dave bailey Posted October 23 Report Posted October 23 Hi everyone. The time has come with my TR5 restoration to get the body tub sand/bead/soda blasted, and I wondered if anyone could recommend someone who could do it I'd obviously like someone nearby if possible, but I'm prepared to travel further afield in order to find a company with a good reputation. I live in Winsford Cheshire. Thanks. Dave. Quote
BRENDA1 Posted October 23 Report Posted October 23 (edited) Hi the lad that sprayed my Surrey back light uses this company to blast it before he sprayed it, as there not far away may be worth a drive over for a chat, if no one else comes up with a local one, also a nice pub just down the road. Mike Red Rose Group Edited October 23 by BRENDA1 Quote
roy53 Posted October 23 Report Posted October 23 Dave I had my tub blasted by a company in Maldon essex a bit far from you but no distortion but a few unexpected holes .To be expected I guess Roy Quote
BRENDA1 Posted October 23 Report Posted October 23 You could also check these guys out, as there local and next door to Macc paints in Congleton who are very good. Mike Red Rose Group Quote
dave bailey Posted October 23 Author Report Posted October 23 Thanks Roy, yes perhaps a bit further than I would like to go. Quote
dave bailey Posted October 23 Author Report Posted October 23 Thanks Mike. Those BAD boys might be worth a closer look. Dave. Quote
Nigel C Posted October 23 Report Posted October 23 Sadly my guys have retired but I have done a lot of work with blasted components/exhibits/machined parts over the years and I am always amazed at peoples lackadaisical approach to the finished item. As soon as it has been blasted it must be at least etch primed, if they can't offer this service, walk away. I know you are probably only thinking of the areas you want repair etc but trust me, the moisture in your finger tips will start the rusting process straight away. I had some exhibits soda blasted by a new supplier and when I went to collect them there was a completely stripped VW bay camper sat outside, when I asked the guys when they had done it they said this morning, it was already rusting. We used to collect our stuff after they called me to say it was still being done, picked it up with cotton gloves, shrink wrapped and worked on that day. Especially if we were going for a clear lacquer finish as we've seen finger prints appear under the lacquer if not handled properly. Quote
Dave McDonald Posted October 23 Report Posted October 23 Hi Dave, hope you and Tracy are well. Glad to hear you’ve got the 5 ready for paint prep. I used Soda Blasting Ltd at Wolverhampton. Very competent. Appreciated the need to avoid panel distortion. Did all shell and external panels. Also etch primed it at their premises as soon as it was blasted. Dave McD Quote
Don H. Posted October 23 Report Posted October 23 (edited) Over here there are plenty of sandblasting contractors who bring their gear on a trailer to the work rather than taking the work to the sandblaster. That’s how my car’s frame and body shell were cleaned up at the shop to kick off its restoration. It might not be an option if you’re in a tightly-packed neighborhood, but if you have any space at all it could be worth checking out mobile sandblasting. Edited October 23 by Don H. Quote
dave bailey Posted October 24 Author Report Posted October 24 22 hours ago, Nigel C said: Sadly my guys have retired but I have done a lot of work with blasted components/exhibits/machined parts over the years and I am always amazed at peoples lackadaisical approach to the finished item. As soon as it has been blasted it must be at least etch primed, if they can't offer this service, walk away. I know you are probably only thinking of the areas you want repair etc but trust me, the moisture in your finger tips will start the rusting process straight away. I had some exhibits soda blasted by a new supplier and when I went to collect them there was a completely stripped VW bay camper sat outside, when I asked the guys when they had done it they said this morning, it was already rusting. We used to collect our stuff after they called me to say it was still being done, picked it up with cotton gloves, shrink wrapped and worked on that day. Especially if we were going for a clear lacquer finish as we've seen finger prints appear under the lacquer if not handled properly. Nigel, thanks for the information, I get the need for immediate priming of a newly blasted car body. Dave. Quote
dave bailey Posted October 24 Author Report Posted October 24 19 hours ago, Don H. said: Over here there are plenty of sandblasting contractors who bring their gear on a trailer to the work rather than taking the work to the sandblaster. That’s how my car’s frame and body shell were cleaned up at the shop to kick off its restoration. It might not be an option if you’re in a tightly-packed neighborhood, but if you have any space at all it could be worth checking out mobile sandblasting. Thanks Don, I don't really think that is an option where I live. Dave. Quote
dave bailey Posted October 24 Author Report Posted October 24 21 hours ago, Dave McDonald said: Hi Dave, hope you and Tracy are well. Glad to hear you’ve got the 5 ready for paint prep. I used Soda Blasting Ltd at Wolverhampton. Very competent. Appreciated the need to avoid panel distortion. Did all shell and external panels. Also etch primed it at their premises as soon as it was blasted. Dave McD Hi Dave. I've been reading up on soda blasting, and I must admit that I'm not totally convinced about it. I appreciate that it is a relatively gentle process. and won't distort body panels, but by the same token won't remove rust. The other problem is that the soda can find it's way into confined areas which can be difficult to clean out, and apparently any trapped soda will cause a bad reaction with subsequent painting. I'm not getting any of the outer panels blasted as I will hand sand (DA) them. So I'll be looking for something a bit more aggressive, crushed glass seems to be very good. Having said that, you seem very happy with the results from soda blasting, so I'm not sure. Anyway I'll give those guys a ring and see what they say. Good luck to you and Bailey for next season. Regards. Dave. Quote
Dave McDonald Posted October 24 Report Posted October 24 Dave, to be fair, Soda Blasting did use grit or sand blasting on the inner tub where rust was more prevalent and there was no worry about finished. appearance. Soda was used on all the external panels where avoidance of distortion was important, but also my outer panels were generally rust free and only needing paint removal. Good luck with your continuing restoration. Bailey is already looking forward to 2027 season. Dave McD Quote
BlueTR3A-5EKT Posted October 24 Report Posted October 24 Some one told me they had cat litter used as the blast medium on their shell. Certainly cheap. I have yet to try it. Quote
james christie Posted October 25 Report Posted October 25 Crushed walnut shells are a popular choice. But first you have to pick the walnuts. 😎 james Quote
RogerH Posted October 25 Report Posted October 25 49 minutes ago, james christie said: Crushed walnut shells are a popular choice. But first you have to pick the walnuts. 😎 james Hi James the Walnut shells would come under 'Prunus' blasting. Quite a gentle but effective blasting medium. Used extensively in aerospace, often incorporated with a liquid. Roger Quote
stuart Posted October 25 Report Posted October 25 I use a guy down West from me and I supply him with a can of Bonda rust and he primes it all with that straight away. Stuart. Quote
dave bailey Posted October 25 Author Report Posted October 25 6 hours ago, stuart said: I use a guy down West from me and I supply him with a can of Bonda rust and he primes it all with that straight away. Stuart. That's a good point, I would need to find someone who would be prepared to paint the car straight away with Bonda Rust. Anyway thanks all for your thoughts. I will start ringing around. (Perhaps I should try used cat litter, that would be a re-cycling win-win. 🤭 Dave. Quote
BlueTR3A-5EKT Posted October 25 Report Posted October 25 10 hours ago, RogerH said: Hi James the Walnut shells would come under 'Prunus' blasting. Quite a gentle but effective blasting medium. Used extensively in aerospace, often incorporated with a liquid. Roger Used it to clean the compressor of a RR Dart. Quote
RogerH Posted October 25 Report Posted October 25 1 hour ago, dave bailey said: That's a good point, I would need to find someone who would be prepared to paint the car straight away with Bonda Rust. Anyway thanks all for your thoughts. I will start ringing around. (Perhaps I should try used cat litter, that would be a re-cycling win-win. 🤭 Dave. If using 'used' cat litter try and remove the lumps first. Roger Quote
jimt Posted October 26 Report Posted October 26 Hi David ive used D&N in Sandbach as suggested by Mike B- for a chassis a good few years ago and they made a good job of it - Jim Tomczyk - Red Rose member Quote
dave bailey Posted October 26 Author Report Posted October 26 (edited) 16 hours ago, BlueTR3A-5EKT said: Used it to clean the compressor of a RR Dart. Used to fly with 2 RR Dart RD10 engines in the CMk1 Andover (RAF) Dave. Edited October 26 by dave bailey Quote
roy53 Posted October 26 Report Posted October 26 I went through the same quandary as you Dave before deciding on sand/fine grit It was a shame that the company that Pete Felon used which was a heat strip stopped doing tubs. He seemed very pleased with them and would have been my first choice. Quote
dave bailey Posted October 26 Author Report Posted October 26 Hi Roy. Never heard of 'Heat Stripping' unless you mean using a heat gun and scraper. Which sounds tedious over a whole body tub. Dave. Quote
