Ongoing saga of radiator cooling.   This is the radiator with starting handle hole that has the centre 3” of tubes blocked top to bottom.
I am replacing the 9” Comex/Revotec fan on my TR3    It is 9” as the standard Revotec 11” kit hits the front crank starting handle bolt unless you have dispensed with the extension and starting handle bolt.   I have made a 7/16” thick steel spacer to go under the head of a shorter bolt to hold the crank belt pulley in place.
Decided not to use the Revotec mounts as they were just not right.   I tried re drilling but they were shrouding the 12” fan flow.
Made a few right angle brackets from angle iron and had my brother weld them to the sides of the radiator on the rear flange..   Also had two stud plates welded on either side of the front edge sides to attach a radiator duct/tunnel to.
Here is work in progress.    Lots of trimming and tidying to do but the basic set up is there now.
That is a special work in progress . I have had many years of overheating and my Kenlowe fitted in front of the radiator has given up and gone solid. You make it look very professional and we need an update when it is fitted and working. You are lucky to have a brother who welds. I can not face hours out in the garage removing the front panel , with the weather so cold. At the moment it is running at a regular temperature and does not need any alterations.
Well done,
Richard
The SPAL puller on my 4 is mounted in a similar fashion on four tabs.
Front of engine with 7/16” spacer and short bolt fitted.
Peter
That looks like a complicated way of mounting a fan. Of course I could be missing something in your actual application. Attached are a couple of photos from my first fan fitted before going down the Volvo radiator path. Ignore the hoses, they are for mounting on my engine test stand.
The mount consists of two short lengths of aluminum angle, four self drilling screws, and four nut/bolts to mount the fan to the angles. If your fan is a bit larger, like yours, mount the angle in reverse.
Brian
5 hours ago, Trumpy3 said:
Peter
Brian
Thank you Brian.  That certainly is a simpler method.   My worry about using self tappers was screwing into the water tubes.   Hence the welded brackets fitted before the radiator recore.
Peter
The folded steel radiator surround on the TR is fairly solid and my experience is that it takes the load well. There is ample clearance from the radiator tubes for the screws, at least on my radiator which had been re-cored at some time prior to my ownership.
Brian
I too noted that the radiator side struts are quite significant, with plenty of space to do things with.
I welded straps with nuts on  to my side struts and the whole thing is quite solid.
