Mad-River-68 Posted October 19 Report Posted October 19 Hi all. Our 71 6 has a replacement Lucas wiper switch. I installed it as follows: blue/light green - 1 green - 2 red/light green - 4 brown/light green - 5 my issue is that the switch is off then the top is pushed in, slow in the middle position, and fast in the down position. I believe it should be off in the middle position. Any wisdom would be appreciated! Quote
RobH Posted October 19 Report Posted October 19 (edited) It is working correctly. That particular switch cannot be made to do what you suggest as its switching pattern will not allow it. Edited October 19 by RobH Quote
TR NIALL Posted October 19 Report Posted October 19 1 hour ago, Mad-River-68 said: Hi all. Our 71 6 has a replacement Lucas wiper switch. I installed it as follows: blue/light green - 1 green - 2 red/light green - 4 brown/light green - 5 my issue is that the switch is off then the top is pushed in, slow in the middle position, and fast in the down position. I believe it should be off in the middle position. Any wisdom would be appreciated! That’s the way mine also operates. Quote
Mad-River-68 Posted October 19 Author Report Posted October 19 Thanks all! I appreciate the gut check! Quote
