  • 3 weeks later...
Following on from this post,
I've bought this;-
reading the instructions, (Not like me) I see this is enough for a 16 radiator house!
Do I still use the whole container?
John.
I would think not John , Fernox is good stuff but in over concentracion might cause an issue down the line. The heating guy's that worked for the same outfit I did always used the apropriate ammount for the size of the system .
That bottle treats 130lt so I would use the amount for the capacity of the cooling system plus a bit assuming its for the TR.
In my domestic system Iv'e used a full bottle with no issues.
Bri
I use washing soda from Tesco, I mix up a nice strong solution and run with it for about a week so that it cycles hot and cold a few times before flushing back and forth.
George
Flushed mine with plain tap water from the hose a couple of days ago and was surprised and delighted to find the water coming out was blue from the Blucol antifreeze with no sludge evident, including from the tap on the engine block.  Refilled with blucol antifreeze and de-ionised water to last another two years.
Edited by PaulAnderson
photo added
Is there a reason why the bluecol antifreeze needs to be changed every 2 years- asking as in most cases these cars are not daily drivers and if the antifreeze is tested for protection and passes then isnt it a waste to change it unecessarily? Interested to hear views
Corrosion protection deteriorates. Antifreeze contains corrosion inhibitors that protects  cylinder heads,radiators and cast-iron engine blocks. Water pumps and steel pipes and internal waterways are also protected.
 The pH also reduces, becoming more acidic which will increase the likelihood of it attacking metal seals and gaskets.
Cameron
12 hours ago, Richard71 said:
I think the main reason is the deteriorating effect of the corrosion inhibitor. The mixture will protect from frost for far much longer than 2yrs.
Richard.
I agree, "rust never sleeps". Corrosion continues whether the car is used or not. In fact, I can see some argument for corrosion being worse in cars that aren't used due to local depletion of corrosion inhibitors in the stagnant coolant.
I don't know if antifreeze testers check for corrosion inhibitors.
My service regime is all usual annually at least then alternate every other service
Coolant change one year
Brake fluid change the other
it’s vipers in the scheme of things
