Grahamgl Posted October 22 Report Posted October 22 (edited) Gentlemen, When I was looking at the rolling chassis this morning the company carrying out the body work mentioned that there was no movement in the rear suspension. He jumped onto the rear of the chassis and the only movement was due to flexing in the tyres. The lever arm shock absorbers have been rebuilt and the leaf springs went to a specialist spring company in Birmingham for re tempering and putting together . When I fitted the leaf springs to the chassis I put them on as received with new spring eye bushes. Is the non movement of the rear suspension due to not having the weight of the body on the chassis or should I have greased the springs before installing them or what else could be the problem please? Or am I now worrying about nothing? Thanks Graham Edited October 22 by Grahamgl Quote
stuart Posted October 22 Report Posted October 22 17 minutes ago, Grahamgl said: Gentlemen, When I was looking at the rolling chassis this morning the company carrying out the body work mentioned that there was no movement in the rear suspension. He jumped onto the rear of the chassis and the only movement was due to flexing in the tyres. The lever arm shock absorbers have been rebuilt and the leaf springs went to a specialist spring company in Birmingham for re tempering and putting together . When I fitted the leaf springs to the chassis I put them on as received with new spring eye bushes. Is the non movement of the rear suspension due to not having the weight of the body on the chassis or should I have greased the springs before installing them or what else could be the problem please? Or am I now worrying about nothing? Thanks Graham I had the same problem when I rebuilt my Girling axle 4a and when fully built the axle only just cleared the chassis. I fitted new springs so you may find yours have been tempered up to similar standard, They do settle eventually but they definitely wont move with just the chassis weight. Stuart. Quote
Drewmotty Posted October 22 Report Posted October 22 I’d be concerned if it did move with no bodywork and just the weight of a single person jumping on it. Quote
Chilliman Posted October 23 Report Posted October 23 Got a rolling chassis here for an early 4 that is freshly built - it's exactly the same. Quote
