Can somebody please confirm when fitting poly insulator seats to the front and rear springs are they usually fitted to the top as well as the bottom. Superpro state that they do not supply insulators for the top. Rear bases appear to be much thicker than the front ones which have a much higher upstand inside the spring.
Be very grateful for any thoughts please.
Thanks,
Edited by Tim T
Thanks,
Top and bottom, available in thin or thick https://superflex.co.uk/product-category/triumph/triumph-tr4a-6/triumph-tr4a-6-individual-kits/sf1028k/?v=7885444af42e
https://superflex.co.uk/product-category/triumph/triumph-tr4a-6/triumph-tr4a-6-individual-kits/sf10285k/?v=7885444af42e
https://superflex.co.uk/product-category/triumph/triumph-tr4a-6/triumph-tr4a-6-individual-kits/sf2327k/?v=7885444af42e
https://superflex.co.uk/product-category/triumph/triumph-tr4a-6/triumph-tr4a-6-individual-kits/sf23275k/?v=e529a9cea4a7
Edited by stuart
Very useful , Stuart. ,
Many thanks,
35 minutes ago, John Bracher said:
But you get them in the SuperPro 'Car kit', and the 'rear kit'??????
I agree John, and I have now found them but SuperPro did categorically say they do not make them for the tops of the springs. Interestingly enough the code numbers for them are the same as Superflex ie 1028 and 2327. Confusion also arose as one pack had 2 labels stating they were for the rear and another second label on the same pack stated they were front. Hence the call to SuperPro.
Anyway, all sorted now and onto the next issue!
Many thanks for all input.
First II have heard of this Tim.
Who ever you talked to (superpro)has been misinformed !
I now prefer superflex but that's just me.
Regards Harry
Harry,
It is quite disconcerting when the manufacturer gives you duff info. Also, not great when a distributor puts contradictory labelling on items. Anyway, now sorted with insulators top and bottom all round. Now having to deal with binding ball joints on the front suspension, locking up when on full extension, although Stuart has pointed to to Amsteer units.
Cheers,
I have found while changing springs on a TR4A recently that the top insulator has to follow both the spring hanger and spring profile at the top. The bottom of the trailing arm is flat with only the inner spring profile being more critical.
Not an expert but perhaps the need to follow the spring hanger profile at the top is an influence upon compatibility.
Regards
Steve
Awhile back the standard shocks for the fronts were slightly shorter and caused problems. Think they were rectified but not sure on that. I went with Konis as a superior damper and the correct length.
Amsteer are the best top ball joints but a tad expensive, there is some other top quality ones out there but need hunting down.
Regards Harry
If your ball joints are.new then connect to a drill and give them a good run .
frees up most
Roy
frees up most
Roy
Wont correct the lack of articulation though as thats what the problem is with some of the repro ones.
Ball joint issue now all sorted. Repro from a main supplier was barely 26 degrees, and managed to locate a nother pair with 32+ degrees. Attached image showing an original and the 26 degree repro.
Many thanks again for all input.
Cheers,
6 minutes ago, Drewmotty said:
Amsteer joints are the correct spec.
I had been trying to call them for days but the phone seems out of action and no replies to email either.
  • Tim T changed the title to TR5/6 coil springs insulators and ball joints
35 minutes ago, Drewmotty said:
I failed with email too. Keep trying the phone.
I did get a delivery receipt.
Got a pair from Richard C-R thanks.
On 10/20/2026 at 4:32 PM, dblenk said:
Just bought some i better check them
david
David, were the ones that you bought ok?
I now have a spare pair, if you need some!
Cheers
is that total movement or max to centreline
i fitted these to the 5 rebuild also ??
if total i have 32 degrees max to max (16 one way from Centreline)
i wouldnt have thought we would want a lot of movement ??
David
Edited by dblenk
David
I understand that the quoted angles are from the vertical centre line to the maximum articulation, left or right. In the photos below they are 36 degrees and 26 degrees. The 26 degree units when fitted cause the stub axle to bind up totally when the spring is at full droop/extension. This is not apparent with a fully loaded car but if the chassis is jacked up it will lock again, and if driven enthusiastically and the front wheels leave the ground it will again lock up making for an interesting landing! I also found that the fitment of the vertical link to the ball joint taper shaft was not ideal. The 36 degree unit resolved all of these issues.
I hope the photos show this although the 26 degree unit would not stay quite at its full extension.
Cheers,
The same issue with the reduced angle I found on the tie rods of new steering racks
—> with the car lifted the coil spring bend on the rack.
I posed that years ago, it’s better to check this with the car lifted and the ball joints not connected
