John Morrison Posted October 20 Report Posted October 20 Hi folks, what’s the latest thinking on the above, which one and from where. John Quote
Harbottle Posted October 20 Report Posted October 20 1 hour ago, Lebro said: Wosp for me, Bob Me too, had no problems since fitting several years ago.🫰 Quote
Rob Salisbury Posted October 20 Report Posted October 20 Maybe I've been lucky but the 62 year old lucas starter motor always starts the engine when I ask it to, I suppose around 20 years ago I renewed the brushes and replaced both phosy bronze bushes and gave it a clean, but it just works. Why re invent the wheel? Cheers Rob Quote
Hamish Posted October 20 Report Posted October 20 Sometimes one needs to especially if you go a bit sporty and higher compression. or an original fails in a big way and a replacement is due anyway. Why not go high torque Quote
Dave McDonald Posted October 20 Report Posted October 20 I enquired about hi torque starter at TR Shop just last week. Their TR5/6 WOSP motor is £235 and they tell me is 1.4 kw, whereas (they tell me) the Rimmers Powerlite unit at, £265, is only 1.0 kw. I’m no auto electrician, so if what I’ve said is rubbish then so be it, but it seems to me that TR Shop item is best deal. Dave McD Quote
james christie Posted October 20 Report Posted October 20 I think you will find that the 1.4kw unit is Wosp and the 1.0kw Powerlite. I have had a Powerlite for a few years now. Excellent james Quote
tim hunt Posted October 20 Report Posted October 20 When the Lucas M418G starter motor on my 4A became unreliable, rather than overhaul it I decided to fit a high torque motor, settling on a Powerlite RAC 102. This is much lighter than the original Lucas unit and takes much less current, whilst producing far greater torque than an inertia type. Another advantage is that the new starter motor is much smaller than the original, and it will pass between the steering column and engine without the need to disconnect the former to remove it. The internals are as used on starter motors supplied to Nissan and reliability has not been an issue in the 15 years since I fitted it. I find the 1.0kW output more than adequate! As for fitting the new motor, the lower fixing bolt is quite easily accessible from beneath the car. The upper mounting, however, is a different matter. The drive end cover on the motor is positioned to give optimum clearance for the motor when fitted. One result of this is that the motor is supplied with a 3/8” UNF stud fixed on splines through the upper hole in the end cover. When fitting the new motor it is just possible to place a spring washer over the stud behind the bell housing and then to start threading a nut. I found it impossible, however, to tighten the nut from the engine compartment since there was no room to use any spanner in my tool kit. After some head scratching I came up with the (now obvious) solution. I carefully cut out a 4” x 4.5” section of the original thick cardboard gearbox cover in the area of the upper starter motor fixing This allowed a slim 9/16” socket to be fitted on the nut and will make any subsequent removal of the starter motor, if ever necessary, a doddle. A thin piece of aluminium or steel sheet, suitably shaped to fit the cover curvature, should be cut a little larger than the hole and then secured by self tapping screws in spire fixings. Tim Quote
RobH Posted October 20 Report Posted October 20 Both WOSP and Powerlite are basically a Nippon Denso OSGR motor unit ( Off-Set Gear Reduction ). I believe they buy those motor units in and make the mounting adaptions to fit different cars. The wattage is not really important provided the gearing gives sufficient torque to turn the engine under all conditions. A Lower power starter would actually be an advantage as it takes less current and so gives less dip in battery voltage while cranking , meaning the ignition can produce a better spark. Quote
Trumpy3 Posted October 20 Report Posted October 20 One other advantage of the hy-torque starter is that it is much kinder on the ring gear. The bendix system relies on the high initial torque of the starter to pull the pinion into the ring gear. The pinion engages the ring gear at speed and results in the ring gears we see after a time and needing changing. The more often you use the car the faster this will occur. The hy torque is a soft engagement starter where the initial process engages the pinion while turning the pinion with a low torque. Once the pinion is engaged the full power is applied and away you go. Ring gears should see you out. Also their efficiency may allow a successful start with a low battery. Brian Quote
John Morrison Posted October 21 Author Report Posted October 21 Many Thanks Guys, I'm asking for someone else in the group. Best John. Quote
stuart Posted October 21 Report Posted October 21 There are Hi Torque starters and there are Hi Torque starters, some are better than others. Stuart. Quote
PodOne Posted October 21 Report Posted October 21 53 minutes ago, stuart said: There are Hi Torque starters and there are Hi Torque starters, some are better than others. Stuart. Ripe for a recondition and it's as good as new! Let me guess who supplied it. Quote
stuart Posted October 21 Report Posted October 21 1 hour ago, PodOne said: Ripe for a recondition and it's as good as new! Let me guess who supplied it. Not difficult to guess. Stuart. Quote
michaeldavis39 Posted October 21 Report Posted October 21 No problem for me with a refurbed original Lucas. My old school mechanic friend has had poor experiences with High Torque starters and has lost time and money on them so will not ever fit them regardless of customers request- he has original starters refurbed now. Quote
RogerH Posted October 21 Report Posted October 21 I have had two of these fancy starter motors and both failed just after a year. I took them to a decent auto electrician in Uxbridge and the one fitted to the car has worked faultlessly for 10 - 15 years. The other I sold to a TRR member and I believe it is also working faultlessly. They must have been built late on a Friday afternoon using parts from the scrap bin. Roger Quote
multipletriumphsinner Posted October 22 Report Posted October 22 We were doing/selling these twenty odd years ago. Back then they hadn't been repro'd in China, so we had a chap touring all the scrap yards in the Midlands for used original ones (he also brought us overdrives, diffs, etc). We stripped them, had the front cases machined to accept our own adaptor plate, and then gave the lot to our local auto electricians to properly recondition them. It went really well for a decade or so, minimal warranty, and a few thousand sold to trade, and retail. Inevitably the used core started to dry up at about the same time the repro stuff started to flood in. We bought several different repro's in, and gave them to our trusted reconditioner for their thoughts. They condemned most of them, and wouldn't warranty any of them if they built them using our machined front cases, and adaptor plates. One of them would work, but only if they could change a couple of key components which would shove the price right up. Those original Japanese manufactured starters were bullet proof, whereas the first generation of repro stuff was absolute tat. Quote
PodOne Posted October 22 Report Posted October 22 China to the rescue. Dread to think how long their cars will last 2-3 years to cover the warranty and bang its done sir! Quote
trevor Posted October 23 Report Posted October 23 Wasp for me , bought from TRGB who were very helpful . Quote
Dave McDonald Posted October 23 Report Posted October 23 On 10/20/2026 at 10:00 PM, james christie said: I think you will find that the 1.4kw unit is Wosp and the 1.0kw Powerlite. I have had a Powerlite for a few years now. Excellent james That’s what I said! Dave McD Quote
