Lebro Posted October 26 Report Posted October 26 I think it means putting the whole car (or chassis etc) into a large oven, & heating it till the paint peels off. Bob Quote
RogerH Posted October 27 Report Posted October 27 They are the same place that Pete Fenlon recommended. Roger Quote
roy53 Posted October 27 Report Posted October 27 Yes that is them but when i checked 18 month ago they said they no longer do body tubs just outer panels Roy Quote
dave bailey Posted October 27 Author Report Posted October 27 That's an interesting process. I'm not sure how it removes rust, not that there is much rust on my body (car!). Also I'd be a bit concerned about possible movement/distortion caused by the heating, as I guess it must get pretty hot. Dave. Quote
jimt Posted October 27 Report Posted October 27 I used to use Ribble Tech to. Chemically clean blocks & heads but they no longer do ANY stripping - not even body panels -they now only sell the bulk chemicals for it. Quote
jimt Posted October 27 Report Posted October 27 25 minutes ago, dave bailey said: That's an interesting process. I'm not sure how it removes rust, not that there is much rust on my body (car!). Also I'd be a bit concerned about possible movement/distortion caused by the heating, as I guess it must get pretty hot. Dave. Wont remove rust only paint etc Quote
Chilliman Posted October 27 Report Posted October 27 1 hour ago, jimt said: Wont remove rust only paint etc +1 - That's why they used to have to give the tubs a bath in phosphoric acid after the heat process before priming. I've used Envirostrip several times over the years which does a great job of getting rid of everything including the rust & not experienced issues with chemical leeching but each to their own. I did have one tub & outer panels soda blasted when it became the new best thing about fifteen - twenty years ago which was a complete waste of time & money as far as I'm concerned. Even after any of these treatments you can still split panels apart & find signs of rust around the inner face of spot welds which has probably been there since the car was built 60yrs ago but not spread as it was sealed tight excluding oxygen. Don't forget there were no primers used between the panels back then. I just make sure everything is properly primed & sealed again but I'm not naive enough to think that after dipping or blasting all rust has been removed - it's not possible. Quote
dave bailey Posted October 28 Author Report Posted October 28 I've contacted a couple of media blasters from my list, and am encouraged to go with one of them. One near me, D & N shotblasting & painting Services. near Sandbach, and Midland Precision Blasting Ltd, in Bridgenorth. Both use crushed glass, and have experience with restoration of classic cars, so are sympathetic to the need for care. I'm still waiting to hear from VIP Powder Coatings Ltd. (TR Bitz use them) I'll report back with the results of my search in due course. It will be a while because I have to take off all the outer panels and mount the body on a rotisserie so that I can finish the welding on the underside, which I couldn't get to on the bench but I need to get something organised now bearing in mind how busy these media blasting guys get. Dave. Quote
RogerH Posted October 28 Report Posted October 28 Hi Dave, what are you thinking of getting powder coated. There are a number of previous posts suggesting powder coating parts such as the chassis is not a particularly good idea. The surface can crack and allow moisture in between the coating and the bare metal. It them rusts merrily and you do not see any of this going on. Better to use a decent chassis paint that you can keep an eye on. Roger Quote
David Farmery Posted October 28 Report Posted October 28 +1 for Envirostrip; had my 4A body shell and panels done by them. Didn’t experience any problems. Make sure you have it primed could be years before you get round to completing the bodywork! Be ready for seeing it in a worse state than you imagined. Quote
dave bailey Posted October 29 Author Report Posted October 29 13 hours ago, RogerH said: Hi Dave, what are you thinking of getting powder coated. There are a number of previous posts suggesting powder coating parts such as the chassis is not a particularly good idea. The surface can crack and allow moisture in between the coating and the bare metal. It them rusts merrily and you do not see any of this going on. Better to use a decent chassis paint that you can keep an eye on. Roger Hello Roger, Not sure where you heard I was planning on powder coating anything. The only parts I'm considering powder coating are the suspension components. I agree with you about the chassis, and am planning to hand paint it with a good quality chassis paint. Dave. Quote
BRENDA1 Posted October 29 Report Posted October 29 Hehe. I think Roger has got it mixed up with the company name VIP. powder coatings. Mike Red Rose Group Quote
RogerH Posted October 29 Report Posted October 29 15 hours ago, dave bailey said: I've contacted a couple of media blasters from my list, and am encouraged to go with one of them. One near me, D & N shotblasting & painting Services. near Sandbach, and Midland Precision Blasting Ltd, in Bridgenorth. Both use crushed glass, and have experience with restoration of classic cars, so are sympathetic to the need for care. I'm still waiting to hear from VIP Powder Coatings Ltd. (TR Bitz use them) Hi David, I did a wrong assumption. You mentioned VIP powder Coatings and I put 2 & 2 together and of coarse got the wrong answer. Roger Quote
Dave McDonald Posted October 30 Report Posted October 30 On 10/28/2026 at 9:25 PM, dave bailey said: ….mount the body on a rotisserie so that I can finish the welding on the underside, which I couldn't get to on the bench but I need to get something organised now bearing in mind how busy these media blasting guys get. Dave. Dave, good to hear that your rebuild of Mike Hughes ex race TR5 is coming on well. I have a rotisserie which I made specifically for my TR5 restoration. You’re welcome to loan it if you want. Dave McD Quote
dave bailey Posted October 30 Author Report Posted October 30 20 hours ago, RogerH said: Hi David, I did a wrong assumption. You mentioned VIP powder Coatings and I put 2 & 2 together and of coarse got the wrong answer. Roger Hi Roger, yes their name is a bit confusing, I believe that they do as much media blasting as powder coating! Dave. Quote
dave bailey Posted October 30 Author Report Posted October 30 1 hour ago, Dave McDonald said: Dave, good to hear that your rebuild of Mike Hughes ex race TR5 is coming on well. I have a rotisserie which I made specifically for my TR5 restoration. You’re welcome to loan it if you want. Dave McD Thanks Dave. I'm just about to start on the car again having had the summer off doing 'normal people' things. I'll bear in mind your rotisserie offer, I have Steve Chapmans at the moment, but having seen him at the Malvern gathering he has just bought a Doretti in serious need of restoration and he mentioned that he might need the rotisserie back. Dave. Quote
Dave McDonald Posted October 30 Report Posted October 30 1 hour ago, dave bailey said: Thanks Dave. I'm just about to start on the car again having had the summer off doing 'normal people' things. I'll bear in mind your rotisserie offer, I have Steve Chapmans at the moment, but having seen him at the Malvern gathering he has just bought a Doretti in serious need of restoration and he mentioned that he might need the rotisserie back. Dave. Dave, yes ok, just let me know when/if you want it. Dave Quote
