Simon at Precision Clutch, Henstridge,Dorset.
I would buy a new cover Sachs 3082 634 104 and a standard ap / Borg & Beck disc
Just need these Roger, I've been meaning to have this done for a while, linings even have the rivets.
Derek
+3 also they will recondition to suit your application too.
What is it about a Laycock cover that makes it so much preferred over other offerings? I don't believe I've driven a car with a Laycock clutch cover, I have an Luk clutch kit in my TR6 and it seems alright.
Richard.
Richard.
Gives a softer pedal feel, some of the replacement clutches sold these days are for the likes of a Transit and give a very heavy pedal.
Richard.
The Laycock clutch cover has the weakest spring of all TR clutch covers
and this is why it needs the lowest pedal force to release the clutch
Precision Clutch Components fitted a new diaphragm centre to my old Laycock cover and did a lovely job. I did not fit it to my car but gave it to a mates project TR5 which could be awhile before I will know if it works OK. Think the poundage was slightly down but shows a lot of promise. Unscrupulous recon ones out there have had the wear machined off resulting in thinner fingers.Be aware.
Regards Harry
Helix clutches feel pretty much the same is you use the standard clutch plates - and you can buy them off the shelf, interchange with 4 or 6 pad paddle plates with cerametallic materials. Really good quality.
Regards
Tony
Friction plates with glued paddles and without torsion springs are not everybodies darling.
Knowing what Tony does with them I would say they would be more than adequate for standard road use.
