  • John Morrison changed the title to MU Drive Shaft Seals?
As Neil says:
you have to remove the pedestal and (carefully) follow the steps outlined in the  wsm.
Order some  paper gaskets as well, these may be damaged.
And renew the 2 O-rings.
Waldi
Hello,
For this, the housing needs to be inspected very carefully. Usually, the housing needs to be repaired because it's worn out. This requires a bushing to be manufactured, which is then pressed in after drilling out the housing. So, it's not a quick and easy fix! And you also need to consider the fuel resistance of the shaft seals.
Best regards,
Ralf
Take MU off
Send it to Neil Ferguson for a quick turnaround rebuild/refresh
Best money you might spend unless you've the deep knowledge type this is a critical thing that must work properly 😉
Edited by Steve-B
Not sure how rebuilding the metering unit would be needed. The pedestal seals are separate to the metering unit.
The drive gear does wear, particularly where the pedestal seals run which is a pain as they were not available last time I checked.
Hi Andy, my thought was if the pedesstal seals are leaking and it obviously has to be removed to replace them the time would be right to invest in  a refurb wouldn't you agree?
On 10/26/2026 at 7:54 PM, Schnippel said:
Hello,
Best regards,
Ralf
I agree, no use replacing the seals if the bushings are worn.
I also have this job to do and I'm not looking forward to it. Especially as I don't have the bullet-shaped widget shown in the manual to ease the seals over the leading edge of the cross-shaft. Does anyone offer a refurbing service for the PI Pedestal?
Cheers, Richard
Cheers, Richard
Hi Richard,
I believe TR-Trader still offers a service of refurbing the pedestal.
https://www.trtrader.com/parts-lists/Lucas-MKII-Petrol-Injection.htm
Francis
Cheers, Richard
Richard,
to avoid damage to the newly installed lip seals, I used a short bit of electrical shrink sleeve: I slided the small tube of sleeve over the shaft nose, then warmed the sleeve with a small flame so it shrunk around the shaft/nose.
Once the shaft is “in”, you can remove the sleeve with a nose plier.
Waldi
Only if the MU needs rebuilding.
Look on it as a separate job altogether.
Thanks for the tips guys. Waldi, I have some heatshrink and that's a great tip - I'll give it a try. If I mess it up I'll go to TR Trader as you suggest Francis.
All the best, Richard
Thanks for the replies/advice. As it’s quite a critical job to get right, I’ve chickened out and am taking it to Revington TR to do the job. They recon it’s a couple hours work so I can wait while it’s done.
