Help needed please guys, to diagnose the source of an engine ‘knock’ noise coming from the near side of PI engine, in area of cylinder 4-5 / distributor / metering unit. It’s not tappets, or timing, or fuel delivery, as far as I can tell. It’s a ‘knock’; confirmed using mechanic’s stethoscope.
Engine originally CR but rebuilt to CP spec 2500 miles ago (ancillaries and internals to match). Noise appeared 1000 miles ago but no noticeable fall-off in performance.
Noise became worse recently and annoying.
Removed engine head, cam and followers checked. Followers 6&7, lobes 6&7 and corresponding rocker adjuster screw balls all pitted. All items renewed. New cam shaft. Naturally thought “problem solved”.
Top end reassembled. Car worked fine. Combustion good in all cylinders. BUT .. same Knock still there immediately. Same place.
Took sump off. Oil checked and was clean - no swarf, no ‘bits’, no observable contaminents.
Took con-rod end caps off on pistons 5 & 6. Checked Big end bearings on both - All fine. Not checked bearings in cylinders 4 -1 because that’s not where the noise is coming from.
Checked for play in gudgon pins on pistons 5&6 - none observed.
Checked for possible piton ‘slap’ as far as can be observed from a static engine but considered highly unlikely on inspection.
Distributor removed. Stem checked for play. Nice and snug. No play.
Metering unit (refurbished alongside original engine rebuild) and fuel delivery and injectors all fine. Not the strongest ‘click sensation’ on injector feeds 2 and 5 but has been the same for last 12 years without issue.
Before I strip the engine again, can anyone logically tell me what the knock could be.
Cheers guys. David Ansell (Clyde Valley Group).
Was the "pitting" there before the engine rebuild, or definitely occurred after?
Have you removed and checked the oil pump?
Hi Dave
I wonder if you have too much end float for pedestal drive cog/drive within the pedestal. It could be bouncing/knocking.
Or the drive to the MU.
Is the distributor and oil pump dogs fully home.
I'd be tempted to look here before stripping the engine.
Interesting good luck with it and keep us posted
Andy
Thrust washers set with no more than 6 thou end float ?
Knocking is usually big ends and mains will be a rumble.
Piston hitting underneath overlapping head gasket?
Careful strip down and mike up everything. Close examination should reveal its secret.
 Frustrating but hopefully you will find it!
Lets us know when you do.
Regards Harry.
A low sounding ‘donk’ on acceleration and deceleration I found to be excessive end float of the gearbox laygear.
The mystery knock on my TR4 was a loose valve insert which I failed to find until it broke up.
Other difficult to find knocks found on different TRs turned out to be a loose flywheel and a loose crank pulley.
Is the knock at engine speed or half that at valve speed?
Cam bearings or lack of?
Just delt with this on a 6
it was as mentioned a lose crank pulley.
Roy
Guys (all).
Very many thanks for all your insightful and valuable feedback. It’s genuinely appreciated.
Rather than answer each suggestion in turn I’ll work through the ‘list’ and tackle it all logically.
I will let you all know what it turned out to be.
Thanks again,
