Steve-B Posted October 14 Report Posted October 14 (edited) If you're a skilled Mac user who is comfortable with the use of Terminal and unpacking, etc you probably are like me, an "old UNIX head" from the 70's and the forcible installation of all their intrepretation of AI (Ain't Intelligent) has dumped 10-30Gb of crud on your Mac with MacOS 26 or 27, this is for you! A clever friend noticed this new utility on GitHub called "Remove Mac AI" and it does exactly what the unpacking instructions say -- it removes all traces of the bloatware from your Mac! WORD OF WARNING: I have successfully run it and am not the writer, so if you are NOT skilled in UNIX/MacOS command line,get proper help or don't do this. If you are skilled and comfortable, take a look on GitHub at https://github.com/omlahore/RemoveMacAI and make your own decision. FWIW on MacOS 26.7 on my MacMini I regained 10Gb of space. Once I finally bite the bullet and install MacOS 27.x I will re-run it to purge the next dump. Edited October 14 by Steve-B Quote
RogerH Posted October 14 Report Posted October 14 Hi Steve, that sounds like a good move. Sadly Windows is full of its own rubish + who knows what. Last month I decided to go out and buy a new computer. I asked the young lad would they install Windows 7 - I like windows 7. He didn't quite laugh at me but it wasn't far short. Anyway the bottom line was no. So I went along to a small computer shop. They did laugh. I have a new computer at home with me (almost unsed) and it has W10. I can't really get on with it. Shame. Roger Quote
RobH Posted October 14 Report Posted October 14 Ask someone to put Linux Mint on it for you Roger. Quote
Charlie D Posted October 14 Report Posted October 14 I’ve got a home made CNC machine that I have not used for years, but I wanted to do a simple job three weeks ago. Unfortunately the PC I use to run it was dead, and after an hour or so I concluded it was the mother board, so decided it would be quicker and cheaper to just go and buy a whole “New” machine. The software I use runs on Win 98 and the last time I bought a computer for it they cost about a tenner. Looking on eBay it now seems that such machines cost between £75-£200, if you can actually find one that will handle Win 98. The problem with most machines made after about 2001 is that they have too much memory (Win 98 will not run with too much memory.) and if they have an LPT port it only gives out 3.3volts on the pins. My CNC controller needs 5V on the pins. I’ve tried loading Win 98 onto a late edition XP machine, (I tried for 2 weeks solid) but to no avail. Tomorrow a very old XP machine is arriving and, hopefully, I can get it to load ‘98. The message of this story is if you still have an ancient Windows 95/98 PC in the attic , DON’T take it to the tip, stick it on eBay. Over the years I’ve dumped so many PCs thinking that no one will ever want them. Now it seems that there is an upsurge in “Vintage computer games”, and they need 95 or 98 to run them. Charlie. (I'm using Win 8 to write this, and I'm 100% happy with it.) Quote
Steve-B Posted October 14 Author Report Posted October 14 1 hour ago, Charlie D said: Now it seems that there is an upsurge in “Vintage computer games”, and they need 95 or 98 to run them. Charlie. (I'm using Win 8 to write this, and I'm 100% happy with it.) You can install Parallels on a Mac if you need windows stuff, or similar on Linux/NetBSD/FreeBSD and avoid the Wintel cartel 😘 Quote
Lebro Posted October 14 Report Posted October 14 I have windows 98 on an old laptop which I use for my DOS based pcb design software (Boardmaker) Bob Quote
RogerH Posted October 14 Report Posted October 14 2 hours ago, Charlie D said: I’ve got a home made CNC machine that I have not used for years, but I wanted to do a simple job three weeks ago. Unfortunately the PC I use to run it was dead, and after an hour or so I concluded it was the mother board, so decided it would be quicker and cheaper to just go and buy a whole “New” machine. The software I use runs on Win 98 and the last time I bought a computer for it they cost about a tenner. Looking on eBay it now seems that such machines cost between £75-£200, if you can actually find one that will handle Win 98. The problem with most machines made after about 2001 is that they have too much memory (Win 98 will not run with too much memory.) and if they have an LPT port it only gives out 3.3volts on the pins. My CNC controller needs 5V on the pins. I’ve tried loading Win 98 onto a late edition XP machine, (I tried for 2 weeks solid) but to no avail. Tomorrow a very old XP machine is arriving and, hopefully, I can get it to load ‘98. The message of this story is if you still have an ancient Windows 95/98 PC in the attic , DON’T take it to the tip, stick it on eBay. Over the years I’ve dumped so many PCs thinking that no one will ever want them. Now it seems that there is an upsurge in “Vintage computer games”, and they need 95 or 98 to run them. Charlie. (I'm using Win 8 to write this, and I'm 100% happy with it.) Hi Charlie nobody like W8. That's why W10 happened. But then nobody like that either. Have you seen the prices for a BBC Acorn from the late 70's early 80's - OMG!!! Roger Quote
BlueTR3A-5EKT Posted October 14 Report Posted October 14 (edited) My 2011 iMac runs all my legacy software quite happily, which is why I avoided going upmarket with a newer but faster machine. Saved me lashing out on any replacement machine or software thankfully. The windoze 7 laptop I have is only now ever used to read certain motor manufacturer illustrated parts list/stock/pricing discs. I can then suck that info onto the iMac and read via the ancient cross platform database software FikeMaker Pro. That in turn is populated by Excel spreadsheets. PDF extraction from certain parts catalogues can be a challenge, but usually I can get a good enough image for the art dept to clean and part number, ready for web use. I have found I needed to get into the programs files on the iMac and delete the Adobe auto update ‘virus’ that wants me to rent their software, software that I have already legitimately purchased, so is not required The full screen pop up is more than annoying. Added to which they do not do a version of CS suitable for my ancient iMac. So Adobe auto updates are in the bin. Edited October 14 by BlueTR3A-5EKT Quote
Charlie D Posted October 14 Report Posted October 14 3 hours ago, Steve-B said: You can install Parallels on a Mac if you need windows stuff, or similar on Linux/NetBSD/FreeBSD and avoid the Wintel cartel 😘 2 hours ago, Lebro said: I have windows 98 on an old laptop which I use for my DOS based pcb design software (Boardmaker) Bob 6 hours ago, RogerH said: I have a new computer at home with me (almost unsed) and it has W10. I can't really get on with it Steve, I've got an HP ex-company laptop that was encrypted with McAfee Endpoint, so totally uncrackable to mess with, but I was somehow able to load it with Linux Mint and I guess it's possible to emulate Windows to run my ancient software, but I'm stuck again with the 3.3V LPT output. I built a 3.3V to 5V converter, but it still didn't seem to work, which is why I finally gave up and went and bought a PC that might actually work with Win98. Bob, I've also got a Panasonic Toughbook (Cast magnesium case which I stripped the paint off and polished to a high shine. Bling at it's best.) with Win98 on it but again the LPT output did not work properly. I totally understand why you use the DOS Boardmaker software. If it works for you, then why not. Roger, Have a look at "Classic Shell". I use it on my Win8 main machine to make the desktop look and act like I'm used to. (Looks unavailable at the moment, but it is there. I got onto it this afternoon.) http://www.classicshell.net/ Charlie. Quote
BlueTR3A-5EKT Posted October 24 Report Posted October 24 I have a spare functioning on mains Sony Vaio laptop that runs XP Has Pentium M725 processor 40gb HD free to a good home Re-homer pays postage. Quote
