Hi Reiner,
yellow, red and blue is correct from my memory, on white I can follow you.
A locked bypass and a second oil pressure gauge at the end of the oil gallery would be interesting?
1 hour ago, Z320 said:
Hi Reiner,
Like Brian posted?
5 minutes ago, Z320 said:
Indeed, he did,
but this is not original and a detail he should point on (did he?)?
God point.  He is measuring gallery pressure after the filter.   The original pressure take off measures oil pump delivered oil pressure as maintained by the pressure relief valve.
Don’t we measure only the „Stau“ of oil through the bearings (and oil filter),
limited by the release valve?
Rainer
Yes, have done external check on my spare engine. It looks as if I have interposed the oil pump and main oil gallery on my sketch. The flow is in the opposite direction to my sketch.
Good lesson, check before you post.
I apologize to all for the confusion.
Brian
7 hours ago, Trumpy3 said:
Rainer
Brian
Brian, you don’t need to apologize. Your explanation was a great help and motivated me to understand it properly. That’s why I got another Purolator so I could follow along in a hands-on way. Thank you so much.
