Phil Read Posted October 20 Report Posted October 20 I am recommissioning a 4A and notice the trunnions have no grease nipples. The only grease points on the front are the top ball joints and track rod ends. Is this normal. Quote
Z320 Posted October 20 Report Posted October 20 Tr4A: the grease nipple is on the vertical link Quote
harrytr5 Posted October 20 Report Posted October 20 Hoping the ball jointed ones will be on the market very soon after being fully tested. Regards Harry Quote
Phil Read Posted October 21 Author Report Posted October 21 (edited) 22 hours ago, Z320 said: Tr4A: the grease nipple is on the vertical link There are no greace nipples in the vertical link, however there are two blanking plugs, i will investigate. Edited October 21 by Phil Read spelling Quote
Z320 Posted October 21 Report Posted October 21 I oil them via a siringe and modified nipples, locked with a rubber cap Quote
Phil Read Posted October 21 Author Report Posted October 21 1 minute ago, Z320 said: I oil them via a siringe and modified nipples, locked with a rubber cap They look about the right position. I will remove the plugs and fit nipples. Thanks for the advice. Quote
Z320 Posted October 22 Report Posted October 22 „My“ rule: use oil when ever possible, if leaking use grease Quote
Andy Moltu Posted October 26 Report Posted October 26 Just use grease. Too much hassle to seal the trunnion caps. Besides the early cars with similar (but not identical) trunnions ran on grease. The cynic in me wonders if it was a way of making sure that the agents got regular servicing work at a time when dealer margins on sales were being squeezed? Quote
BlueTR3A-5EKT Posted October 26 Report Posted October 26 2 hours ago, Andy Moltu said: Just use grease. Too much hassle to seal the trunnion caps. Besides the early cars with similar (but not identical) trunnions ran on grease. The cynic in me wonders if it was a way of making sure that the agents got regular servicing work at a time when dealer margins on sales were being squeezed? I think it was a decision brought in to be in line with the small chassis cars (Spit/GT6/Herald/Vitesse/Standard8-10 etc). Or did they start with grease then go to oil? Quote
Spit_2.5PI Posted October 27 Report Posted October 27 The Atlas (introduced 1958) and I think I'm right in saying the 8 & 10 (1953-59) were grease every 1500 miles. By the early 60's the Atlas was extended to 3000 miles. In the mid-60's the Standard/Leyland 15 and 20 (re-badged and stretched Atlas Major) the trunnions were 6000 miles with OIL, not grease. I don't remember there being any difference in the trunnion and vertical link part numbers. Of course, the Atlas and 8/10 saloons were all small car vertical links, not TR which are quite different in geometry. I don't know if there's any difference in the threads. Anecdotally, it has been said that grease of the period would dry out and, if servicing was lax, that's where the trouble started. Of course, the change to oil means trunnions must be "oil-tight" as has already been mentioned. However, I think it was driven by the desire to push out the service period to 6000 miles which made Standard-Triumph change to oil. It may well be that modern greases are not so prone to drying out, so if you've always used grease then carry on! Cheers, Richard Quote
Schnippel Posted October 28 Report Posted October 28 Hello, In practice, it has been shown that grease provides better protection for the joint. Why? Because grease is significantly more effective at preventing water from penetrating. Once water gets in, damage is inevitable. Best regards, Ralf Quote
Charlie D Posted October 28 Report Posted October 28 Or use Penright steering box fluid. Not really oil and not really grease. The best of both worlds. Quote
Drewmotty Posted October 28 Report Posted October 28 53 minutes ago, Charlie D said: Or use Penright steering box fluid. Not really oil and not really grease. The best of both worlds. +1 Quote
Phil Read Posted October 28 Author Report Posted October 28 Some interesting comments, thanks. I did fit grease nipples and pumped EP90 in, interestingly this pushed grease out from around the seal. Quote
Z320 Posted October 28 Report Posted October 28 Ralf, thanks for your explanation about grease/oil/water. About 15 years (?) ago I fitted both vertical links, trunnions and seals ( Superflex) new. And „only“ oiled them every year. If I have time and delight I will examine them, perhaps to come to a different conclusion to oil. Ciao, Marco Quote
