Ken F Posted October 15 Report Posted October 15 Hello, I wanted to remove my as new tr6 mohair soft top and store it so I could get the hard top out the spare room so I could fit it for the winter. I wanted to leave the webbing on the frame intermediate bars but they are riveted. I was hoping to disconnect the webbing from the header rail and keep the header rail with the fabric but It appears to be glued and riveted but I can’t see. I fitted it myself years ago, it came from Moss. I want to avoid scratching or creasing the windows ( I have already made light scratches. ) the windows are so easy to crease or scratch. wish I’d left it in place. Question…. Is it possible to get the fabric off without unsticking or drilling out rivets? what do you owners do if changing between soft tops and hard tops. thanks in advance Ken. Quote
stuart Posted October 15 Report Posted October 15 Im pretty sure you can leave the soft top attached and fit the hardtop on a 6 Stuart. Quote
Peter V W Posted October 15 Report Posted October 15 Ken, you could remove soft top and frame together, 3 countersunk screws each side by the B post and 5 bolts along the rear deck. Lift off as one. Peter Quote
Ken F Posted October 15 Author Report Posted October 15 46 minutes ago, stuart said: Im pretty sure you can leave the soft top attached and fit the hardtop on a 6 Stuart. I looked into that but it’s wider than the wheel arches so won’t go deep enough to clear, also I’m trying not to fold the windows and without taking the ends of the rear rail off I’d have a fold at the corners of the side windows. maybe you have experience of doing it with a method which I can’t envisage. cheers Ken Quote
Ken F Posted October 15 Author Report Posted October 15 30 minutes ago, Peter V W said: Ken, you could remove soft top and frame together, 3 countersunk screws each side by the B post and 5 bolts along the rear deck. Lift off as one. Peter Yes I know but I don’t have space to hang it. It’s like new so I don’t want to just chuck it in the loft of something. The whole thing is heavy and unwieldy if left attached. Once the windows are folded the folds are permanently visible after a time. Thanks Ken Quote
stuart Posted October 15 Report Posted October 15 You just fold the hood the same way as if you would normally which I presume youve done lots of times before.Just remember to fit a couple of squares of foam over the latches to protect them then fit the soft top cover that is designed to cover it while the hard top is fitted. Stuart. Quote
heckler Posted October 15 Report Posted October 15 The soft top & frame can be left in with the hard top fitted it is not supported very well but will sort of sit there . If you have the dual purpose hood bag it can be secured to the inside of the hard top to cover it & make it look tidy but you do loose space . Far better to remove hood assy. Chris Quote
Ken F Posted October 16 Author Report Posted October 16 Thanks all, if I removed the ally strips for the door windows would the header rail separate from the frame? I would then have the fabric and the header which I could safely put in big box in the loft. I would have to drill out the rivets that secure the webbing to the frame but then I could store the fabric without the windows being damaged. I would drive it with the hard top on then, I drove it for 30 years with the hard top. I made seats for the twins and fitted a firewall. Triumph world did a big article on it in about 1995. I was the only TR6 with a hard top at the international weekend and the seats for the twins peaked their interest. I bought the hood with windows from Moss and had to cut and fit and glue it and put all the poppers in etc. I can't remember how I fixed it to the header and I can't see under the seal but its probably riveted and or screwed. When I get room to store the hard top I'll put the soft top back on but it won't be any time soon so just sitting hard top on the folded hood is not my solution because come the spring I'd need the hard top on so I could drive it. ( I don't have space to store the hood and frame as one ) My wife said sell the hard top ( when she's not saying sell the car and all my cars) but I'm keeping it. So those nuts on the outer edges which hold the aluminium strips on.. will that let me separate the rail and hood from the frame? Ken Quote
stuart Posted October 16 Report Posted October 16 5 minutes ago, Ken F said: Thanks all, if I removed the ally strips for the door windows would the header rail separate from the frame? I would then have the fabric and the header which I could safely put in big box in the loft. I would have to drill out the rivets that secure the webbing to the frame but then I could store the fabric without the windows being damaged. I would drive it with the hard top on then, I drove it for 30 years with the hard top. I made seats for the twins and fitted a firewall. Triumph world did a big article on it in about 1995. I was the only TR6 with a hard top at the international weekend and the seats for the twins peaked their interest. I bought the hood with windows from Moss and had to cut and fit and glue it and put all the poppers in etc. I can't remember how I fixed it to the header and I can't see under the seal but its probably riveted and or screwed. When I get room to store the hard top I'll put the soft top back on but it won't be any time soon so just sitting hard top on the folded hood is not my solution because come the spring I'd need the hard top on so I could drive it. ( I don't have space to store the hood and frame as one ) My wife said sell the hard top ( when she's not saying sell the car and all my cars) but I'm keeping it. So those nuts on the outer edges which hold the aluminium strips on.. will that let me separate the rail and hood from the frame? Ken No to remove the header rail you would need to grind off the large rivet at each end of the header rail where the side sections join it, this would separate it from the rest of the frame. Hood fitment at the front is usually glue on the fabric just under the front of the header rail and then the three parts of the seal channel are riveted on and the seal then added to the channel. Stuart. Quote
