Richardtr3a Posted October 13 Report Posted October 13 We have a heavy kitchen sink and it is supported by short clamps underneath the worktop which is fitted over the sink, and cut to match exactly where it touches .There is a small gap of 1/16". This was sealed on initial installation but the seal has given way. The work top has drainage grooves and water runs off the surface and is now leaking into the drawer underneath. So I am looking for some waterproof seal with a very fine applicator. It is tempting to apply too much and push it in by hand , but that will leave some residue on both the sink and the worktop which will look bad. Please help. Richard Quote
Scott M Posted October 13 Report Posted October 13 Can you loosen the worktop at all to give a larger gap between it and sink ? Maybe then get the nozzle of a silicone gun in there and it would seal better when clamped back tight ? Quote
Richardtr3a Posted October 13 Author Report Posted October 13 Thanks Scott I will look at it in the morning when I can remove the drawers under the sink and be able to see the actual leak. Quote
jerrytr5 Posted October 14 Report Posted October 14 Can you not use a standard silicone and then wipe off excess with a cloth and white spirit? That should just fill any gap. Jerry Quote
Richardtr3a Posted October 15 Author Report Posted October 15 (edited) The leaking points were around the basin fixing bracket. I cleaned up the very small gap and filled with silicon mastic using a Stanley blade only. I am leaving a major test for a while. I am searching the garage for white spirit Thanks Richard Edited October 15 by Richardtr3a spelling Quote
