Phil-1CP Posted October 22 Author Report Posted October 22 58 minutes ago, sheldricka said: I’m currently looking at this specific issue too. I also had to level out the front diff mounts as they were previously badly repaired. The whole chassis, suspension, mounts were refreshed, the diff was rebuilt etc. 3000 miles later I’ve had the pinion bearing fail. I’ve been told it’s due to drivetrain misalignment. I’ve found I have a 2.25 degree difference between the diff and gearbox flange. The engine and gearbox mounts are recent, one prop UJ was also in need of replacing due to early signs of failure. My plan is to shim the front mounts with 3mm metal discs to get it to better align. I have enough room on the pins to safely do this. Is the second picture the angle shown on the diff ???? I believe you can shim the back as well by adding spaces between the aluminium cover and the metal bushing bracket.. KR Phil Quote
Phil-1CP Posted October 22 Author Report Posted October 22 1 hour ago, Z320 said: Hi Phil, I found my posts starting November 2021 again, when I noticed my diff is angled about 4°. First I leveled it, what was better then 4°, until I noticed the flanges / shafts have to be parallel. Ciao, Marco Thanks for the previous post - I will take a good look... Quote
sheldricka Posted October 22 Report Posted October 22 14 minutes ago, Phil-1CP said: Is the second picture the angle shown on the diff ???? I believe you can shim the back as well by adding spaces between the aluminium cover and the metal bushing bracket.. KR Phil Yes it is, yes that makes sense. The next action is to drop the rebuilt diff, slide in the prop and start the process of getting the angles aligned. Quote
Phil-1CP Posted October 22 Author Report Posted October 22 50 minutes ago, sheldricka said: Yes it is, yes that makes sense. The next action is to drop the rebuilt diff, slide in the prop and start the process of getting the angles aligned. Keep me posted, I would like to hear about your progress... Mine is all theoretical until I get the Diff and Engine/gearbox on to the rolling chassis Quote
sheldricka Posted October 24 Report Posted October 24 On 10/22/2026 at 10:32 AM, Phil-1CP said: Keep me posted, I would like to hear about your progress... Mine is all theoretical until I get the Diff and Engine/gearbox on to the rolling chassis So, 3mm shim added to both the front pins to drop the nose of the diff and torqued up, the diff is now showing 85.22 from 84.60, analysis from Copilot… Quote
Z320 Posted October 24 Report Posted October 24 (edited) My guess (without AI) is, you have to add a total of 10 mm. My calcuator tells tan 1.96° x 335 mm = 11.46 mm. Ciao, Marco Edited October 24 by Z320 Quote
Phil-1CP Posted October 24 Author Report Posted October 24 Maybe 5mm at the front and 5mm at the back would work...Ideally if you have 87.8 at the gearbox you should be aiming for the same value at the differential. I don't know what angular tolerance is acceptable... and I don't know if a drive shaft inclination of e.g. 1° or so helps or hinders. Quote
