I am working on a friend’s ‘74 TR6 US spec and it has a rear spring sag problem – the LHS looks too low, RHS looks OK. From what I can determine the car was too high at the back (but it was level) when he bought it so he got new back springs and got someone to fit them. Apparently the fitter managed to break something on the RH TA so they got another arm. This was all in the USA before it came to me in the UK. They were unaware of the date issue however - the arms need to be the same sort of age. I’ve just had a look and the LHS (original) is dated 8/74, RHS (replacement) is Dec 69. Support brackets are as per 1974 – inner 3 notches up, outer 1 notch up. Strange thing is the RHS with the replacement seems to sit about right whereas the LHS with the original arm is low.
Does anyone know what to expect with mismatched trailing arms when both sides are using the 1974 bracket set-up?  Presumably I'll have to get a matching TA at least?
Mark
if you are happy with the camber then just use the thicker insulators on the springs.   Ali are available
They can be bent due too kerb strike or now potholes etc
As mentioned it was changed so was it just fitted using the shims and brackets as was or properly setup
Roy
I expect the same shims and brackets were just put back exactly as found.  Remember it was this RHS with the replacement TA that actually seems the correct camber.  It's the other side that's too negative, strangely.
You can download a sheet of info from Buckeye triumph that gives all the info you need to set up correctly
not a quick job to do any alterations but perfect info sheet
spring height can be raised easy as I mentioned
Roy
