Howdy all!
This is what I hope is the last question of the rewiring project for our 1971 TR6!  Just finished testing everything, and going for a test drive.  Everything works as it should - from window washers to courtesy lights, trunk light, all switches, new fog lights, etc.  Even the USB charger I added!  It's been quite a project!
The one thing that is giving me pause is that the new alternator whines when I switch the headlights on.  It's an aftermarket 43 amp unit, like the one Moss sells, but purchased new from another source.   It's definitely charging the battery, but I don't like that sound.  Any wisdom from the collective would be most welcome!  I do plan on trying a new belt - it's on my list of things to take care of as this project comes to a close, but it's in good shape, and is tight but not too tight.
Thanks as always!
Is the belt alignment right - i.e. the pulleys exactly in line?  If not, the belt might be dragging on one side of the vee.
Is that sound present when idling or driving  or when simply reving the engine.
Any other electrical components in use when you hear it ?
Maybe what you are hearing is just electricity being 'generated'.
Also if the belt is very worn it maybe sitting too far down in the pulley grooves to grip sufficiently when load comes on.
