BlueTR3A-5EKT Posted October 15 Report Posted October 15 (edited) Welcome Paul. Fixed , inertia or full harness for race/competition use? Try TR Shop in Chiswick London. Edited October 15 by BlueTR3A-5EKT Quote
RogerH Posted October 15 Report Posted October 15 Hi Paul werlcome to the Forum. It may be a good idea to edit your title to reflect seat belts. Roger Quote
Ecosse Posted October 16 Report Posted October 16 Touchy subject this. I have seen many sidescreen cars fitted with seatbelts where the mounting points are substantially below shoulder level. My understanding is that this can cause injury to the shoulders due to the downward force applied to the shoulders in an impact. Cliff Quote
james christie Posted October 16 Report Posted October 16 I think I would prefer to have a shoulder injury rather than have my head go through the windscreen or be thrown out! After many years of the old traditional belts, a couple of years ago I fitted automatic inertia belts with a 30cm stalk. I find them comfortable and easy to wear. However they don't always reel themselves up due to interference from the tonneau cover when it is fitted. Yes the mechanism is a little below shoulder level, I have a long term project to fit a bracket a bit higher up, clamped to the safety roll over bar james Quote
Paul Chapman Posted October 18 Author Report Posted October 18 On 10/15/2026 at 5:24 PM, RogerH said: Hi Paul werlcome to the Forum. It may be a good idea to edit your title to reflect seat belts. Roger Hello Roger and to all who replied to my first and clumsy post, note to self 'must do better' I am a recently returning member to the register, last here circa 1978 and I have just acquired a TR3A. It does have a pair of static belts at present which I have thought I would replace with a set of inertia reel belts if this is possible and practical. So I would be interested to hear what the merits and pit falls of fitting reel belts and the experience of other forum members. Paul Chapman Quote
RogerH Posted October 19 Report Posted October 19 11 hours ago, Paul Chapman said: Hello Roger and to all who replied to my first and clumsy post, note to self 'must do better' I am a recently returning member to the register, last here circa 1978 and I have just acquired a TR3A. It does have a pair of static belts at present which I have thought I would replace with a set of inertia reel belts if this is possible and practical. So I would be interested to hear what the merits and pit falls of fitting reel belts and the experience of other forum members. Paul Chapman Hi Paul, you're doing OK. I had inertia belts on my 4A and didn't get on with them. The 'reel' box took up limited luggage space and the constant pressure across my chest was an iritation. I now have static belts that can be adjusted to be where I want them. The main down side is that some things may be out of reach within the car, so you need to pop the belt, do the reaching then buckle up. Roger Quote
BlueTR3A-5EKT Posted October 19 Report Posted October 19 The nicest solution I have had on a sidescreen TR was the inertia belt from. TR7 coupe. The inertia box bolted to the arch top with the belt coming straight out over your shoulder. The box has to be in a position not to touch the hood frame, Kept luggage space behind the seat at a maximum. The only issue was the stalk the buckle clipped in, not able to position comfortably I changed to Securon inertia belts with the box on the side of the arch and the runner on the top., not the best solution as Roger says it restricts space on the dog shelf. I have kept the TR7 belts, just in case. Quote
Ian Vincent Posted October 22 Report Posted October 22 On 10/16/2026 at 11:23 AM, james christie said: I think I would prefer to have a shoulder injury rather than have my head go through the windscreen or be thrown out! After many years of the old traditional belts, a couple of years ago I fitted automatic inertia belts with a 30cm stalk. I find them comfortable and easy to wear. However they don't always reel themselves up due to interference from the tonneau cover when it is fitted. Yes the mechanism is a little below shoulder level, I have a long term project to fit a bracket a bit higher up, clamped to the safety roll over bar james I made a couple of brackets for my seat belts which I fitted to my safety roll over bar. Rgds Ian Quote
