johnw Posted October 20 Report Posted October 20 Good morning. I'm planning on changing my brake master cylinder. I've had a quote from past parts which is approximately double the cost of a TRW replacement. Have members had any problems with the TRW item. There seems to be quite a wide variety of prices so I'm assuming that there may be sub standard repros about. Many thanks John Quote
harrytr5 Posted October 20 Report Posted October 20 Recon yours (if original) from past parts. TRW are hit and miss. What price safety? Regards Harry P.S. I have heard, then this might be wrong, the firm that makes the proper seals has gone under or packed up but this is only hear say so I could be wrong!. Quote
PodOne Posted October 20 Report Posted October 20 9 hours ago, harrytr5 said: Recon yours (if original) from past parts. TRW are hit and miss. What price safety? Regards Harry P.S. I have heard, then this might be wrong, the firm that makes the proper seals has gone under or packed up but this is only hear say so I could be wrong!. Anyone know if the seal issue as Harry suggests is a genuine concern and if so the best source for replacements? Are Past Parts in the same boat? Having used various TRW MC and Slaves which have failed I had the original OEM cylinders refurbed by Past Parts its proved a cheaper option in the long run. Andy Quote
Malcolm Baker Posted October 20 Report Posted October 20 Some guys have fitted a Saab Girling 9100652 master cylinder....1979-93....Model 90,99,900. Has got to be better than the TR one with the problematic "tipping valve". Quote
harrytr5 Posted October 20 Report Posted October 20 22 minutes ago, Malcolm Baker said: Some guys have fitted a Saab Girling 9100652 master cylinder....1979-93....Model 90,99,900. Has got to be better than the TR one with the problematic "tipping valve". I did post this out and the important reservoir some time ago. Works really well.Fit at your own risk. Regards Harry Quote
rcreweread Posted October 20 Report Posted October 20 2 hours ago, PodOne said: Anyone know if the seal issue as Harry suggests is a genuine concern and if so the best source for replacements? Are Past Parts in the same boat? Having used various TRW MC and Slaves which have failed I had the original OEM cylinders refurbed by Past Parts its proved a cheaper option in the long run. Andy I spoke to Past Parts about this very issue recently and it is true that their quality UK seal maker had decided to shut shop - however, PP bought all their remaining stock to protect themselves and were flabbergasted when a large lorry turned up full of pallets of seals and everything else that supplier did - they hadn't got room for it all and the next door business had space and kindly offered to store it, so I don't think they are going to run out of seals just yet! Cheers Rich C-R Quote
multipletriumphsinner Posted October 22 Report Posted October 22 On 10/20/2026 at 10:03 PM, rcreweread said: I spoke to Past Parts about this very issue recently and it is true that their quality UK seal maker had decided to shut shop - Cheers Rich C-R Brovex-Nelson Quote
stuart Posted October 22 Report Posted October 22 2 hours ago, multipletriumphsinner said: Brovex-Nelson Thats a shame if theyve shut as theyre quite local to me, they made up special flexis for me to fit Italias. Stuart. Quote
Magz Posted October 22 Report Posted October 22 I'm going with the GoodParts dual master cylinder in my supercharged build. Running boost, it gets complicated to obtain vacuum for the standard brake booster (vacuum pump, canister, check valves, etc.) so I will simply eliminate the need for vacuum altogether. Side benefit: between the manual brakes and the heavier clutch my legs will get some solid strength training! 😉 Quote
stuart Posted October 22 Report Posted October 22 47 minutes ago, Magz said: I'm going with the GoodParts dual master cylinder in my supercharged build. Running boost, it gets complicated to obtain vacuum for the standard brake booster (vacuum pump, canister, check valves, etc.) so I will simply eliminate the need for vacuum altogether. Side benefit: between the manual brakes and the heavier clutch my legs will get some solid strength training! 😉 Or you could fit an electric vacuum pump which is what most modern diesels use. Stuart. Quote
Magz Posted October 22 Report Posted October 22 2 hours ago, stuart said: Or you could fit an electric vacuum pump which is what most modern diesels use. Stuart. Yes, I believe I mentioned that possibility in my post. I'd rather just get rid of the need for vacuum as I'm already adding an electric fan and electric water pump to the electrical load and the limited space in the engine bay. Quote
