7 minutes ago, BlueTR3A-5EKT said:
Did you buy it?
No not me.
apparently the original rear shape could still be behind that slab rear !?
All very TVR mid 60’s when the Kamm tail was in vogue   At least the converter resisted using Cortina real lamps.
It does look like the back panel is bolt on, at least its still on its original Buckinghamshire plate.
10 hours ago, Kiwifrog said:
Bit of a bargain at 2.5k
plus £600 buyers premium. The seller probably only walked away with ~£1750 if I read the fees/charges correctly.
The Auction house made the most
yes, I did try to help the vendor. They did post on our Facebook page that it was the second Le Mans entry car (I've seen so many of those in my 43 years playing with P's & W's). Got in touch indirectly through another member so I passed on the answers to questions. I estimated that with a V5 it was worth 2-3k. It is heavily modified (not just the "Cam tail") and would take a lot of work to resotre and that we could help as one member has a spare rear section IF anyone wanted to go back to standard.......
I felt the car would have been better represented with this section available
