Hi everyone
With less than a week to go till the Restoration Show at Stoneleigh next Sunday, if anyone would like me to bring parts along to view with no obligation to buy, then please get in touch. I'm already taking along pre-orders so the more the merrier.
I will not be having a stand, but just for a change going along as a spectator/viewer as I rarely get a chance to do this. There will be plenty of opportunity to rendezvous either in the halls or the car park.
I'm still looking for some nearside (LH) crash pads ( not necessarily TR4/4A grab handle ones) in any condition, the worse the better, so if you have any of these gathering dust before going in the bin, please bring them along.
Look forward to seeing you all and having a natter - unfortunately no opportunity for a forum meet!
Cheers Rich Crewe-Read
I wont be attending, but would be interested to know what your plans are with the crash pads? I have a damaged LH one and wondering what/how to repair the plastic covering.
Hi Gav,
the LH grab handle crash pad (is that the one) is repairable but can be fun!!
It is also availabe ready made by the TRShop in chiswick.
The Crash Pad has a metal backing that will not fit easily to a re-covered handle. You need to cut some of  the foam away.
Stretching the vinyl can be frustrating but is do'able.
Use a decent contact adhesive arefully.
Finally there are dozens of patterns on the vinyl try and chose one that closes matched what you already have.
Gav - basically you can't repair the cracked plastic without it being very obvious and pretty much unacceptable as it won't match the other trim bits. Where the plastic covering is damaged/split, the foam underneath is usually damaged and crumbly as well. This damage all has to be cut out, stabilised and then filled and sanded to match the original contours. I then get the prepared item recovered in a top quality leathercloth which is virtually indistinguishable from real leather - in order to accommodate all the curves and bends, it is much easier and creates a classier ( in my view) end product by having stitched leading edges.
The problem with this is that need to match the other handed crash pad, and somehow, my stock has got out of kilter, such that I have 4 more finished offside ones than nearside ones - as they need to be sold as matched pairs, I have a problem, hence my request. I am quite happy to source plain nearside ones to make up pairs for the later TR5/6 models , but will take the grab handle ones if I have to - they are a lot more work but doable with their own challenges like the metal under strengthener on the back of the handle bit ( I don't think the repro ones have this strengthener).
As Roger says, there are loads of different vinyl patterns out there, but I have yet to find one which so closely matches the original item as to not be obvious - also, if you cover one side, even without a stitched edge, I can't see how that wouldn't stand out like a sore thumb when compared with the other.
Check out the photos below - I can take some along to Stoneleigh on Sunday if anyone wants to check them out in detail - I also have matching switch plinths and H frames.
Cheers Rich C-R
