Hallo,
If I’ve used the search function correctly, it seems there isn’t any existing discussion on this topic. Has anyone switched to LED lights? I’m thinking of doing it (for obvious reasons...) — any advice?
aldo
There are actually loads of threads on here about LED lights.  Problem is the site search function doesn't work for three-letter words.   You need to use Google e.g.
"TR forums LED lights"   gets you these and more:
Hi Aldo
if you do get lucky with the search facility you will see that if you change the Flasher relay bulb you will need a new LED :ED relay.
the old one will not work with an LED
Also the RED ignition light needs to be a filament bulb. However there are ways around this (I believe)
@Ferrinone  I should have added you can do the exterior lights in a couple hours easy-as -- remember to get a LED Flasher relay (located under glovebox) as RogerH pointed out.
If you search their website for TR6 it will bring you to a page where you can order a complete kit, exterior (no headlights) or exterior (with headlights): https://www.classiccarleds.co.uk/products/triumph-tr6-led-bulb-upgrade-kit?variant=44744009285928
As to "which headlights" I went with cool white as I felt it was a purer whiter light vs. warm white (6000W vs. 4500W)https://www.classiccarleds.co.uk/products/led-headlights-h4-4500-lumen-hi-lo-beam-conversion-9-32v?variant=42325174794
Dashboard LEDs I've not done yet as that's a bigger project and I don't drive that much at night. Perhaps will do before a longer trip on the Continent but not yet.
Yes you won’t regret it. I have just completed my installation. I also used classic  car lights  https://www.classiccarleds.co.uk/
couldn’t have been more helpful. I went for the green gauge lights and the warm white headlights which were superb. The best is you can be seen now as well with the bright brake lights and indicators
the only mishaps ☺️ I broke the ignition lamp holder. Which I replaced with a plastic one which totally resolved the earthing out problem and it staying on. The other I removed the rev counter to get my hand behind to change the other bulbs ☺️ and got my hand stuck  a good 10 minutes later to free my self lol
Edited by Rob Waldron
I have changed only my headlights to LED warm white and they have never been so good. I bought the whole kit with reflectors. You do need to adjust the dipped beam by moving the LED  which is difficult when fitted on a TR3a. The reflector is held in place by  three small screws holding the chrome retaining surround. So to make an adjustment to the LED you need to have it disconnected. It is then very helpful if you hold the reflector and ask someone to select the dip and full beam options. You can then alter the pattern of the beam on the garage wall. It worked best for me to wait until the daylight had gone.
The dashboard above is more complicated to fit ??
Good luck
Richard
https://www.rac.co.uk/drive/news/motoring-news/new-mot-rules-for-led-headlight-bulbs/
Can anyone confirm that any of the aftermarket LED headlight bulbs meet the standard required above?
regards
Bill
Edited by Bill944T
Contact the supplier. The ones mentioned in this thread have a good reputation and so should/may give you good advice.
Not so here in Australia BTW. We have suppliers claiming the headlights are legal but so far there are no aftermarket replacements that meet Australian Design Rules (ADRs), which require testing to local standards. Uneconomic. A legacy from when we used ADRs to protect our local auto industry which no longer exists.
Cheers,
JC
(posted on behalf of Duncan @ Classic Car LEDs)...highlights/bolds trying to keep up with Duncan's email...
These are not available yet and will not be until 2029/30 at the earliest.
What nobody seems to be picking up on is most headlight fittings have not yet been approved and fittings such as H4 and H7 which are used by 80% of vehicles have not even started to be look at yet by the approval body and won't be until 2029 at the earliest!
Below is a copy of what we have sent to our local MP who is taking up these issues with the Department of Transport.  Our questions at the end really need answers and we are urging others to write to their local MPs too:
As a globally known and respected business based in Tenbury Wells of many years standing, specialising in modernising and improving the safety of classic cars, we write to you to express our concerns regarding the latest MOT Special Notice effective 14.10.2026 and in particular the legislation being imposed for LED replacement headlights.
We would appreciate you taking this up with the Department of Transport on our behalf and make representations on behalf of the Classic Car community and UK retailers who support them who should not be made to continue to suffer from poor and unsafe lighting when improvements are available that met the previous weeks UK MOT standards.
The background to our concerns is as follows:
There are currently, according to the DVLA, 338,697 classic cars on the road in the UK that were registered before 1.4.1986.  88% are licenced and running on public roads, 12% SORN.
The total registered UK car fleet is 37.5 million.
There are approximately 1.33 million licensed motorcycles on the road in the UK with an additional 1.46 million declared SORN.
Classic Cars therefore make up less than 1% of the cars on the UK roads.  The more recent classic cars have a requirement for either H4 or H1 fittings for their headlamps.
Older classics often pre-date H4 fitting lamps and the headlamp fittings are numerous such as P45T, BPF P36D, P36S, P26S, P15D, PX15D, APF P15D, BA20D, BA15D etc.
Under the new regulations put in force under MOT special notice 05-26: approved LED replacement bulbs in halogen headlamps there is now a requirement for all halogen lamps that are replaced with LEDs to be replaced with UNECE approved LEDr lamps.
The list of currently Approved UNECE LEDr Categories is as follows:
H11 (Primarily used in low-beam headlights and front fog lighting)
H8 (Commonly used in fog lights and day running lights)
H16 (Commonly used in fog lights)
HB4 / 9006 (Commonly used in fog lights and low-beams)
C5W (An auxiliary/interior fitting)
The status of other common fittings under review with UNECE is as follows:
Pending Formal Adoption (Expected 2027+): Technical specifications for H9, H10, HB3, and HIR2 have made progress through the UNECE working group level, but they are still awaiting broader international market implementation.
None of the above approved or pending formal approval are common fitments for car headlights and none are used in older vehicles.
Not Yet Approved (H4 and H7): The two most widely used headlight fittings, H4 and H7, are not yet included in the generalized UNECE LEDr framework. A harmonized UNECE framework for them is not anticipated until roughly 2028–2029
Not listed: H1, H3, P45T, BPF P36D, P36S, P26S, P15D, PX15D, APF P15D, BA20D, BA15D etc.
The MOT rules in force from 06.02.23 allowed the use of LED conversions that pass the beam pattern tests for headlights for Class 3, 4, 5 and 7 vehicles (car, private bus and light commercial vehicle) first used before 1 April 1986 and all class 1 and 2 motorcycles of any age.  They also banned the use of halogen to HID conversions.
As you will see from the list of currently approved UNECE LEDr categories, H4 lamps are not approved, and neither are any of the other fittings that classic cars use.  H4 are not being considered until 2028-2029 so, realistically, classic car owners that require an approved H4 fitting lamp are going to have to wait at least 4 years until they are available to purchase if these regulations are upheld with no exemptions.  The other lamp fittings are not even mentioned so the wait could be considerably longer assuming they are going to be approved at all.
The 06.02.23 ruling for MOTs worked well for the classic car industry and owners.  It meant that they could upgrade to LED headlights and be comfortable that they were not blinding other road users.  It made the cars much safer to use.  Because the MOT beam pattern test had to be passed, this removed the many poor quality LEDs that are currently on the market from use because the ones that passed do and did have the proper dipped-beam cut off lines. Without these defined cut off lines, they would fail an MOT.
There are many UK retailers specialising in these lamps that pride themselves on the beam patterns that their headlights produce.  They are also not excessively bright.
Customers always comment on the great beam pattern achieved with our design of LED headlights and we also get similar comments from MoT inspectors too. A large percentage of profit comes from such upgrades for many firms specialising in classic cars which have been allowable under the previous guidelines.  This rule change could force many more UK firms out of business.
In summary:
Why should classic cars continue to suffer from traditionally poor and unsafe headlights and put themselves at risk of an accident.  There is a very good argument for re-introducing the pre 1.4.86 ruling as the requirement for passing a beam pattern test at an MoT. This will remove the poor quality LED upgrades from use.  Complaints from the public are about factory LED headlights in the majority, which are excessively bright and often blind oncoming road users, especially those in use on modern SUVs.  The new regulations do not deal with this at all.
We would also ask:
Why are HID conversions of halogen lamps now allowed under the new MOT guidelines?  They were previously barred in 2023 as the beam patterns are generally very poor with no discernable cut off line on dipped beam.
Why are Class 1 and 2 Motorcycles exempt from these regulations. There are many more motorcycles on the road than classic cars.  Motorcycles are equally at risk of blinding oncoming road users as car owners.
Kind regards
Duncan
