3 hours ago, Tim T said:
David
I understand that the quoted angles are from the vertical centre line to the maximum articulation, left or right. In the photos below they are 36 degrees and 26 degrees. The 26 degree units when fitted cause the stub axle to bind up totally when the spring is at full droop/extension. This is not apparent with a fully loaded car but if the chassis is jacked up it will lock again, and if driven enthusiastically and the front wheels leave the ground it will again lock up making for an interesting landing! I also found that the fitment of the vertical link to the ball joint taper shaft was not ideal. The 36 degree unit resolved all of these issues.
I hope the photos show this although the 26 degree unit would not stay quite at its full extension.
Cheers,
PM me and i will arrange to have the 36 degree units from you
thanks
David
