Nigel C Posted October 12 Report Posted October 12 Hi all, I have tried searching for this info on the forum, don't know if its me or the search engine etc but couldn't find what I wanted so here we go, new thread! Can anyone give me an indication to the travel of the solenoid on an A type overdrive. I have a "non standard" arrangement (Ken will kill me John!) on mine and I'm thinking that I might be asking to much of the solenoid to draw the OD actuator in. I will measure the travel tomorrow...to tired tonight to go back out there....equally, have to keep busy! Quote
Trumpy3 Posted October 12 Report Posted October 12 Nigel Not sure what you mean by 'non standard' but if the solenoid system is basically standard then the travel is important. There is a stop that prevents the armature (plunger) from dropping all the way down. If it does bottom out, it may not be strong enough to pull the armature into the solenoid due to not enough of the armature is actualy in the solenoid.. There were two methods used to act as a 'off' stop. A rubber stopper which normally deteriorate due to the inevitable oil leaks. The other is a small screw that can be adjusted to give the required armature travel. It is normal to replace the failed rubber stopper with a screw set up. The actual recommended setting is the distance between the stopper and the armature in the engaged position. Can't actually remember the setting but it is listed in some manuals. I experienced an issue where the OD would not engage some times but would mysteriously engage some time latter, 5min-30min latter. My OD had a failed rubber stopper. Fitted an adjusting screw and problem went away. Brian Quote
John Morrison Posted October 13 Report Posted October 13 (Ken will kill me John!) .....Again! John. Quote
Nigel C Posted October 13 Author Report Posted October 13 I've measured the travel on my solenoid and its around 7mm which I'm sure is well within its capabilities and it is making it all the way in and not drawing current. I guess it failed due to old age....it has my sympathies ! Quote
