Don H. Posted October 17 Report Posted October 17 Seems like every season I lose a few speed nuts from the small screws that hold the grille in place. I hate speed nuts, BTW, and although my car's nice, it's nowhere near a concours contender. But it's fun to keep it original and it lets me use the red book for almost all services. That's why I've continued to use those frustrating little nuts. But the community here must have a good tip for keeping those spring metal nuts attached, yes? A bit of Dum Dum on the back? A small piece of rubber sheet as a lock washer? Their replacement with proper small setscrews and nyloc nuts? Something else? Quote
james christie Posted October 17 Report Posted October 17 I have had the same problem! Resolved by fitting 'Rivnuts'. I'm also about to fit them to the doors to hold the panels, which shed their screws at regular intervals. james Quote
Ian Vincent Posted October 17 Report Posted October 17 1 hour ago, james christie said: I have had the same problem! Resolved by fitting 'Rivnuts'. I'm also about to fit them to the doors to hold the panels, which shed their screws at regular intervals. james I fitted 3mm rivnuts to hold the door panels a few years ago, problem solved. I don’t have a similar problem with the grill. Rgds Ian Quote
Ralph Whitaker Posted October 18 Report Posted October 18 I thought they were just self tappers into the steel, how on earth do you hold the speed nuts in place while inserting the screws. I`ve always known them as spire nuts. Ralph Quote
Charlie D Posted October 18 Report Posted October 18 (edited) I use M4 "well nuts". I actually use them in different lengths and thread sizes for all sorts of things. https://www.ebay.co.uk/itm/224153652299 Charlie Edited October 18 by Charlie D Quote
RogerH Posted October 18 Report Posted October 18 15 hours ago, Don H. said: Seems like every season I lose a few speed nuts from the small screws that hold the grille in place. I hate speed nuts, BTW, and although my car's nice, it's nowhere near a concours contender. But it's fun to keep it original and it lets me use the red book for almost all services. That's why I've continued to use those frustrating little nuts. But the community here must have a good tip for keeping those spring metal nuts attached, yes? A bit of Dum Dum on the back? A small piece of rubber sheet as a lock washer? Their replacement with proper small setscrews and nyloc nuts? Something else? Hi Don your nuts look a little flat ! try bending the speed nut to give it more spring. That may help to retain it. Roger Quote
TR Rob Posted October 18 Report Posted October 18 3 hours ago, Ralph Whitaker said: I thought they were just self tappers into the steel, how on earth do you hold the speed nuts in place while inserting the screws. I`ve always known them as spire nuts. Ralph As Ralph says, when I removed and replaced my grille, the grille was held in place by chrome Philips head self tappers ! Quote
Don H. Posted October 18 Author Report Posted October 18 (edited) 5 hours ago, Ralph Whitaker said: I thought they were just self tappers into the steel, how on earth do you hold the speed nuts in place while inserting the screws. I`ve always known them as spire nuts. Ralph Moss USA call 'em spire nuts, too. I always learned them as speed nuts -- maybe that's more common over here with spire being more British/European, or because my father was a native Clevelander (Ohio), where the Tinnerman company that invented them was headquartered. They're the easiest thing in the world to fit along the bottom of the grille opening. Nut in one hand/sheet metal screw in the other. Edited October 18 by Don H. Quote
Don H. Posted October 18 Author Report Posted October 18 5 hours ago, RogerH said: Hi Don your nuts look a little flat ! try bending the speed nut to give it more spring. That may help to retain it. Roger They do indeed look kinda flat, Roger. I've tried bending those things on other projects over the years with so-so results. And they're pretty tough little pieces of spring steel. I'm going to try a small rectangular piece of inner tube sheet rubber as a washer for the speed/spire nut to bear against. That may do the same thing as your idea to give the corners of the nut a better way to bite. Quote
Don H. Posted October 18 Author Report Posted October 18 20 hours ago, james christie said: I have had the same problem! Resolved by fitting 'Rivnuts'. I'm also about to fit them to the doors to hold the panels, which shed their screws at regular intervals. james Rivnuts could be an excellent solution. I'm always reluctant to go down the one-way street of enlarging holes, and rivnuts would take something like a 1/4" / 6mm hole in the sheet metal. Rivnuts could be perfect for door trim panels! Quote
james christie Posted October 18 Report Posted October 18 I also used rivnuts on the gearbox tunnel - the floors from Cox and Buckles that I had fitted some 48 years ago didn't have captive nuts so I had initially just used nuts and bolts. Using a cordless drill with the appropriate socket means that getting the transmission cover off is now slightly less of a chore. james Quote
BlueTR3A-5EKT Posted October 19 Report Posted October 19 I am considering using square body plastic nuts. Just need to file the holes in the apron grille area square and repaint as required. My friend hot glue gunned the spire nuts in place on his apron. I could well consider that as an alternative to filing and painting. Page 58 in this catalogue. https://www.bresco.com/acatalog/BrescoCatalogue.pdf Quote
