I'm new here so please take it easy on me...
I attached the rear mounts to the aluminum housing, I placed the rubber cones on to the differential bracket. I made sure that the flange of the differential was more or less 90°. I then used a laser to determine that the rear mount positions and front mount positions are more-or-less at the same level - see photo.
The difference between the chassis mounting points in the z-.axis is around 23mm (the repair manual), so when the diff is mounted to the car then is it correct to assume that it has an angle of around 3.9° to the horizontal ? (I'm assuming 336mm between the front and back studs) - am I missing something here  I thought it should be close to 90°.
Does anybody know what value the diff flange should have when mounted to the chassis
Hi Phil
Welcome to the forum we don't bite!
Nothing I worried about when it came time to bolting it back in place. Besides the props UJ's will take out any discrepancies if there are any at both ends.
Looks like you have a nice winter project going on.
I'm sure others will be along with greater knowledge.
Andy
Hi Phil,
wow, first question and a frist class question too!
What you notice is what I also noticed and considered in 2021 with my TR4A IRS.
The answer is pretty easy but never any issue on any TR forum I know:
The engine and diffs are both angled on all TRs, on the 4A IRS - TR6 in Z-orientation - that is pretty easy!
On the Z-orientation the diff must be angled the same amount as the engine, the angle of the probshaft doen't matter.
AP1GczOpeEJqwxsVBPqvqMo7NAY8GpCEA9mKMg5I
This is why the diff is installed in angle on all TR IRS axles.
BUT to my measurement on the original setup the diff is angled much MORE than the engine - causing not harmonic spinning of the diff, drive shafts and wheels.
As told above, not any issue here or on any other TR forum....
I shimmed my diff 10 mm at the front, sadly that makes a set of distancers and "connectors" needed (and a lathe) and the assembly a bit a pain.
But the result makes me very pleased!
AP1GczPhbKEPXp1bw81qaPkAhGZHd0u3v-vq0jUB
On the photo the distancers are 21 mm to get the diff horizontal, that was wrong, I reduced them to 10 mm for the correct angle.
10 mm may not be correct on your TR6, becaues my 4 pot engine is not original fitted at the front and rear end.
BTW the W-orientation is much more "a problem" on the solid axles (TR2-4+ AA not IRS),
because the angle of the engine to the probshaft must be the same as the angle of the probshaft to the diff.
And while driving a TR2-4 the diff constantly changes its angle, because it sadly has no traction bar.
AP1GczO1ctfAIgBKwrxrsHfWN5CYc7c_-c8LIAUK
For any questions - please ask.
12 hours ago, PodOne said:
Hi Phil
Andy
Thanks Andy for taking time to respond, good to know that you don't bite and that the differential worked a treat for you.
KR
Phil
1 hour ago, Z320 said:
Hi Phil,
On the photo the distancers are 20 mm to get the diff horizontal, that was wrong, I reduced them to 10 mm for the correct angle.
Hi Marco
Thanks for you explanation, My findings would support your 20mm spacers to get it pretty close to 90° flange angle. Unfortunately, on my car I have an additional 7-8mm because the rear mounts are too low.
Could you explain exactly what you mean on the Z-view and w-view, are the 10mm spacers addressing the W-Axis.
On a standard setup (23mm relative height difference between front and rear mounting points) I would expect around 4° tilt up - which plane is this for you W or Z ??
I love the sketches maybe I can do a couple and place them in this topic.
Again many thanks for your valuable reply.
BTW, you can shim the rear mount by adding a couple of washers (about 5-6mm), Doing that I can get correct about 1°
Ok, I try.
On the sketch below I doubled all angles to make the issue better visible.
You see on the front the engine and gearbox -> angled on my 4A about 1.5°
And at the rear the diff -> angled about 4°, between is the propshaft (not correct illustrated).
This is the z-orientation of the gearbox and diff flange, but with a difference of 4.0 - 1-5 = 2.5°.
But both should have the same angle (0 on my sketch above, with the propshaft angled).
AP1GczN1_cDHnP1ETBuXvVdajBhjCO-WF0PGW8zh
I lowered the front bracket of the diff to get the diff angle down to 1.5°, same like the engine-gearbox unit.
At TR2-4s (solid axle) the diff points down to the front, not up like on the IRS TRs.
This is the W-orientation (which looks more like a U or V).
Several times on this forum I posted this youtube video
And this shows how the angle of the diff changes on a TR4 (W-orientation)
Snd I found this new video
12 hours ago, Z320 said:
Hi Phil,
Marco,
Is that a modification of some sort you've made to the mounting studs?
I ask because the nearside rear stud on my TR6 has stripped threads. The result of this is obviously not being able to tighten the nut adequately which I believe is the source of my rear end clunk.
I'm looking for a repair solution if anyone can offer one.
Richard.
10 hours ago, Z320 said:
Ok, I try.
Hi Marco
Many thanks for the explanation, now it is crystal clear which angles you mean. Very helpful.
Could you confirm that the default "normal" diff angle is around 4° pointing upwards. This would confirm my calculations and observations.
Many thanks
Phil
Hi Richard,
to adjust the angle of the TR4A IRS diff I fitted spacers and thread connector on the front studs to lower the diff there.
Because the TR6 diff has a different rear end to fix to the frame it should be better and much easier to lift the diff there for the correct angle.
This may help you with your stripped threads? I guess not.  I own no TR6 so I can't test.
Ciao. Marco
Hi Marco
I would also be interested in what you did here. I would ideally like to lengthen the studs a little.
In particular how you stopped shaking loose..
see red area of your original photo
2 hours ago, Phil-1CP said:
Hi Marco
Many thanks
Phil
Phil,
I don't remember, "about" 4° could be possible.
But a 4A IRS must not be the reference for your TR6,
because the rear end of the diff is fixed different.
Ciao. Marco
3 minutes ago, Phil-1CP said:
Hi Marco
As told above it should be much easier to modify the rear end fixing on a TR6, mine is a TR4A IRS.
To avoid shaking loose I use Loctite in different variations, here "high strenght"
Hi Marco
There are certain limitations on the rear, basically when the bolt head hits the frame, but using longer bolts and placing the washers/spacers between the mounting brackets on the aluminum housing (not the fixing bolt).
Do you happen to have a drawing of the stud extension or is this some form of standard stud extension, any help would be appreciated.
As stated above I need to correct the additional 7mm, so a spacer at the front would be needed and hence a stud extension.. Any help would be appreciated.
It looks pretty substantial.
Kind regards
Phil
I show you later, but this front extensions are a pain to fit.
Because with fitted them first, it is not possible to fit the diff anymore,
hitting the frame and brake line fittings.
AP1GczMJJE2v8DoGs8H9w8-Wr6P0zvA7kUQYWYoT
Hi Marco
Thanks for all the video links as well. I haven't watch them all yet but will do shortly.
If you get chance to tell me how you did your stud extensions then that would be appreciated
kind regards
Phil
Hi Phil,
the 3/8" UNF thead on the stugs is about 15 mm long,
when I fitted 21 mm spacers I made connectors 21 mm (hex 14 mm) long and glued the cut off end of a bolt in.
As I wanted to reduce the spacers to 10 mm obviosly so such short connector is possible.
I modified the outside hex surface and made a fat washer M16 (or 18, I don't remember) with a pressed in sleeve.
  AP1GczMch7Mgkz46Mbp-MQdLJpr_jNTGdKJpkDtd
From on top....
AP1GczPG749KN2FMaa8tZrhieK1nKLsPi3SoRzU_
from below...
AP1GczMHbPylzXBwCVhUgCxRAcysqjcj-KXZXRej
37 minutes ago, Z320 said:
Hi Phil,
From on top....
from below...
Thanks Marco
Very interesting, I assume by "glued" you meant "welded" otherwise what glue did you use?
I assume just to create a stud extension that the above hex nut and bolt combination is the same principle ? see below?
Many thanks for taking time to answer so many questions already
KR
Phil
Sorry me, you misunderstand me.
Glue is glue with Loctite high strenght, not weld.
If you weld the extensions on the studs you will not get the diff in and not out!
The set of extensions is before (21 mm) and after (10 mm) modification = the same.
BTW! Think this probelm to its end, please.
If you have drive shafts from the diff to the wheel hubs with univerals joints,
and the wheel hubs are not in the same angle (toe in and camber) like the diff (zero in both directions),
the rear wheels don't spin with constant speed too. So you better don't overdo the toe in and camber.
I remember a TR6 at the Belgium TR meeting, not knowing what driveshaft it has....
Hi Marco
That's my bad, completely misunderstood your text.
So the stud extension is machined from one piece and then it is glued (loctite) on to the existing stud thread.
KR
Phil
Good point,
So I should also check the angular position of the half shaft flanges and make sure the differential is not twisted.
I'm going to use new half shafts obtained from Moss and then I will check the toe in and chamber.
Have you any recommendations or measurements for this....
Of course, one simple solution to all this would be a CV joint driveshaft. The angles make no difference for a CV shaft, as opposed to U-joint shafts. If only someone would sell such a beast...
