 'plasma like' non-spark Roger Quote
Lebro Posted October 11 Report Posted October 11 I have experienced what you describe, I think it's a wire feed speed issue, try upping the speed a tad. Bob Quote
john.r.davies Posted October 11 Report Posted October 11 Roger, What are your power and wire feed settings? It may be that the welder is doing exactly what you say: "the spark is replaced with what looks like a plasma discharge and the weld surface is coated in a thin sheen blue/silver metal." You have accidentally transitioned from standard short-circuit transfer into spray arc transfer. If the power is set too high, then instead of melting when it hits the panel and a circuit is formed, the wire strikes an arc as it approaches and vapourizes, condensing on the surface as the metallic sheen. Typically this changes the sound from a fizz to a hiss. The cure would be to reduce the volts, or increase the wire speed. Could also be an unreliable wire feed mechanism. If the speed falls then in the intense heat around the weld pool the same as above occurs. John Quote
RogerH Posted October 11 Author Report Posted October 11 (edited) Thank you Bob and John. That is very scientific and theoretical. Something from a sci-fi movie. The welder is quite clever and can set its own ideal settings. These should work every time. My old Clarke 100E also did this plasma type thing The actual wire feed speed is very stable. I did try slowing the wire feed down as the weld bead did look on the big side, but!!! So tomorrow I will try CO2, 5%CO2/Argon vary the wire speed Roger Edited October 11 by RogerH Quote
Chilliman Posted October 11 Report Posted October 11 I've been doing a fair bit of bodywork recently, I expect you've found out for yourself that a lot of what used to be 18g Stanpart panels has now become 0.9mm with the replacement panels that are available which is easy to blow holes in if you're not careful. I have a selection of shapes of copper I use as backing plates which work very well & I have recently bought a cheapo set of grips with a copper face which works incredibly well for doing plug welds & filling small holes, leaving a smooth side. Wish I'd bought a set years ago. They would be simple enough to make yourself from an old set of Moles but they were only about £8 from China so not really worth the effort. Quote
RogerH Posted October 11 Author Report Posted October 11 Hi Folks, I have been posting this query on the Sideways forum and there is a general feeling that the wire speed is too low/slow. This has allowed me to come up with a theory (wow). if the wire speed is too slow to support a continuous arc and if in that instant where the arc stopped there was conductivity between the job and the contact tip then perhaps as the wire just about emerged it got plasma'd and the slow wire speed continued to sustained the plasma. The contact tip would need to be near the job. So increase wire speed and increase gap between tip and job. May be. Roger Quote
stuart Posted October 11 Report Posted October 11 When was the last time your replaced the liner in the torch feed, they do pickup the coating on the wire after a while which will slow the feed also clean the rollers in the feed mechanism as well as they pickup the coating too. Stuart. Quote
ed.h Posted October 12 Report Posted October 12 Interesting that you have 5%CO2/Argon. Here in the US, "C25" is pretty standard for MIG welding. That's 25% CO2, 75% Argon. TIG typically uses 100% Argon. Ed Quote
RogerH Posted October 12 Author Report Posted October 12 Hi Stuart, It is a fairly new unit and hasn't done a great deal of welding. Roger Quote
john.r.davies Posted October 12 Report Posted October 12 22 hours ago, RogerH said: Thank you Bob and John. That is very scientific and theoretical. Something from a sci-fi movie. SciFi??? Spray arc is a known and used welding technique. Here's a discussion of the problem from the MiG welding forum: What's spray arc? | MIG Welding Forum and one from an instruction site: What is Spray Transfer Welding? (Beginner's Guide) John Quote
TR4Tony VC Posted October 15 Report Posted October 15 (edited) Hi Roger Ive settled on a 15% argon mix and use the hobbyweld bottles which you buy one and then just get it refilled (or another the same) - I’ve found the 15% mix does everything well, whereas even the 5% similar from Hobbyweld have the sorts of issues you’re experienced on new steel. I really struggled with the small white disposable cylinder gas, so gave up years ago. My hot shot friend who does some TIG and ally welding for me always tells me I should be using gas less wire, so that may be worth trying too. It seems like lots of the ‘pros’ do. Regards Tony Edited October 15 by TR4Tony VC Quote
RogerH Posted October 15 Author Report Posted October 15 Hi Tony thanks for that. I have just bought a SIP disposable bottle from Halfords and that is 86/14% Ar/CO2 The gasless wire has a certain appeal. Roger Quote
dave bailey Posted October 15 Report Posted October 15 On 10/11/2026 at 5:04 PM, john.r.davies said: Roger, What are your power and wire feed settings? It may be that the welder is doing exactly what you say: "the spark is replaced with what looks like a plasma discharge and the weld surface is coated in a thin sheen blue/silver metal." You have accidentally transitioned from standard short-circuit transfer into spray arc transfer. If the power is set too high, then instead of melting when it hits the panel and a circuit is formed, the wire strikes an arc as it approaches and vapourizes, condensing on the surface as the metallic sheen. Typically this changes the sound from a fizz to a hiss. The cure would be to reduce the volts, or increase the wire speed. Could also be an unreliable wire feed mechanism. If the speed falls then in the intense heat around the weld pool the same as above occurs. John I agree with John, I've experienced this problem many times, and found that turning the power down one setting, or increasing the wire speed cures the problem. I find that the Hobbyweld 5, (5% CO2) works very well. Dave. Quote
Dale Moore Posted October 15 Report Posted October 15 I think I get this effect when the welders not been used for a while. The wire feeds a bit sticky coming out, usually resulting in a ball on the end of the gun I speed it up until it gets more steady Being a bit short on gas I tried the gasless wire last year when welding up a bit of corrosion on one of the rear chassis legs. Results were ok ish Bit like stick welding but a tad more controllable. Leaves slag so you have to keep chipping it off before going over it again Dale Quote
John Bracher Posted October 16 Report Posted October 16 Roger, I have the Mig 180 (previous model) and I have to say, it has never missed a beat. Except once, when the spool was binding on the supply spindle, due to a damaged/bent spool. It was defeating the wire feed roller pinch, and sporadically interrupting the wire feed. The same/similar can happen if the torch feed cable is kinked/bent. Quote
RogerH Posted October 16 Author Report Posted October 16 Hi John thankfully I am completely kink free. I may have found the cause of the problems. On Wednesday the orginal spool of wire finished. When I went to fit the new spare I noticed that the old spool was for 0.6mm wire and I had been running it on the 0.8mm setting. Perhaps that is why it was burning out and plasma spraying. The new roll of 0.8mm mild steel wire is working well. Roger Quote
Ian Vincent Posted October 16 Report Posted October 16 I changed to gasless welding when I ran out of gas half way through a little project and now I’m a convert. No faff, minimal spatter and tidy welds. I use a stop start technique on thin sheet to avoid blowing holes. Rgds Ian Quote
john.r.davies Posted October 16 Report Posted October 16 2 hours ago, RogerH said: Hi John thankfully I am completely kink free. I may have found the cause of the problems. On Wednesday the orginal spool of wire finished. When I went to fit the new spare I noticed that the old spool was for 0.6mm wire and I had been running it on the 0.8mm setting. Perhaps that is why it was burning out and plasma spraying. The new roll of 0.8mm mild steel wire is working well. Roger Ahah! Wire feed rate not what it was set at >>>> arcing! Quote
BlueTR3A-5EKT Posted October 16 Report Posted October 16 4 hours ago, RogerH said: Hi John thankfully I am completely kink free. I may have found the cause of the problems. On Wednesday the orginal spool of wire finished. When I went to fit the new spare I noticed that the old spool was for 0.6mm wire and I had been running it on the 0.8mm setting. Perhaps that is why it was burning out and plasma spraying. The new roll of 0.8mm mild steel wire is working well. Roger So, what is the preferred MIG welding wire? On 5kg reels Quote
