Phil-1CP Posted October 16 Author Report Posted October 16 8 hours ago, Z320 said: Standard data, not more Hi Marco thanks, I was wondering if you could answer one more question:- Did you buy these stud extensions and if yes where did you get them from.??? I would be interested to buy a few or even make my own if I knew what your starting point was. I'm really interested in the stud extension - see below:- Again any help would be highly appreciated. KR Phil Quote
Z320 Posted October 16 Report Posted October 16 Sorry Phil, they are self made on my lathe. 14 mm hex bar, 3/8“ tap, a 3/8“ bolt, cut on lenght and glued in Quote
Phil-1CP Posted October 16 Author Report Posted October 16 2 hours ago, Z320 said: Sorry Phil, they are self made on my lathe. 14 mm hex bar, 3/8“ tap, a 3/8“ bolt, cut on lenght and glued in thanks Marco okay, I can now see how you did it, I thought the Loctite was to mount the adapter to the chassis stud, not the bolt in the hex bar to form the extension adapter. Kind regards Phil Quote
Schnippel Posted October 17 Report Posted October 17 Hello, this week I spoke with a specialist in driveshaft manufacturing. The transmission flange and the differential flange must be parallel! Maximum angular deviation: 5 degrees. In the TR, the transmission flange is tilted slightly backward. Therefore, the differential flange must also be tilted backward. If I lower the differential at its front mount, the exact opposite happens. Right? Best regards, Ralf Quote
Z320 Posted October 17 Report Posted October 17 (edited) On IRS TRs both shafts (engine + diff) point up in the direction if driving. This way they are parallel, as the flanges are also parallel 90° to the shafts. Parallel is correct, but with too much difference Edited October 22 by Z320 Typo Quote
Z320 Posted October 17 Report Posted October 17 (edited) 1 hour ago, Schnippel said: Hello, this week I spoke with a specialist in driveshaft manufacturing. The transmission flange and the differential flange must be parallel! Maximum angular deviation: 5 degrees. In the TR, the transmission flange is tilted slightly backward. Therefore, the differential flange must also be tilted backward. If I lower the differential at its front mount, the exact opposite happens. Right? Best regards, Ralf Two cases: the engine on all TR2-6 point up in the direction of driving. This is why the diff must also point up (the same angle) in the direction of driving. But on the solid axle TRs the diff point down in the direction of driving and constantly changes, on the IRS axles it point as the engine up (parallel) but much to much. The max difference of the angle pretty sure is NOT 5°, but 0.5°, or you have to contact another „specialist“. 5° is the standard max. angle for a probshaft to a powershaft with universal joints Edited October 17 by Z320 Quote
Schnippel Posted October 17 Report Posted October 17 Hello, With the protractor like the one Phil uses, you can precisely measure the parallelism of the flanges to each other. The offset of the flange centers must not exceed 5 degrees. Ideally, it should be 1-3 degrees to ensure proper lubrication of the cross pins. Have fun measuring! Ralf Quote
Z320 Posted October 17 Report Posted October 17 Simple answer: it’s different Don‘t mix up different position on the drivedrain, please Quote
Phil-1CP Posted October 17 Author Report Posted October 17 1 hour ago, Schnippel said: Hello, With the protractor like the one Phil uses, you can precisely measure the parallelism of the flanges to each other. The offset of the flange centers must not exceed 5 degrees. Ideally, it should be 1-3 degrees to ensure proper lubrication of the cross pins. Have fun measuring! Ralf Well this is my take.... the picture that Marco posted is the best way for visualizing the angles on the drivetrain... The diff and transmission axis need to be parallel, I would aim for a difference of+-0.5°, the flange angles need to be adjusted to achieve the this value. Whether they are 3-5° I don't know. My measurements at the diff side indicate a 4° tilt up (depending on your viewing point) I don't know yet what my transmission angle is, but if I leave the diff at 4° I would aim to go for 4° for the transmission (for me this then points down out of the engine, up if you consider the drive train from the diff) 0° is apparently bad because the needles on the UV joints don't move... I heard when using the digital protractor that flipping it can cause an error, so use the magnetic side on the diff and keeping the same orientation use the non-magnetic side for the transmission output. no idea whether this is true. as I said just my take on things. Marco has more experience on this. KR Phil Quote
Z320 Posted October 17 Report Posted October 17 (edited) OK, 3 things first: #1: I hope this is not only waste of time #2: all angles are examples, please check on your own TR #3: I don't know whats Ralf's problem with me (indeed I guess I know) Here we go See the sketch I made on a drivedrain with Z- (IRS-axles) and W- (TR solid axles) orientation. First the IRS axles: Assume the propshaft is leveled to 0° (indeed it is not). The engine best should be angled 1° UP to keep the gearbox universal joint moving for lubrication. But this causes not harmonic spinning of the probshaft (vibartions and wear out), which should be deleted by the diff angled 1° UP. 2 UJ angled 1°, both shafts parallel again --> PERFECT! Next the solid axles: Same issue, but the diff must point DOWN, to get the same angle, but NEGATIV What is the issuey on my TR4A (engine differnt fixed, different gearbox, diff different fixed) The assembly is still Z-orinentation, my engine is pointing 1.55° UP, the propshaft also UP (NOT down) 1°, reducing the bend of the 1st UJ sadly down to 0.55°. Not good, I know, but I can´t change this. The diff was pointing UP 4°, that is 2.45° too much and causes more disharmonic spinning of the diff AND driveshafts AND wheels than it deletes. What is the issue on solid axles TRs? I can only suppose this, because I don't own a TR2-4. alpha 1 - alpha 2 is not at all alpha 3 - alpha 2, and constantly changing while driving, a poor construction. The Triumph engineers pretty sure knew why the IRS axle was needed to bring on the market. And they knew about the Z-orinetation and did it basicly correct, but too much for what ever reason. Ciao. Marco Edited October 17 by Z320 Quote
Schnippel Posted October 17 Report Posted October 17 Vor 4 Stunden schrieb Phil-1CP: Also, das ist meine Einschätzung… Das von Marco gepostete Bild veranschaulicht den Winkel des Antriebsstrangs am besten. Die Achsen von Differential und Getriebe müssen parallel verlaufen. Ich würde eine Abweichung von ±0,5° anstreben. Die Flanschwinkel müssen entsprechend angepasst werden. Ob sie 3–5° betragen, weiß ich nicht. Meine Messungen am Differential ergaben eine Neigung von 4° nach oben (je nach Blickwinkel). Ich kenne den Winkel meines Getriebes noch nicht, aber wenn ich das Differential auf 4° belasse, würde ich auch für das Getriebe 4° anstreben (das Getriebe zeigt dann vom Motor weg nach unten, vom Differential aus betrachtet nach oben). 0° ist offenbar ungünstig, weil sich die Nadeln an den UV-Gelenken nicht bewegen... Ich habe gehört, dass das Umdrehen des digitalen Winkelmessers zu Fehlern führen kann. Daher soll man die magnetische Seite am Differenzial verwenden und bei gleicher Ausrichtung die nichtmagnetische Seite für den Übertragungsausgang verwenden. Ich weiß allerdings nicht, ob das stimmt. Wie gesagt, das ist nur meine Meinung. Marco hat da mehr Erfahrung. KR Phil Hi, you can only check the parallelism of the flanges once the machine, including the transmission and differential, is bolted to the chassis. The transmission could be lifted at the rear using small flat bars, for example. I just removed a transmission, and those things were underneath it too. At least on the J Overdrive version. TR 6 Best regards, Ralf Quote
Phil-1CP Posted October 17 Author Report Posted October 17 1 hour ago, Schnippel said: Hi, you can only check the parallelism of the flanges once the machine, including the transmission and differential, is bolted to the chassis. The transmission could be lifted at the rear using small flat bars, for example. I just removed a transmission, and those things were underneath it too. At least on the J Overdrive version. TR 6 Best regards, Ralf Hi Ralf Exactly, that would be the plan. I only measure the diff to get a ball-park figure for the angle. I have an A-type overdrive, so that's something I still have to measure once everything is bolted to the chassis. KR Phil Quote
Z320 Posted October 17 Report Posted October 17 (edited) 2 hours ago, Schnippel said: Hi, you can only check the parallelism of the flanges once the machine, including the transmission and differential, is bolted to the chassis. The transmission could be lifted at the rear using small flat bars, for example. I just removed a transmission, and those things were underneath it too. At least on the J Overdrive version. TR 6 Best regards, Ralf Who wants to improve the assembly by lifting the gearbox - will fail. Edited October 17 by Z320 Quote
Phil-1CP Posted October 17 Author Report Posted October 17 3 hours ago, Z320 said: Who wants to improve the assembly by lifting the gearbox - will fail. Why, what is the problem? , so all possible corrections at the diff ??? Quote
Phil-1CP Posted October 18 Author Report Posted October 18 10 hours ago, Phil-1CP said: Why, what is the problem? , so all possible corrections at the diff ??? Hi Marco According to the PM you sent, a 4° correction at the gearbox side is not possible... so here my situation:- The rear diff mounting bracket is incorrect on my chassis, With the normal mounting arrangement (23mm height difference and 336mm between front and back pivot) there is a standard (my opinion) 4° pointing up angle. Due to the incorrect chassis I have another nearly 2°, so I'm at 6° total. So in your opinion any correction should be done on the differential side...depending on the gearbox angle. I'm pursuing this a little because I may have to scrap my chassis and somehow get a new one...and would like to hear your valuable suggestions, Quote
Z320 Posted October 18 Report Posted October 18 Yes, to get the shafts parallel the gearbox must be very much (!) lowerd, to fit to the diff. IMO this is not possible. It is much easier to get the diff down to the gearbox angle Quote
Phil-1CP Posted October 18 Author Report Posted October 18 6 hours ago, Z320 said: Yes, to get the shafts parallel the gearbox must be very much (!) lowerd, to fit to the diff. IMO this is not possible. It is much easier to get the diff down to the gearbox angle thanks for the confirmation that focus should be the differential. Just out of interest which loctite did you use on your stud extender? Did you use the same one for both the bolt in the hex bar and the extender to diff stud thread ? KR Phil Quote
Z320 Posted October 18 Report Posted October 18 I used strong both, but recommend medium, because the extensions must be off for the diff out again Ciao, Marco Quote
Phil-1CP Posted October 18 Author Report Posted October 18 46 minutes ago, Z320 said: I used strong both, but recommend medium, because the extensions must be off for the diff out again Ciao, Marco Hi Marco Thankyou, that is what I thought,.. high strength can't get them off. Maybe 243 would be good. could use 270 for the bolt though... Thanks again Marco, you have been really helpful to me.... KR Phil Quote
stuart Posted October 18 Report Posted October 18 11 hours ago, Phil-1CP said: Hi Marco According to the PM you sent, a 4° correction at the gearbox side is not possible... so here my situation:- The rear diff mounting bracket is incorrect on my chassis, With the normal mounting arrangement (23mm height difference and 336mm between front and back pivot) there is a standard (my opinion) 4° pointing up angle. Due to the incorrect chassis I have another nearly 2°, so I'm at 6° total. So in your opinion any correction should be done on the differential side...depending on the gearbox angle. I'm pursuing this a little because I may have to scrap my chassis and somehow get a new one...and would like to hear your valuable suggestions, FWIW you could get another rear differential bridge from likes of MT Classics in Birmingham Stuart Quote
Phil-1CP Posted October 18 Author Report Posted October 18 46 minutes ago, stuart said: FWIW you could get another rear differential bridge from likes of MT Classics in Birmingham Stuart thanks Stuart, Always an option, or I can just modify the mounts as Marco has suggested. KR Phil Quote
Phil-1CP Posted October 22 Author Report Posted October 22 Just out of interest, if I assume the Differential mountings are parallel when fitted (see first and second photos at the start of this topic) then I end up with a default diff angle of 3.92° assuming 336mm between front and rear mounts, and a 23mm height difference between front and rear mounts. Quote
Z320 Posted October 22 Report Posted October 22 Hi Phil, I found my posts starting November 2021 again, when I noticed my diff is angled about 4°. First I leveled it, what was better then 4°, until I noticed the flanges / shafts have to be parallel. Ciao, Marco Quote
sheldricka Posted October 22 Report Posted October 22 I’m currently looking at this specific issue too. I also had to level out the front diff mounts as they were previously badly repaired. The whole chassis, suspension, mounts were refreshed, the diff was rebuilt etc. 3000 miles later I’ve had the pinion bearing fail. I’ve been told it’s due to drivetrain misalignment. I’ve found I have a 2.25 degree difference between the diff and gearbox flange. The engine and gearbox mounts are recent, one prop UJ was also in need of replacing due to early signs of failure. My plan is to shim the front mounts with 3mm metal discs to get it to better align. I have enough room on the pins to safely do this. Quote
